Turnigy Multistar - lightweight 10C cells
wesnewell   100 GW
Re: Turnigy Multistar - lightweight 10C cells
Post by wesnewell » Aug 16 2015 2:59am
They have their 10ah 4s packs on sale for half price, $30 each now. I ordered 6 of them. That's 20 cents per wh.
Need Advice? https://endless-sphere.com/forums/viewt ... =3&t=66302
Mongoose 26" Ledge 2.1 mtb bike $99, yescomusa.com 48V 1000W rear hub kit $200, Hua Tong 72V 40A controller $35, 10ah 24s lipo $217=~43mph, range=45 miles @ 20mph. 25K miles and still going strong.
Huffy Fortress 3.0 with MXUS 3000 4T motor, 24s lipo, 96V 60A controller. Total cost with extras <$700. Top speed ~50mph
My videos https://www.youtube.com/channel/UC0KW4U ... _G2wQhptMg
dirkdiggler   10 kW
Post by dirkdiggler » Aug 19 2015 11:06am
Glad I jumped on that deal. Price is back to $60 each for the 4s 10AH Multistar packs. Save $90 on the three I bought. Mine should be here today. Hope to get some riding time in this weekend and we'll find out how they do.
dirkdiggler   10 kW
Post by dirkdiggler » Aug 19 2015 10:42pm
I can't believe the size of these things! Wow. They are heavy, but I will have double the AH in the same space as before. they are a bit wider and longer than the 4s 5ah hardpacks, but not by much. Hopefully they will function well enough. I only need to have about 8ah for my rides, so hoping they will provide enough amps. I'll miss not having to use a wiring harness, but the HXT plugs have scared me a few times as it is too easy to plug the batteries into each other. The XT90 plugs seems bomber too.
leffex   100 W
Post by leffex » Aug 27 2015 3:12am
This gotta be a steal 20s1p for 155 dollars or full 24s1p almost 1kw for 172 dollars! :lol:
I will try these goodies out soon in the hope that they will manage the load and ampacity I need.
They also just got out of surgery for new 4mm zombiebullets from a carnaged chargeplate. LOOKING all Green allright!
Whoooooottaaaaa new range from a 21s4.8ah(200cycles ), 20s4.2ah(750 cycles hardcases) And the new 20s10ah(0cycles) will be hardcore mode 30km/ mediumhardnormal mode 45km and superrange 60km 8)
Salestech in an ebike store
darth_elevator   100 W
Post by darth_elevator » Aug 27 2015 3:00pm
dirkdiggler wrote:I can't believe the size of these things! Wow. .... double the AH in the same space as before.
I'm having the same reaction. If I had ordered that many, I could fit 12 batteries (40Ah) in my saddlebag, with room to spare.
I will be able to replace the 10Ah of hardcases that are mounted on my frame with 20Ah of these multistars, assuming I can adequately pad them.
Has anyone else mounted these on their frame? If so, how are you padding them to give adequate protection? I wrap my hardcases in quarter-inch flexible foam, but I'm not sure that's adequate for these soft packs. I was wondering if I should build some sort of improvised hard cases for them out of hard plastic or formica or something. Any ideas?
"The price of bicycle freedom is eternal pedaling." -- Thomas Jefferson
"The only thing bicyclists have to fear is fear itself. And also getting hit by a car." -- Franklin Roosevelt
"Ask not what your bicycle can do for you, ask what you can do for your bicycle." --John F. Kennedy
"I never met a bicyclist I didn't like." -- Will Rogers
Alan B   100 GW
Post by Alan B » Aug 27 2015 4:50pm
I use coroplast, but the Borg frame has flat flanges to mount to, making it a lot easier. Photos in my CroBorg thread from early in this year. 18S pack went from 20AH to 32AH in the available space (slightly more of the available volume was consumed). Amazing.
Post by darth_elevator » Aug 27 2015 5:07pm
Alan B wrote:Photos in my CroBorg thread from early in this year.
Found it, thanks!
https://endless-sphere.com/forums/viewt ... st#p605594
Where do you get your coroplast?
