I know this is replying to a very old post. But I thought it might be helpful for others.
Sharing some knowledge on the EM3ev 5A charger with pics too (see below), and I have one question I really need an answer to. Please help!
I opened up (very easily, with 8 screws) the EM3ev 5A charger to set the charge voltages for my battery, to gain the following charge settings for different switch positions:
* Low switch: 56% 3.82v/cell 53.48v
* Middle switch: 80% 4.04v/cell 56.56v
* High switch: 90% 4.11v/cell 57.54
These were calculated specifically to my battery pack using:
http://www.ebikes.ca/tools/charge-simulator.html
There were 4 potentiometers (pots) in the charger, which I had to work out by trial and error which pot changed what switch position's voltage. This is what I found out:
- * Pot functions (when facing pot screwface):
* far left changes lowest voltage only (switch position I)
* second from left changes HIGHEST voltage only (switch position II)
* third from left, turn left to increase v (changes ALL voltages of all three switch positions, so use this first to get the middle switch voltage right, then the other two to adjust top and bottom)
* farthest on right does NOTHING to voltage (might be amps!?) I adjusted slightly a bit to test, and turned back to where i THINK it was originally, to within a couple of degrees angle.
So, here is my question: In the pics, you see the four blue pots. What on earth would the far right one do, from what you can see here! I tried to get as much detail in the pics as possible. I might have slightly changed this pot position, but I don't know what affect that has... Bit scary to use it now, without knowing.
Here are the pics: http://imgur.com/a/Yuksq
