Thread for new battery breakthrough PR releases
LockH   100 GW
Re: Thread for new battery breakthrough PR releases
Post by LockH » Oct 05 2017 10:59pm
Suspect "Lack of dendrite formation is huge"... is huge... :)
viewtopic.php?f=3&t=57408
viewtopic.php?f=15&t=60564
Hillhater   100 GW
Post by Hillhater » Oct 06 2017 12:36am
pity they didnt state the Wh/L....but if i assume its similar to current LiCo cells, then that 943 Wh/kg would give approx 50 Wh in a 18650 size cell...or 4 times the current best , meaning about 10-12 Ah per cell ( if the voltage remains the same ?)
BUT.. 1322W/kg "best" power , would imply a output of less than 2C :| :cry:
Ah well, early days i guess !
Pajda   100 W
Post by Pajda » Oct 06 2017 9:14am
Solarsail wrote:
Pajda wrote:This announced Toshiba SCiB new cell sample with 50Ah capacity and volumetric density of about 360 Wh/l seems to me finally usable for BEVs if they can keep other parameters of the current technology like 30 000cycles at 100% DoD and 10C fast charging = 6 min to 80% capacity.
Sorry to disappoint. But 360 Wh/L is so low that few automakers will be inclined to use this. There is no indication of the energy capacity of this technology, in the article. Makes me think that the energy capacity is about half of today's batteries.
18650 by Panasonic, volumetric energy density = 630 Wh/L
Gravimetric energy density = 263 Wh/kg
No problem :D I compared the current LTO technology with about 170Wh/l with this newcomer. If we used as example Nissan Leaf, the current LTO technology allows to install about 14kWh in its battery box. Which is not practically usable even with 6min ultra fast charging option. But this new LTO anode technology gives you about 28kWh and it is fully comparable with standard Nissan 30kWh battery (because with LTO anode technology you can use 100% capacity without problems with cycle life). And you still have 6min ultra fast charging option (of course you need a 300kW charging station). I can imagine that this could be interesting for taxis, pizza delivery and so one. I would personally prefer a 60kWh battery with regular 45 min fast charging as a regular driver, because the price of the battery 28kWh with LTO anode vs. 60kWh C(Si) anode will be almost the same.
crazymanc   100 mW
Post by crazymanc » Oct 07 2017 5:38am
Hillhater wrote:pity they didnt state the Wh/L....but if i assume its similar to current LiCo cells, then that 943 Wh/kg would give approx 50 Wh in a 18650 size cell...or 4 times the current best , meaning about 10-12 Ah per cell ( if the voltage remains the same ?)
How is that a problem? A 1C discharge of a 10-12Ah cell is already as good as something like the NCR18650GA/PF at ~3C.
If 2C of these new cells would be anything like 3C of the old ones (in the way then discharge curves compare) that'd make them ridiculously good. 20-25A discharge currents from one high capacity 18650? You could easily run 250 watt ebikes on one series string!
liveforphysics   100 GW
Post by liveforphysics » Oct 07 2017 6:22am
True peak power is also when a cell voltage is pulled down to half its open circuit voltage, so in practice if it's 50% voltage sag at 2C, it's actually around a 1C useful cell ('which would still be ~25% voltage sag losses).
For a few years some lithium sulfur cells have been around with stupendous energy density >600Wh/kg, but the downside was always the poor native conductivity of the sulfur behaving like a substantial added series resistance, and poor mechanical stability from volumetric changes as it intercaltes and deintercalates lithium.
If asphalt solves the conducive issues and mechanical interface issues and cycling issues of using sulfur, even if they are 1C useful cells they still have the potential to be game changeing at the right energy density for longer range EV aircraft and long range commuter vehicles, as asphalt and sulfur are dirt cheap materials compared to exotic microscopic silicon particle doped graphite anode blends used in many modern cells today.
e-beach   100 MW
Location: Any Los Angeles area beach I am at. Or Santa Monica or possibly the south bay beaches.
Post by e-beach » Oct 07 2017 10:53am
Wonder what the asphalt does to recyclability?
Favorite Quote: "This is L.A., sugar. There is no 'over the top." --- Chris Erskine
Current build: Liahona w/ cheap front suspension and suspension seat post. Yescomusa 36v 800w generic front hub motor. 15ah Headway triangle mounted pack. Tronsung 30 amp,
Previous Build:1992 Trek Antelope 800 - Bone Crusher (no suspension) - Yescomusa 800 watt 36 volt front wheel kit. Don't do it! Get suspension!!!
