Turnigy Multistar - lightweight 10C cells
brumbrum   100 kW
Re: Turnigy Multistar - lightweight 10C cells
Post by brumbrum » Sep 27 2015 1:37pm
edited, for giving out wrong information.
My NYX and cromotor build
viewtopic.php?f=6&t=74615
My LMX 161 dirt bike build
viewtopic.php?f=6&t=94074
bionicdan   1 kW
Post by bionicdan » Sep 29 2015 11:07am
Getting 2x20ah 4s and 1x20ah 6s delivered tomorrow. This will be my perfect pack with a mix of size, weight and capacity I think. Hopefully no self dischargers this time. Let me know if you need any measurements of size as they have mucked up the orientation of the dimensions I think/hope.
GEARS? Where we're going we dont need gears!
Due to metal plates and a body full of nuts and bolts I am as bionic as my bike. Mxus 4t 120v toshiba fets and 16ah 24s nanotech.
johnamon   10 W
Post by johnamon » Sep 29 2015 3:05pm
bionicdan wrote:Getting 2x20ah 4s and 1x20ah 6s delivered tomorrow. This will be my perfect pack with a mix of size, weight and capacity I think. Hopefully no self dischargers this time. Let me know if you need any measurements of size as they have mucked up the orientation of the dimensions I think/hope.
Please post a few photos of everything in one shot with a reference item (tin of Coke is a good example as it's a similar shape)..... and width, height, lengths. Thanks!
bionicdan   1 kW
Post by bionicdan » Sep 29 2015 4:27pm
will do.
hopefully its gonna fill this bag woo :)
DAND214   1 GW
1 GW
Location: About 1200 miles south of Chicago, in sunny/rainny Port Richey, Florida!
Post by DAND214 » Sep 29 2015 10:57pm
Are those prices correct? $130 for a 4s and only 136 for the 6s. Oh and They are now 1p, even better. Wish I waited a few months now.
Dan
bionicdan   1 kW
20000mah pack sizes
Post by bionicdan » Sep 30 2015 4:59am
says 127 and 109 usd on international warehouse on the 1 time offer :)
Anyway heres some pics. Of course I have the obligatory self discharging cells every time I order two packs at the same time as if i wont mind or something as I have two the same.
They are 1-2mm smaller than stated all round making them 142x88x197mm HxWxL when stacked up. NO MORE BASHING MY LEGS WOOO
The plastic wrap means the cells lay on the flats not the ends as it is with all the other ones I have. Not sure how that debate went about damage being easier one way or the other?
I used under 9.5ah on my first ride and they went down to 3.81v resting.
johnamon   10 W
Post by johnamon » Oct 06 2015 2:16pm
good to see that someone else's decorative glass table is their 'hobby table' :lol:
bionicdan   1 kW
Post by bionicdan » Oct 06 2015 2:30pm
well its fire resistant he he. Actually its my mums house. I was just showing off cool stuff to my brother who is only 19. His mates all came out to watch me zoom off at 37mph lol
le15otl   100 W
Post by le15otl » Nov 05 2015 4:54pm
If the 10C cells are really best used at 2.5C (or 4C with the 16ah's), do you think this 2C rated multistar will be only good at 0.5C or something lower? Or is it probably rated more honestly? I can't find any reviews or testing info on the 2-3C ones
http://www.hobbyking.co.uk/hobbyking/st ... h=12000mah
To be safe I bought some 20ah 10C's which are great
miuan   10 kW
Post by miuan » Nov 24 2015 9:11am
The 20C will serve you well at 1-1.5C continuous or 3C peak.
I have used my 10Ah Multistars with a 60A controller and after 4 months use the cells' capacity starts to diverge.
They will still hold top balance but became very inconsistent on bottom end, requiring a much higher LVC.
I need to retire the cells and return to my 2yr old Zippies which are much higher C and still keep perfect balance top and bottom. They are a lot heavier though.
pucksterpete   1 kW
Post by pucksterpete » Nov 24 2015 2:42pm
miuan wrote:The 20C will serve you well at 1-1.5C continuous or 3C peak.
Okay, What voltage are you running and how many in parallel?
Optim Alp Hardtail with MXUS Motor
20S 2P Turnigy 5.0 Hard Case
Top speed 38mph tops :)
Hyena Special
http://endless-sphere.com/forums/viewto ... 97#p585997
Excelsior/Strong GTS with Cromotor
24S 3P Turnigy 5.0 Hard Case
Top speed so far 53mph
http://endless-sphere.com/forums/viewto ... =6&t=46993
miuan   10 kW
Post by miuan » Nov 25 2015 2:15am
20S1P
icecube57   1 GW
1 GW
Post by icecube57 » Nov 25 2015 9:11pm
After a year on the 10AH packs i saw a 5-8% loss of capacity in the packs. But i was running them in 4P and only using 25-30A on a BBS02
danielrlee   1 kW
Post by danielrlee » Nov 26 2015 2:56am
icecube57 wrote:After a year on the 10AH packs i saw a 5-8% loss of capacity in the packs. But i was running them in 4P and only using 25-30A on a BBS02
That's somewhat disappointing for running at less than 1C. May I ask your typical charge/storage voltage?
https://TorqueTech.co.uk : Electric bike spares, parts & accessories : 10% discount code ’ENDLESS10
icecube57   1 GW
1 GW
Post by icecube57 » Nov 26 2015 7:30am
I charged before rides and left them at a half discharge state. Until used again which could be a day or two or a week later. The loss is quite respectable compared to other cells like zippy 8AH which went from 8 down to 7.2 to 7.5AH after a season
Routybouty   100 W
Post by Routybouty » Nov 29 2015 5:22pm
How are everyones Multistars holding up? I'm thinking about getting 10x 16Ah 4s for my Vector. They are priced at $79.64 (and actually in stock), has anyone seen them for a lower price? I'm trying to figure out if I should wait or just pull the trigger. I currently have 25Ah of the 5Ah hardcases. I want a lighter battery though. This will cut my weight in half with 16Ah loaded in, then if I decide I'm going for a long trip, I can pop in the other packs for 32Ah. Or maybe I'll just keep all 32Ah in there all the time, it still comes out a pound or two lighter and waaaay less spaghetti wiring .
