Gaozhao Charger Investigated (non-OEM from China)
Arvicola Terrestris   100 W
Post by Arvicola Terrestris » May 04 2014 9:15am
I'm curios by nature so I want to find out more about this charger that came with my battery. I'm not an electronic engineer so if you also are curios, feel free to join 8)
I bought a battery from China (ebay) and the deal included a charger:
Gaozhao for 48V LiFePO4 5A.
Most text on the charger is in Chinese, and there was of course no manual included.
There are to LED in front, I asked the seller what they indicated:
The Right LED is for Power to the charger on/off = red/nothing
The Left LED is for charging/charging ended = yellow/green
Not hard to figure out, but anyway nice to now for sure.
Reading on the back of the charger it says:
PWY4805 (appears to be the model number = Power+something+48V+5A)
AC 220V 50/60HZ
DC 60V-5A
It also has an CE marking but it is not the Community of Europe approval mark, it is of course the China Export mark.
The 220V plug is the worst and most dangerous plug I have ever seen, and MUST be replaced before use. The male plug on the battery is also dangerous, if you are wearing a gold or silver ring on your finger and by accident touch the plug, your finger ring will become a toaster. So now we know what CE (China Export) stands for. I have changed all plugs on the charger, those for the battery is now Andersons.
It is delivering approx. 300W to the battery, so at approx. 60V and 5A it seems to match.
It is noisy, and the fan inside is a normal 12V fan found in any desktop PC, so I'm going to change it for another more silent model, inside or outside.
There is a fuse next to the cable going to the battery, that's good (soldered - not good), but I can't read how many Ampere it's good for. Can it be measured?
There also appears to be a "pot" screw, maybe it's for the output voltage, anybody has a suggestions?
Link to the ebay.com seller:
http://www.ebay.com/itm/48v-30ah-LiFePO ... 1e7f494680
/Philip
EDIT: Left/Right LED was switched
EDIT: Appears to be identical with these plastic-shell chargers: Gaozao, Vpower, VeiBao
Top/front view
IMG_20140504_135944 800x600.jpg (211.71 KiB) Viewed 3139 times
Bottom view
IMG_20140504_140002 800x600.jpg (188.9 KiB) Viewed 3139 times
Inside charger
IMG_20140504_140038 800x600.jpg (215.91 KiB) Viewed 3139 times
Fuse bottom left, "pot" top right
IMG_20140504_140634 800x600.jpg (108.02 KiB) Viewed 3139 times
Last edited by Arvicola Terrestris on May 07 2014 5:21am, edited 2 times in total.
Christiania cargo trike, Bafang bbs02 750W, 48v, 16s2p LiFePO4 30Ah, 50kg
Grace mxII Urban S, 2. gen. Bosch 350W, 36v, Bosch Powerpack 400 11Ah, 23kg
Trek T420+, BionX PL250 HT, 250W, SRAM 3 speed IGH, 36v LiMn 9,6Ah, 20kg
U.S. Costomary Unit = SI Equivalent:
Length: in. = 25.40mm - ft = 0.3048m - mi = 1.609km
Mass: oz = 28.35g - lb = 0.4536kg
Pressure: psi = 6.895kPa (MPa = N/mm^2)
Velocity: mph = 1.609km/h
Volume: gal = 3.785l
mateusleo   1 kW
Re: Gaozhao Charger Investigated (non-OEM from China)
Post by mateusleo » May 04 2014 9:40am
I also have one of those but i'm pretty happy with it, the connector to the battery is C15 :
Which i find pretty safe, since there no way to touch the contacts unluess you stuck something in there. Also, i burned out that fuse once because when the battery came i was a noob and made the connetions inverse, lucky i had a common fuse to put in its place, seems to be same as any fuse, just soldered intead of plugged, and it was smple to solder the common fuse in the place. Its probably a 10A fuse. The connector to the outlet needed to be changed, its, in fact, not safe, and its not compatible with Brazil standard, also i need a bigger wire since i only have one 220v outlet in my house, so i changed it to a different plus with longer wire. The noise doesnt bothers me since it stays outside of the house.
If you plan to change the cooler, don't get a slow cooler, it gets a little bit warm while charging on 5A.
A thing i wanted to know if its possible to easily convert this charger to 120v AC, so i could easily plug it in any of the outlets in my house.