Post by liveforphysics » Oct 07 2017 2:25pm
e-beach wrote:Wonder what the asphalt does to recyclability?
Solvents would cut the asphalt more easily than any other binder material I'm aware of, and all the solvent can be closed-loop vapor distillation process.
My hunch is that the aspht and sulfur would not be worth recovery at today's recycling tech and prices for the raw materials.
e-beach   100 MW
Post by e-beach » Oct 07 2017 6:48pm
liveforphysics wrote:.......
Then it all gets dumped into a landfill when the cells reach the end of their lifespan. I suppose a recycling tax could be placed on them.
Post by liveforphysics » Oct 07 2017 10:46pm
If the ingredients are something like beach sand and the waste stocks of petrochemical refining and/or stored fly ash piles from power plants, to make the grid storage batteries, it will be a while before its recycled.
As electricity today is likely to remain useful to store, batteries don't have a hard requirement to fail after 20-30years. As size and weight doesn't matter much, it should be possible to make energy storage systems that last millennia without needing to waste the time and expense to recycle
LockH   100 GW
Post by LockH » Oct 09 2017 1:04am
Mmmm... "beach sand"... Mmmmm... :mrgreen:
Buk___   10 kW
Post by Buk___ » Oct 09 2017 1:40am
This Toshiba SCiB with titanium niobium oxide anode looks both interesting and imminent (2019); I wonder how they'll be priced.
LockH   100 GW
Post by LockH » Oct 09 2017 2:25am
^^ HeHe... "I wonder how they'll be priced." Might qualify as "COST per mile" over the life of the cells. Yah? :wink:
Hillhater   100 GW
Post by Hillhater » Oct 09 2017 5:06am
Buk___ wrote:This Toshiba SCiB with titanium niobium oxide anode looks both interesting and imminent (2019); I wonder how they'll be priced.
Its a good idea to read the thread and do a search before posting... :wink:
From last weds..
chessir wrote:This Just In---https://www.google.com/url?q=https://ww ... LErTxpADIV
To be commercialized in 2019 Toshiba Scib - Prismatic
zzoing   10 kW
Post by zzoing » Oct 10 2017 12:20am
It would be a weird situation if they have batteries that last 3000 cycles with high capacity and that cost 3x as much inherently as current techs, so a car battery would be 40,000 dollars fixed cost but 3 times better.
The Asphalt leaching/nanotechnology/nanodeposition/electroplating sounds complicated.
The asphalt lithium prototype is probably 0.1g and as heavy as a fruit fly?
There are precedents of porous asphalt batteries from 2014 and 2016 in research journals, with stated gravimetry at 500mah / g^-1
Density wise, if it's a flake of sponge, it doesnt sound as dense as mouldable material. sponge isn't very pressable and mouldable.
I'm not very optimistic for the asphalt research, unless they have patented it. I think they even put graphene into the sponge first before putting the lithium on there. They leached the graphene with at least 1 acid and another product to purify and remove stuff from the asphalt.
There have previously been super performant forms of porous carbon form plant matter and coffee grounds, I don't know if they can be commercialized.
There are also porous asphalt sulphur battery research articles from 2 years ago.
Post by liveforphysics » Oct 10 2017 2:19am
zzoing wrote: I'm not very optimistic for the asphalt research, unless they have patented it..
A patent means you filled out some forms, and has no bearing on a thing being functional or viable or useful.
Ypedal   100 GW
Post by Ypedal » Oct 10 2017 7:39am
What i want, is a battery that will last 10 years.... period.... give me a calendar life guarantee and i'm on that like stink to shoot.
ES site status page:
LockH   100 GW
Post by LockH » Oct 10 2017 9:19am
ESB "No suitable matches were found."... for Zap&Go?
Carbon-ion battery could mean rapid charging:
http://www.bbc.com/news/av/technology-4 ... d-charging
Vid caption:
A new type of battery could let people charge gadgets, appliances and electric vehicles in seconds.
British start-up Zap&Go has developed carbon-ion supercapacitors that allow rapid charging.
The current version is not able to store much power, but the company hopes future generations will store much more.
V.Interested in the supercaps to do the "heavy lifting" at startups and up hills so don't much care re "not able to store much power"... by which time the batt "kicks in" to spin the motor and recharge the caps, ready for the next EVent. :wink:
chessir   100 W
Post by chessir » Oct 10 2017 11:53am
http://newatlas.com/sodium-ion-battery- ... ium/51682/
Touted as 80% cheaper , this would be my choice from Stanford.
bikeboy-silence is golden
ezip trailz dual24v10ah sla and/or ductape24v10ah lifepo4
gogo   10 MW
New Journal: Joule (?)