Waiting for that perfect ebike.
icecube57   1 GW
1 GW
Post by icecube57 » Nov 30 2015 9:17am
Im running 66v 32AH on a Mxus 4T. They are running great. Never need balancing. Always within 0.01v of each other. Excellent performance. I havent did any capacity loss checks lately.. mainly cause Im not pushing them to empty every time because its a huge pack. I charge mine when I need it. Leave it discharged until the next ride. I store them in a cool area. the 16AH are 2p. meaning two cells are in parallel so they have a lower IR and can put out more power with less voltage sag. These are ok to 4-5C I haven test the 20AH but the reports are they are 1p. Normally larger AH cells have a lower IR too but I tested the 10AH cells which are 1P and they were only good to 2.5C so I transfer those same specs to the 20AH. So i suspect the 20Ah are only good for 2.5C as well.
pucksterpete   1 kW
Post by pucksterpete » Dec 07 2015 3:30am
So what does it mean when there is a line marked through the Back Order button on HK's site?
Is it that their out of stock and they are discontinuing the product?
Looks that way for some of the 5.2 Multistar batteries
lets hope not
Here is HK Response
Code: Select all
Marnelie11:18:59 AM
Yes, the back order item with no line that means that you just need to wait the restocking of 30 days but the back order item with line, we are not sure when will the item it will back on stock.
claire11:19:52 AM
Hyena Special
le15otl   100 W
Post by le15otl » Dec 07 2015 5:58am
Doesn't mean it's necessarily discontinued but don't expect it to be restocked within 30 days. There has been something with the same line that was in backorder for almost a year :(
okp   100 kW
Post by okp » Dec 17 2015 1:54pm
got four of these 6S 5200mAH 10C... I put two of them in series to make it 12S.
I drew maximum 29A peak; riding smoothly on my E-MTB. I have 3 sessions with them. At this time, even charged and balanced at 95% with a Hyperion Duo charger (i.e top notch charger), I had a beep warning on one of these pack saying that the voltage of one cell was too low.
So at this time, and even with a gentle and smooth use... I don't recommend getting these packs... even if you draw less than 30A peak... which is really not much (but usual on 12S).
icecube57   1 GW
1 GW
Post by icecube57 » Dec 17 2015 3:05pm
It seems that the smaller the pack I guess the worst sag there is. If you did 12s 2s 2P. You in theory were barely able to squeak by and stay under the suggested 2.5-3C threshold. I have a friend that was about to buy a crap load of these but in the 4s version. Glad you posted your experience. Typically with larger format cells the IR is better and they can take more abuse but these smaller packs the IR must be high for them to perform so poorly. But they should still give capacity. These packs maybe good if you use them to get the AH and pair it with a nanotech to help prop up the C rating.
It is possible with your three sessions that you might have over discharged one pack and it went into reversal. Also when you get these packs a good balancing session and discharge test for capacity is always in order with anything from hobby king. Its quite possible you have a pack with a dud cell that performs poorly doesnt give capacity and is probably self discharging to a certain extent 3 rides on a 10Ah pack is a tall order. Not sure if you have a cycle analyst and was tracking AH. But if you never initially check the packs for capacity who is to say you have a 10AH pack. That one bad cell could not be giving capacity and you went to discharge 10AH but there was only 8.5-9 Ah available and you couldn't tell you were over discharging it. So many scenarios run through my mind but the info you gave us is incomplete.
Offroader   10 MW
Post by Offroader » Jan 26 2016 3:19am
They are selling those multistar 4s 16,000 packs for $55 dollars now. That is really cheap.
http://www.hobbyking.com/hobbyking/stor ... ouse_.html
Too bad I've decided to switch over to 18650 cells.
cwah   10 GW
Post by cwah » Jan 26 2016 4:06am
If you can only pull 3C max.... why don't you just get the ncr18650pf? They also pull 3c max and are lighter too!
Offroader   10 MW
Post by Offroader » Jan 26 2016 11:44am
cwah wrote:If you can only pull 3C max.... why don't you just get the ncr18650pf? They also pull 3c max and are lighter too!
I went with the Sanyo NCR18650GA 3500 cells actually. In comparison they are lighter and you can get more capacity.
Only drawback is you have to run the volts down to 3.3 volts to get the capacity out of them compared to lipo at like 3.7 volts.
What i like about cells over packs is that i can maximize my battery space better with cells. Which is exactly what I need to do with my new Qulbix Q76R frame which is 76mm wide and very thin. I plan on fitting a 3000KW pack into it and using the complete frame opening for a removable pack.
There is no way I can do this with packs like the mutistars.
The other benefit I heard is that 18650 cells like the Sanyo they say have a much greater cycle life, even as much as double. If that is true then cells could be the better value.
But it is hard to compete when they sell these multistars discounted like this.
Hillhater   100 GW
Post by Hillhater » Mar 03 2016 6:52pm
Attention Aussies !!!
HK seem to be clearing out stocks on the Multistars locally ( global whs is nearly all back order on these already ?)
...but they are cutting the prices regularly to really low levels ..so check regularly if you need some cheap , high capacity Lipo .
I wonder if they have something new in the pipeline to replace them ?