1000w - 48v Ebike with 48v 20ah LiFePO4 pack from sun-thing28
Post by Arvicola Terrestris » May 04 2014 10:03am
mateusleo wrote:I also have one of those but I'm pretty happy with it, the connector to the battery is C15
Agree that the female plug on the charger is safe, it's the male counterpart on the battery I was nervous about.
I will change the fan to a larger diameter model, that runs slower. Cooling effect will be the same.
Did you see what was written on the fuse you changed?
/Philip
Male plug on the battery
dnmun   100 GW
Post by dnmun » May 04 2014 10:30am
have you even used the charger? just started nagging about it because it is made by chinese people so it has to be hazardous?
i have no idea why you think the fan is inadequate. that is really just over the top. that is not how those chargers always fail.
Post by Arvicola Terrestris » May 04 2014 11:01am
dnmun wrote:have you even used the charger? just started nagging about it because it is made by chinese people so it has to be hazardous?
Take it easy! I have not said the charger is some Chinese shit, I have made some observations or take it as test, I don't care. It was cheap and that's what I got for my money.
The 220V plug IS dangerous... seen from the standards we are used to in Denmark/Norway/Sweden/Germany.
The fan is not inadequate, I have never said that, I said it is noisy....
Yes I have used it and it works well, and as I stated in the beginning: I am curios.
Do you have something to contribute with? I would be happy to now more about the small screw to the right, and I think you probably know what it could be or how to find out.
/Philip
IMG_20140504_175217 800x600.jpg (118.47 KiB) Viewed 698 times
IMG_20140504_175227 800x600.jpg (39.07 KiB) Viewed 3103 times
dnmun   100 GW
Post by dnmun » May 04 2014 11:07am
maybe this is the first charger you ever owned. all the charger fans are noisy. except maybe the headway charger but it is on 3.3A anyway. by screw i assume you mean the trimpot labeled R15A? it most probably is used to set the final charger voltage. i think i have contributed a small amount to understanding how chargers work and how to maintain them. i even know how that one is gonna fail, but you will find out when it happens so why spoil the fun?
if you can get a battery to 240V then maybe worry about the plug but most people use better connectors anyway.
Post by Arvicola Terrestris » May 04 2014 11:42am
dnmun wrote:maybe this is the first charger you ever owned. all the charger fans are noisy. except maybe the headway charger but it is on 3.3A anyway. by screw i assume you mean the trimpot labeled R15A? it most probably is used to set the final charger voltage. i think i have contributed a small amount to understanding how chargers work and how to maintain them. i even know how that one is gonna fail, but you will find out when it happens so why spoil the fun?
It's my charger number something between 10 or 20, because I'm newbie in here doesn't mean it's my first everything. Or maybe it's my English?
And since the fan is a regular 12V fan found in many different appliances (that don't make so much noise) I just want to replace it with a fan with ball bearings I have in my box with spare parts, that is not so noisy, perhaps mine is just a faulty one.
About the plug in the picture above, its the plug for the wall, not the battery, so there is constant 220V on it.
Yes you have contributed a lot on this forum, that's why I hoped someone like you would contribute, so thanks for the trimpot info, I had it suspected for that function. Just sad you put a meaning in my posts that isn't there, and then try to punish me by:
"i even know how that one is gonna fail, but you will find out when it happens so why spoil the fun?"
wow!? how old are you?
/Philip
dnmun   100 GW
Post by dnmun » May 04 2014 11:45am
i am 68. how old are you?
Post by Arvicola Terrestris » May 04 2014 12:05pm
:) didn't think you would answer that one :)
I'm 37, nice start we had here ;)
I think we should use our energy one something more rewarding.
/Philip
Takemehome   1 kW
Post by Takemehome » May 04 2014 10:34pm
WOW, they're getting better.
The trimpot R15 is an improvement ( voltage adjust.)
If it fails, odds are 50/50, don't panic it's very easy to fix.
Ask dnmun :lol:
Don't dream your life, live your dream.
Don't buy anything before visiting http://ebikes.ca
Justin, Thank you.
mateusleo   1 kW
Post by mateusleo » May 07 2014 12:44am
/Philip
The counterpart on the battery is dangerous if you short circuit the poles, else, if you touch it, nothing will happen. I installed a cutout that opens with 25 or 30A (I don't remember exactly) to avoid short circuit damages.
About the fuse, I didn't pay attention on the words on it, all I did was check if the wire inside both were about same thickness, so I replaced it.