Post by gogo » Oct 12 2017 10:31am
http://www.cell.com/joule/home
I didn't see anything posted about this.
What is Joule?
Joule, a sister journal to Cell, is a home for outstanding and insightful research, analysis and ideas addressing a key global challenge: the need for more sustainable energy.
Joule is a distinctive and forward-looking journal, bridging disciplines and scales of energy research. Joule connects all who are researching and analyzing the challenges — scientific, technical, economic, policy and social — of providing sustainable energy solutions.
Joule spans scales of energy research, from fundamental laboratory research into energy conversion and storage up to impactful analysis at the global level.
Joule will purposefully highlight and amplify the implications, challenges and opportunities of novel energy research for different groups working across the entire spectrum of the field.
Research areas will include but not be limited to:
Batteries and supercapacitors
Biofuels and biotechnology
Carbon capture and storage
Energy access, security, and behavior
Energy grids and networks
Energy-harvesting devices
Energy policy and economics
Fuel cells
Geothermal energy
Hydrogen storage and energy
Materials for energy systems
Nuclear power
Solar energy
Techno-economic analysis and life-cycle assessment
Transportation fuels
Wave energy, wind energy, and hydroelectricity
"A conclusion is the place where you got tired of thinking." -Steven Wright
LockH   100 GW
Post by LockH » Oct 12 2017 11:57am
^^ 8)
LockH   100 GW
Post by LockH » Oct 16 2017 3:06pm
Air-Breathing Aqueous Sulfur Flow Battery anybuddy?
Air-Breathing Aqueous Sulfur Flow Battery for Ultralow-Cost Long-Duration Electrical Storage:
http://www.cell.com/joule/abstract/S254 ... 17)30032-6
Starts:
Highlights
•Chemical cost analyzed for 40 rechargeable couples developed over the past 60 years
•Aqueous sulfur/sodium/air system identified with ultralow chemical cost of ∼US$1/kWh
•Air-breathing flow battery architecture demonstrated at laboratory scale
•Techno-economic analysis shows installed cost is comparable with PHS (pumped hydroelectric storage) and CAES (underground compressed air energy storage)
... and:
Here, we demonstrate an ambient-temperature aqueous rechargeable flow battery that uses low-cost polysulfide anolytes in conjunction with lithium or sodium counter-ions, and an air- or oxygen-breathing cathode. The solution energy density, at 30–145 Wh/L depending on concentration and sulfur speciation range, exceeds current solution-based flow batteries, and the cost of active materials per stored energy is exceptionally low, ∼US$1/kWh when using sodium polysulfide. The projected storage economics parallel those for PHS and CAES but can be realized at higher energy density and with minimal locational constraints.
Huh. ESB "No suitable matches were found."... for anolytes. :mrgreen:
MIT's new flow battery breathes air to cut costs of renewable energy storage:
https://newatlas.com/air-breathing-battery/51720/
rumme   100 kW
Post by rumme » Oct 17 2017 9:33am
Ypedal wrote:What i want, is a battery that will last 10 years.... period.... give me a calendar life guarantee and i'm on that like stink to shoot.
Well such a " guarantee" is highly unlikely, considering that some people may use a battery for 200 cycles per year while others may only use it for 75 cycles per year.
Giving a guarantee on complete charge/discharge cycles would make more sense, as long as the battery had a built in " counter" to keep track of those cycles { kinda like a hour meter on a backhoe} . Of course the battery company would have to come up with some technology that guaranteed the batter cycle meter, could not be altered by the owner along with having some technology inside the battery to inform the manufacturer if the battery was abused in any of the charge/discharge cycles which would void the warranty.
LockH   100 GW
Post by LockH » Oct 17 2017 9:50am
Also? May wish to add that "expected ambient temps" thingee in there (re "useful life").
Hillhater   100 GW
Post by Hillhater » Oct 17 2017 7:36pm
For a battery that might be a " WattHour " meter to record the total Whs discharged during its life.
But then you have other effects like DOD, charge/Discharge rates, temperature conditions , etc etc..all of which have been shown to affect battery life.
But why would you expect a 10 yr guarantee on a battery ?... you dont get one on any of the other major purchases in your life, like Cars, houses, etc. ?
fechter   100 GW
Post by fechter » Oct 24 2017 8:19am
Lithium Titanate is supposed to last 25 years, but the energy density sucks.
