nukezero
I just got a charger off eBay for 13s 48v li-ion cylindricals. The seller (victor studios) told me it was 54.6v output but the charger back label is telling me that it is 55V output 2.0A. I'm not sure if it is just rounding up or not.
But anyways, I wonder if it will be safe for use with Samsung 13s (18650-25Rs) which are rated at 4.2V fully charged = 4.2V x 13 = 54.6V. I mean, I wonder if that extra 0.4V overcharge could screw things up...
here's the charger: http://www.ebay.com/itm/Universal-Smart-2A-Charger-for-48V-13S-Li-ion-Lithium-Polymer-Battery-Pack-NEW-/300941980639?pt=Battery_Chargers&hash=item46118a33df
About Universal Smart 2A Charger for 48V(13S) Li-ion Lithium Polymer Battery Pack-New:
Describe
Intelligent charger designed for 48V (13 cells) Li-Ion Battery packs including Polymer Li-Ion and Cylindrical Li-Ion.
Worldwide input AC power from 100V - 240VAC.
Charging Current: 2000 mA (2.0 A).
Charging time = ( Ah rate of the pack x 1.5 ) / 2A charging current.
Built in IC to cut off power automatically when battery is fully charge.
Red LED show Battery charging and Green LED shows full.
one LED is always Green (battery symbol) indicate has AC power (also fan is running).
the LED with Sine wave symbol will turn RED indicating charging battery (Green = battery is fully charged).
Charging terminal : Standard Male DC Barrel Connecotr(OD: 5.5mm, ID: 2.1mm).
Dimension (LxWxH): 6.0"(152mm) x 2.5"(64mm) x 1.8"(46mm).
Weight: 14 OZ (392 grams).
Size: 6" x 3.3" x 2"
Net Weight: 16.00 oz
Describe
