Another No Solder/Weld 18650 Build (Updated 03/09/2014)
Lurkin   100 kW
Re: Another No Solder/Weld 18650 Build (Updated 03/09/2014)
Post by Lurkin » Jun 22 2017 5:00pm
Interesting. Is that an app on your phone allowing you to do that heat imagery?
GlowInTheDarkNinja   10 mW
Re: DIY assembly kit for 18650 without spot welding/Solderin
Post by GlowInTheDarkNinja » Aug 30 2017 3:45pm
Does anyone have recommendations for non consuctive material? In the form of matting
I want something like a yoga mat, that can compress a bit. I'm planning to use the material as some what of a spring, in order to compress my battery contacts together.
spinningmagnets   100 GW
Post by spinningmagnets » Aug 30 2017 5:54pm
Poron, as seen on the Snath battery pack thread, info from LFP
viewtopic.php?f=14&t=57810#p862290
notger   100 W
Post by notger » Nov 01 2017 12:13pm
bzhwindtalker wrote:I calculated the deformation in the middle of the pack, it should be OK especially for the 10S6P (calculated for a 8S10P version)
The springs can compensate the middle deformation of the holder. There is a balance of clamping force to spring rate to find to make it work with a specific configuration and holder material. The spring travel is around 2.4mm and here the deformation is max 1mm, also this is with V1 springs with higher force, I reduced the springs force since this calculation.
Is there any News about your soldereless Packs ?
It looked/looks really interesting and promising.
So you are using them already in your Bikes right ?
greets
notger
Ecyclist   1 kW
Post by Ecyclist » Sep 27 2018 12:06am
Here is my final product. It is 10S6P with twin charging capability. I can charge it bulk with 42V charger, or I can balance charge it with SKYRC iMAX B6AC hobby charger. I can control amps. with VESC and I monitor cells with small volt meter and two battery testers / loggers.
I use XT-90 Anti-Spark Connector for bulk charging and power delivery and two XT-60 connectors for balance charging. The pack contains a fuse that doubles as a kill switch.
Don't expect from life to be easy and then it will be.
My builds:
Avian with hypocycloidal drive https://endless-sphere.com/forums/viewt ... 2#p1318056
2016 GNG extreme drive https://endless-sphere.com/forums/viewt ... 28&t=82252
MJSfoto1956   100 kW
Post by MJSfoto1956 » Oct 25 2018 8:25am
Ecyclist wrote:
Sep 27 2018 12:06am
That is a stunning piece of design and superb execution. A+
(you should sell this kit!)
Quick question: why two XT-60 connectors for balance? Are you using two hobby chargers in parallel? (i.e. charging either 5s6p or 10s3p each?)
M
Bois and their fancy tacticool ain't cool -- it's a pathetic circle jerk
QANON is a sick cult: https://www.rollingstone.com/culture/cu ... e-1064076/
Ecyclist   1 kW
Post by Ecyclist » Oct 25 2018 10:37am
MJSfoto1956 wrote:
Oct 25 2018 8:25am
Ecyclist wrote:
Sep 27 2018 12:06am
M
Thanks dude.
I use two XT-60 for balance charging 5s6p. One half at the time. Keep in mind that my pack is 10s6p and with this setup I can go up to 12s. Parallel charging with SKYRC iMAX B6AC is no go IMHO.
My builds:
patrickb   1 µW
Post by patrickb » Oct 25 2018 2:47pm
I only discovered this forum after finishing my own No Weld build. I used my cnc machine to cut out the parts. I'd like to share my concept:
Ecyclist   1 kW
Post by Ecyclist » Oct 25 2018 9:22pm
Nice work. Thank you for sharing. :thumb:
My builds:
Post by spinningmagnets » Oct 25 2018 10:19pm
Very nice work, Patrick. What is the thickness of the copper bus-plates?
patrickb   1 µW
Post by patrickb » Oct 26 2018 6:08am
The bus plates are 0.5mm. I soldered nickel plated contacts onto them. The build still lacks of a housing.
quuxman   100 W
Post by quuxman » Nov 27 2018 4:53pm
Jun 08 2017 8:14am
I like this design and would like to do something similar. Could you tell me more about the springs? Where exactly did you source them? Also, what's the thickness of the acrylic (I assume) and how deep are the cell holes? What exact diameter did you make the cell holes? I'm guessing something like 18.1mm?
Also what are the bus strips made out of, and where did you source those? Pure nickel, or plated copper? How thick?
liveforphysics   100 GW
Post by liveforphysics » Nov 27 2018 7:14pm
patrickb wrote:
Oct 26 2018 6:08am
Looks so clean, nice job. If you could find a way to eliminate the nickel and make a single stage of copper, or nickel plate the copper (it's actually really easy to do it home with low cost plating solutions, a sponge and a power supply.) Nickel is great for keeping a low surface oxide finish, but pretty sad for electrical conductivity.