Ps: some member that can translate the Chinese text for us will eventually show up, there are a few the forum
Post by Arvicola Terrestris » May 07 2014 5:23am
mateusleo wrote:I also have one of those but i'm pretty happy with it, the connector to the battery is C15 :
I found this almost identical charger on ebay, but it has both 110V and 220V by a switch.
http://www.ebay.com/itm/110V-220V-outpo ... 1c3f9756bb
/Philip
mateusleo   1 kW
Post by mateusleo » May 07 2014 7:08am
/Philip
Thanks, but the outlet isn't so far, i prefer to keep the 220 than buying new one, saves money :D. I'd change to 110 if it was possible to do changing something inside the charger
Pete1961   10 W
Post by Pete1961 » Jun 19 2014 4:54am
Is this a constant current charger? I am looking for 36V Nominal @ 5A CC, the variable voltage pot would be ideal as I am looking for 43.1V max, can the CV trickle charge be disabled? as this is not wanted
imorton   1 kW
Post by imorton » Jun 19 2014 6:22am
For the life of me, I'm really interested in finding out the PROPER PROCEDURE for using this charger.
1) Do I plug it to the battery FIRST, than plug it into the wall plug AC current?
2) Or do I plug the charger into the wall (AC plug) FIRST, than plug the charger output into the battery?
I would really appreciate anyone who knows the technical operation details about these chargers to let me know, I would be really grateful… :)
IAN.
IAN from http://www.all-about-houseboats.com
GIO 500w scooter, LifePo4 48v 15Ah, WattsUp meter,
cal3thousand   1.21 GW
1.21 GW
Post by cal3thousand » Jun 19 2014 10:13am
I've always plugged my chargers into the wall first. I have been told that you want the CV stage to power up before attaching a battery.
Get a Cycle Analyst and a Multimeter, you're still a noob if you don't have at least one of each.
Planning on posting questions or buying anything on this site? Put up your country (at minimum) on your profile. This is a worldwide forum and we haven't reached clairvoyance.
bigsi   10 W
Post by bigsi » Jun 19 2014 3:14pm
Dumun strikes again haha.
specialized s-works enduro carbon running 18FET Lyen. crystalyte 5304v3 running 105v 15ah....
I build quick release custom batteries to any size and shape. Including custom installs.
imorton   1 kW
Post by imorton » Jun 19 2014 4:08pm
cal3thousand wrote:I've always plugged my chargers into the wall first. I have been told that you want the CV stage to power up before attaching a battery.
I wonder if it is the "lower voltage" chargers that don't need to be plugged into the wall first. The reason being, I had a Currie Ezip E-750 scooter (24 volts), and the instructions on that charger said to plug it into the battery first, than into the wall.
leffex   100 W
Post by leffex » Jun 20 2014 4:12am
I have one.
Used for 3-4 times now. Silent in comparisson to other chargers (BC168).
84.5V 5A output. It will charge from 20s pack from 3.75v each cell to 4.17v in about one hour or 50 minutes. 80% charge in about 20-25minutes.
I have the v3, or veibao.
weight less than a kg or less than 2lbs
i changed the connectors to non-spark type 8mm
Salestech in an ebike store
mateusleo   1 kW
Post by mateusleo » Jun 20 2014 7:29am
I've been using mine (48v 5a) for about a year and a half, no problems so far.
imorton   1 kW
Post by imorton » Jun 20 2014 7:36am
mateusleo wrote:I've been using mine (48v 5a) for about a year and a half, no problems so far.
And do you plug the charger in the WALL first, or do you connect it to the BATTERY first?
mateusleo   1 kW
Post by mateusleo » Jun 20 2014 8:27am
I bought a pre built bike with sla`s and I was instructed to plug to the wall first. So, when I upgraded to lifepo4 I kept the same habit, first I plug to the wall then I plug to the battery. When it's fully charged and balanced, I unplug of the battery first and off the wall later.
imorton   1 kW
Post by imorton » Jun 20 2014 9:15am
Thanks for the info. I wonder how other people use these chargers?
Do they plug wall first, or plug battery first?
leffex   100 W
Post by leffex » Aug 03 2014 4:15pm
Used mine for 2 months going strong. I just made an order of 4 chargers, 3x20s 84v and one 87v lifepo but i will use to my 21s li pack at 4.14per cell.
Manuel001   1 µW
Post by Manuel001 » Sep 01 2014 11:16am
I have also that charger. But my one does not have the potentiometer R15a. Can anyone make a photo from backside of print, please?
What value does have the potentiometer?
Thanks?
