Where did you get this info from? I can't find reference to it. Most articles cite a 3x increase. Over 1000Wh/Kg would be 4x or more, and a 'coin cell' would be substantially more than a 4x reduction to an 18650.
Thread for new battery breakthrough PR releases
Re: Thread for new battery breakthrough PR releases
Aus/us co-lab is trying to get a new battery off the ground. Source: the driven.nz
"Magnis Energy Technologies and its US partner Charge CCCV (C4V) announced to the ASX on Friday morning its Extra Fast Charge technology managed to get a battery up to 85 per cent in just six minutes"
Normal energy density cells, but goes on to say that the ultra fast charger is not associated with premature degradation of the battery.
Going to need a hefty charger @ ~8c charging
- Location: Sydney ..(Hilly part !) .. Australia/ Down under !
Not especially hefty if its only a 1000mAh cell.. !
....such as a cell phone !.....which is where the big market demand will be .
...but if it is for a 100kWh EV pack......??...yea !!
I think they're aiming at the ev market...
This is cool but I doubt I'll ever see a bike powered by it.
https://www.msn.com/en-us/news/technolo ... r-BB18mrO3
Powered by nuclear waste. Cool.NDB's innovation is in creating a new, proprietary nano diamond treatment that allows for more efficient extraction of electric charge from the diamond used in the creation of the battery. Their goal is to ultimately commercialize a version of their battery that can self-charge for up to a maximum lifespan of 28,000 years, created from artificial diamond-encased carbon-14 nuclear waste.
This battery doesn't generate any carbon emissions in operation, and only requires access to open air to work. And while they're technically batteries, because they contain a charge which will eventually be expended, they provide their own charge for much longer than the lifetime of any specific device or individual user, making them effectively a charge-free solution.
NDB ultimately hopes to turn their battery into a viable source of power for just about anything that consumes it -- including aircraft, EVs, trains and more, all the way down to smartphones, wearables and tiny industrial sensors. The company is currently now at work creating a prototype of its first commercial battery in order to make that available sometime later this year.
That's cool as shit even if it's a non-rechargeable. Would love to see a datasheet, lol.fechter wrote: ↑Aug 26 2020 9:52pmThis is cool but I doubt I'll ever see a bike powered by it.
My first major build: 1.6kW 8T MAC motor on a Trek 4500 MTB.
Monster MTB: Leafmotor 1500w @ 4kW on a Turner O2 full suspension.
The monster scooter: Heavy duty Cannondale semi recumbent - under construction.
Blue Dream: Maxaraya FS semi recumbent and high efficiency mid-drive - under construction.
https://newatlas.com/energy/self-assemb ... dendrites/
Nice. Just wish they would hurry all these breakthroughs along, I'm not a patient man! This sounds pretty promising though.
I thought it worthwhile copying this to here..
Some hope for a cheaper, safer, longer lasting, alternative for home storage battery packs.
They claim it it is so simple and easy to manufacture with readily available materials ( zinc and Bromine) that mass production costs could be 30% that of LiThium cells
GELION Endure..
https://www.gelion.com/wp-content/uploa ... -FINAL.pdf
https://reneweconomy.com.au/gelion-laun ... ays-28079/
GELION Endure..
NAWA are make headlines again... Not sure what happened to the ultracap breakthrough a few years back but this time they state they are ready to commercialise the tech with scalable process.
https://newatlas.com/energy/nawa-vertic ... electrode/
Not holding my breath but one day.....
What about these new amazing cells from Tesla? They named them 4860.... erroneously, because it should have been 48600 (*), but what about their tech spec? I read "5x energy density" but also "+15% range", so what's wrong here? Which are real specs?!?
Lithium battery correct cylindrical cells nomenclature is: "diameter - length - 0 ", with "0=lithium". That's way the cells 18mm in diameter and 65 mm in length are called 18650 and not 1865...
I haven't seen a spec sheet on those yet, but based on the presentations i've seen on them, the energy density change isn't huge or revolutionary. It sounds like more of a change in packaging and production efficiency.jumpjack wrote: ↑Oct 08 2020 3:58amWhat about these new amazing cells from Tesla? They named them 4860.... erroneously, because it should have been 48600 (*), but what about their tech spec? I read "5x energy density" but also "+15% range", so what's wrong here? Which are real specs?!?