Alan B   100 GW
Post by Alan B » Aug 27 2015 5:30pm
Tap Plastics, or any sign maker should have it.
Post by darth_elevator » Aug 27 2015 5:43pm
Thank you very much!
bionicdan   1 kW
Post by bionicdan » Sep 23 2015 2:54pm
Has anyone else had puffers yet? The one I got with the low cell finally puffed up while I was out and hadnt touched it for 2 weeks. My mum said there was a funny noise in the shed.... doh. Did I just nearly burn my mums shed down? Was only at 3.85v never went below 3.3v never over 4.2v and cycled 20-30 times.
GEARS? Where we're going we dont need gears!
Due to metal plates and a body full of nuts and bolts I am as bionic as my bike. Mxus 4t 120v toshiba fets and 16ah 24s nanotech.
Post by darth_elevator » Sep 23 2015 4:19pm
bionicdan wrote:Has anyone else had puffers yet?
Knock on wood, no puffers yet. But I've only taken them on a couple hard rides so far. None of the six had any low cells when I first got them, so maybe I got lucky.
wesnewell   100 GW
Post by wesnewell » Sep 24 2015 4:16am
No puffers here, but I haven't even used them yet. Just got the bms for them and haven't got a 24s charger yet. I'm going to cut off the XT90's and replace them with 4mm bullets before I wire them to the bms. I did just depuff a 3+ year old 4s hardcase pack and its held up good for a couple of cycles.
jkbrigman   10 kW
Post by jkbrigman » Sep 24 2015 9:58am
wesnewell wrote:No puffers here, but I haven't even used them yet. Just got the bms for them and haven't got a 24s charger yet. I'm going to cut off the XT90's and replace them with 4mm bullets before I wire them to the bms. I did just depuff a 3+ year old 4s hardcase pack and its held up good for a couple of cycles.
Hey Wes, can you give some more details? What does "depuff" mean and how did you do it? I have some turnigy 6s's that are trying to puff just a little.
Also: what's your BMS? I bought a BMS and am considering adding it to my LiPo....it would be so nice to ever only have to bulk charge....
eRecumbent. 9C 2810, 6-FET,CA,18S3P LiPo, Kenda Kwest. 33mph max 12.8Wh/mi (22mph avg) Phat Bike Commuter HS3540, 6-FET, 18S3P LiPo, Schwalbe Marathon 47mph max 25 Wh/mi (28mph avg) Basic LiPo Charging Thread , Add Throttle to Multispeed Bike
dogman: "I bet if you just don't ride like a jerk, you can do whatever you want up to the speed where everybody looks at you like this. :shock: "
tomjasz: "Romans go full dork. They could give a hoot what 'Merkins do."
Post by darth_elevator » Sep 24 2015 11:28am
jkbrigman wrote:Also: what's your BMS? I bought a BMS and am considering adding it to my LiPo.
Which one did you buy, jkbrigman? (And also interested in knowing which one Wes bought.)
jkbrigman   10 kW
Post by jkbrigman » Sep 24 2015 12:06pm
This one:
http://bestechpower.com/222v6spcmbmspcb ... -D163.html
I'm thinking about pairing it with Turnigy Multistars. But I'm worried about pack puffing.
wesnewell   100 GW
Post by wesnewell » Sep 24 2015 12:10pm
Depuff means I took a small straight pin and very carefully poked a hole in the foil punches to squeeze most of the air out of them and then took some packing tape and closed the hole. When I was going to check capacity, one cell went to 3.0V before the others, which were up to one at 3.56V. Not wanting to take the time to get them all to 3.0V I then charged it and it took 4369 mah. The pack was reading 3% soc before charging, so it wasn't really empty yet. Since I never checked capacity when they were new, I don't know how much, if any capacity is lost in the 3+ year old packs, but I figure it's about 90% now. This pack was the worst balanced of the 13 I bought new and it had puffed so bad it cracked both side of the plastic case. I was surprised when I got the pouches out that they were pretty uniform in their puffing and it was a combination of them all puffing that cracked the case.
jkbrigman   10 kW
Post by jkbrigman » Sep 24 2015 12:20pm
wesnewell wrote:Depuff means I took a small straight pin and very carefully poked a hole in the foil punches to squeeze most of the air out of them and then took some packing tape and closed the hole.