Samd   1.21 GW
1.21 GW
Post by Samd » Nov 27 2018 11:34pm
Awesome.
I was thinking of a similar linear setup using carbon conductive spray on sanded copper, instead of nickel plating the copper. Thoughts?
http://ballaratebikes.com/
Post by spinningmagnets » Nov 27 2018 11:35pm
If the spring element is separate from the conductor (which I recommend), then the conductor can be copper or 6063 aluminum.
I have seen nickel, zinc, lead, and tin as the most often used plating material. As long as it's thin, the resistivity "hit" is not too bad. However, if the plating material is thin, why not silver?
If the pressure contact is silver-plated, why not use aluminum as the conductor (double the thickness compared to the equivalent copper contact, of course). The genuine Anderson contacts are silver-plated copper. The silver on those is thin enough that it isn't too expensive. In fact, it only needs to be silver-plated on the part that actually touches the cell.
I'm thinking that...if you use a bonded fuse-wire on the positive end, you only need silver-plated aluminum contacts on the negative. Thanks, Luke!...
markz   100 GW
Post by markz » Nov 28 2018 7:28pm
Why not
1) a mound of solder for the contacts and compress each end plate?
or 2) a dimple and something behind it to keep it from crushing?
fechter   100 GW
Post by fechter » Nov 29 2018 9:16am
markz wrote:
Nov 28 2018 7:28pm
Why not
Solder is a horrible conductor and will cold flow over time.
quuxman   100 W
Yet another No Solder/Weld 18650 project
Post by quuxman » Nov 30 2018 4:38pm
I was very close to ordering a set of N.E.S.E. modules from http://18650.lt/ but they're pretty expensive and I'd still need to make some sort of enclosure for the BMS. So I decided to build something very similar to patrickb (thanks for your post!). Here's the model I have so far:
I have two Tiny BMS boards from EnergusPS sitting around waiting for this project (I intend to build 2 packs like this). The holder is symmetrical so I'll fabricate 2 copies for a pack. The slot on the right should fit the BMS board. The cell holes are 18.7mm in diameter and 5mm deep to fit LG MJ1 cells. The electrodes will be dimpled nickel plated steel strap, .15mm thick and 8mm wide. Underneath the electrode strips will be strips of compression foam.
Originally I was assuming I'd CNC the cell holders, but 3dhubs.com has the cheapest fabrication quotes I've found, and printing 2x of these is 107$ whereas machining is 200$ more. I'm planning on printing with PETG because I've heard that printed ABS can be pretty brittle. I'm not entirely settled on this because ABS is stiffer and that's obviously important. The two halves will be held together with 10-12 M4 bolts with nuts and washers. The material at the bottom is 3mm thick in the thinnest parts.
Does this look reasonable to people with experience building this kind of pack? One thing I'm thinking of changing is making the whole thing 1-2mm thicker for extra stiffness. Another change I'm thinking might be worth making is making all the edges thicker with a groove, for holding a gasket and sidewalls for a full water proof enclosure.
quuxman   100 W
Post by quuxman » Dec 03 2018 12:06am
Did a tiny bit more reading, and PETG (with Glycol) is actually softer and stickier than PET, but worksalot better with FDM. This means I indeed want ABS. Also I have a much updated model, now made with parametric modeling so cell configuration can be changed nearly effortlessly:
https://gallery.autodesk.com/fusion360/ ... y-enclosed
UPDATE: Some of the parameters could probably be specified more conveniently (It's my first attempt at using Fusion360 or any parametric modeling). The main issue is when I export to STL there's intersecting faces, which 3dhubs.com complains about. Any ideas on how to fix this?
UPDATE2: Pulled the trigger at 3DHubs for a total of 185$, they didn't seem to think the intersecting faces warnings were an issue. I did figure out which operation causes them: the 3 plane fillet. I updated the model more, some minor physical changes, but mostly better parameterization for changing things (I hope). This is my first venture into both physical modeling and 3D printing, so I expect there to be some issues. I already thought of one (forgot to leave some tolerance for the top case to fit around the base, so I'll have to sand it down probably). New model:
https://gallery.autodesk.com/fusion360/ ... -pack-case
Post by spinningmagnets » May 31 2019 10:21am
Luke / LFP discusses the specifics of how heat on an 18650 cell affects the insides (the common method of spot-welding nickel buses onto the cell-ends)
viewtopic.php?f=14&t=99012#p1450141