I think the good thing is that Tesla is continuing to step back from the idea of using tons of tiny cells. Salvaged 4860x cells will be a dream for DIY ebike pack building because you could build them with 1P or 2P
Even without seeing a spec sheet, you must know that “5x energy density” is total BS !jumpjack wrote: ↑Oct 08 2020 3:58amWhat about these new amazing cells from Tesla? They named them 4860.... erroneously, because it should have been 48600 (*), but what about their tech spec? I read "5x energy density" but also "+15% range", so what's wrong here? Which are real specs?!?
If it were even 1.5X ED improvement, it would be a industry revolution with street parties on the Moon
.....but it is’nt !
And you are late to the game with the “Cell nomenclature”....Tesla’s previous cell was termed a 2170 rather than a 21700.... from 5 years ago..
Since they make them, they can call them anything they want
As the new cell is a lot bigger then a 2170 isn't the '5x the energy density' meant per cell (new vs old)? And the +15% range per volume of the total battery pack size?Hillhater wrote: ↑Nov 08 2020 4:32pmEven without seeing a spec sheet, you must know that “5x energy density” is total BS !jumpjack wrote: ↑Oct 08 2020 3:58amWhat about these new amazing cells from Tesla? They named them 4860.... erroneously, because it should have been 48600 (*), but what about their tech spec? I read "5x energy density" but also "+15% range", so what's wrong here? Which are real specs?!?
.....but it is’nt !
look up the definition of “Energy Density”..
& Since when was range a function of battery pack “volume “ ?
My apology, I meant to only write 'energy' without the 'density' behind it. As that is what they claimed on Tesla's Battery Day:
As I also immediately thought "that can't be right such a big step in density" I rewound the video and saw their marketing term 'energy'. But most people overlooked that and Tesla fanboys now claim the 5x energy density. Smart move Tesla...
No prob’s !
Teslas info reveal on this (4680 ..not 4860 ?)..cell was very “promo” like.
On simple volume ratio it is 5.54 times larger than the 2170 cell which Tesla rate at 4.8 Ah.
..so from a “volumetric” point of view the larger cell should be capable of a 26.6Ah capacity even using the current chemistry... but i believe Tesla have reported 25 Ah ??..which would not suggest an increase in energy density at all !
.. Further, the “6X power” statement could simply result from the increased Ah capacity ..( assuming the same “C” rate as the 21700).....But i would have expected a significantly higher “C” rate from the new “tabless” construction, especially as they implied a lower IR for this cell.
At the end of the day, these are practically pre-production “prototype” cells and may not fully reflect the final commercial production specifications.
- Stealth_Chopper 10 W
“Report on Emerging Energy Storage Technologies,” presents the results of research
conducted by NSWCCD for CPSC, under CPSC Contract No. CPSC-I-17-0002. CPSC funded this
research to learn about emerging high-energy-density battery technologies and to identify strategies to
mitigate the fire hazards related to battery failures. "
https://www.cpsc.gov/s3fs-public/NSWCCD ... Cwb2eiznIT
Summary ex:
"Battery safety remains a pressing issue for
LIB, and despite their ubiquity in many markets, the trends for future LIB are to become more
energy dense and cheaper, but not necessarily safer. "
Safety ex:
"Typically, cells are assembled into modules by spot-welding the positive and negative tabs
on each cell into the desired series or parallel arrangements. In more complex modules passive
safety mechanisms (e.g. fuses, channels for vent gases, intumescent materials) and/or active
mechanisms (e.g. forced air or circulated liquid cooling) may be included but in many instances,
cells are simply restrained with epoxy and sealed into a suitable enclosure. Alternative module
assemblies deliberately designed for improved safety have also been demonstrated, but are not
widely adopted by industry.
While intrinsic safety at the cell level, either by modifying the LIB
chemistry or adopting a safer alternative, non-propagating battery designs are a valuable second
layer of protection for cells and can contain thermal runaway should it occur."
Summary ex:
Safety ex:
...Toyota’s Solid State EV battery
There is a lot of noise on the jungle drums about Toyota going full commercial in 2021 with a solid State battery in a new EV
https://thedriven.io/2020/12/14/toyota- ... -for-2021/
Focus is on the 10 min recharge time, but few details of capacities , energy density, costs ,..etc etcJapanese car maker Toyota will introduce a solid state battery that can recharge to full in just 10 minutes 2021, a move that could revolutionise the electric vehicle market.
Deleted