Thanks Wes! I'll give it a try on mine. They really aren't very bad, but I'd like to try "depuffing" to help me maintain performance of the pack.
wesnewell   100 GW
Post by wesnewell » Sep 24 2015 1:02pm
Well, I'm kind of reckless, just be aware that if you stick that needle in to far the pouch could ignite on you. So be very very very careful not to do that. I just happened to have a straight pin handy. Something sharp and non conductive would be a lot safer.
jkbrigman   10 kW
Post by jkbrigman » Sep 24 2015 1:14pm
wesnewell wrote:Well, I'm kind of reckless, just be aware that if you stick that needle in to far the pouch could ignite on you. So be very very very careful not to do that. I just happened to have a straight pin handy. Something sharp and non conductive would be a lot safer.
Agreed. I regard this operation as being extremely dangerous. I have some spare cinder blocks I am using to make a small platform and do the work on that platform.
I was going to angle the pin as parallel-to-the-wall of the cell as possible to keep it away from the battery internals. Does the location of the pin prick matter?
Post by darth_elevator » Sep 24 2015 2:39pm
DAND214   1 GW
1 GW
Location: About 1200 miles south of Chicago, in sunny/rainny Port Richey, Florida!
Post by DAND214 » Sep 24 2015 10:16pm
I did my puffers at the top along the side under the fold. Pinned it almost at the top and hot glued it shut folding over the flap. No more puffer or any leakage. that is on the Turnigy 6s 20c packs or 4s hardpacks. Not my Multistars.
I sure wouldn't think you could draw enough amps with a 6 fet that would hut the Multistars.
Dan
wesnewell   100 GW
Post by wesnewell » Sep 25 2015 1:37am
jkbrigman wrote:Agreed. I regard this operation as being extremely dangerous. I have some spare cinder blocks I am using to make a small platform and do the work on that platform.
I did the outside cells in on the flat sides and the inside cells on the edges. I tried to puff the section here I was going to poke first by squeezing the cell in other places.
jkbrigman   10 kW
Post by jkbrigman » Sep 25 2015 7:51am
Thanks!
It's going to be awhile before I integrate the BMS: I have to effect repairs to my existing packs, and I'm considering some Multistars.
But installing it is on the to-do list and I'll report back. I have two Meanwell LED supplies, the 340 watt ones and I'm eager to make them my primary chargers. They work great with no BMS and the current ramps down REEELY nicely (Alan B has threads on this) but I think a BMS might give the benefit of shutting off at the right spot.
I'll report back, because this topic is not without debate. Some feel a BMS on LiPo is just asking for trouble out on the road. I'm looking to see if that opinion is more important than protecting the pack.
jkbrigman   10 kW
Post by jkbrigman » Sep 25 2015 7:53am
wesnewell wrote:
jkbrigman wrote:Agreed. Does the location of the pin prick matter?
DAND214 wrote:I did my puffers at the top along the side under the fold. Pinned it almost at the top and hot glued it shut folding over the flap. No more puffer or any leakage. that is on the Turnigy 6s 20c packs or 4s hardpacks. Not my Multistars. I sure wouldn't think you could draw enough amps with a 6 fet that would hut the Multistars.
Dan
This is great information gents. I'll follow up later with what I end up doing.
Wheazel   10 kW
Post by Wheazel » Sep 25 2015 8:41am
I was thinking of maybe ordering a pair of these 20Ah 6s packs from HK europe to test. As they are in sock as of now.
However, the price is about 129Euro if you get the discount by waiting for the popup. (143Euro otherwise)
So that means 260Euro for 12s20Ah, pretty nice... But the 18650 29E cell can be bough from nkon for around 2,5Euro each for numbers that match the capacity.
Apart from the extra work of building the 18650 pack, you actually match the cost of these lipos in this case.
I imagine the packs would behave similarly under load, but most likely a higher capacity with for example 12s8p 29E cells. (96cells)
With my prior experiences of HK lipo cells suddenly going dead or arriving half-dead, I didnt bite this time.
