Multistar High Capacity 6S 16000mAh
Emoto   10 kW
Post by Emoto » Sep 04 2014 11:25am
This is big MAH :shock: not having to parallel multiple pacs means cleaner wiring lets hope for a higher c rante in the future.
http://www.hobbyking.com/hobbyking/stor ... ouse_.html
RLT   10 kW
Re: Multistar High Capacity 6S 16000mAh
Post by RLT » Sep 04 2014 1:38pm
Interesting.
The highest AH they offer on the US site is 10, and they are backordered
I might be tempted to try (4X) 5S, if they had them, or maybe even (5X) 4S.
teslanv   100 MW
Post by teslanv » Sep 04 2014 1:44pm
Pricing not bad, either. That's only $0.366 per watt-hour !!!
DD Hubs, Batteries, Controllers & Custom Ebikes.
http://westcoastelectrics.com
West Coast Electric Cycles
Bellevue, WA
USA
Punx0r   100 GW
Post by Punx0r » Sep 04 2014 2:05pm
Interesting.
Looking at the pattern in the heatshrink it looks like a bunch of paralleled cells inside the pack, but hopefully they are at least somewhat matched when assembled. That would offer an advantage over parallel separate packs.
dogman dan   100 GW
Post by dogman dan » Sep 04 2014 4:15pm
Or, the beauty of the 4s pack, is only 4 pouches if you have to chuck one.
Russell   10 MW
Post by Russell » Sep 04 2014 4:23pm
Emoto wrote:This is big MAH :shock: not having to parallel multiple pacs means cleaner wiring lets hope for a higher c rante in the future.
Already out of supply and on backorder :(
-R
Jeep Comanche Trekking Bike w/YOUE geared motor, 42 lbs + 15 lb rear trunk bag w/12S 16Ah LiPo battery, tools, etc., 21A controller, 700 x 40C tires. 27 MPH.
My other E-Bikes: Nashbar Steel Flatbar
teslanv   100 MW
Post by teslanv » Sep 04 2014 4:37pm
dogman wrote:Or, the beauty of the 4s pack, is only 4 pouches if you have to chuck one.
Great point, Dogman. I just nuked a 4S pack last night. Was a "dammit" moment for me, but with a 6S 16Ah pack, it would be an "Oh, F@#*!? Moment. :wink:
Bellevue, WA
USA
dogman dan   100 GW
Post by dogman dan » Sep 05 2014 5:37am
Mostly I was just thinking of the probability of one pouch puffing right out of the box.
It's a dilemma, less wiring would be nice, but only if they do a better QC before assembly.
I've often wished you could buy a 2s 4p pack. that would be 8 cells per pack, 7 to get 14s 20 ah. You'd cut off the 3 pin balance plugs and replace with two 8 pin plugs.
If one went bad, you would be tossing the same number of cells of two 4s packs.
babyhughie   100 W
Post by babyhughie » Sep 08 2014 3:32am
These packs are badass I will be holding out n waiting until they get stock in... 18s1p for 16ah makes me happy :-). The only thing I don't like is the XT-90 connectors.. Is it possible to series connect them without adapters? I am not familiar with the XT-90 connectors they look kind of funky..
neptronix   100 GW
Post by neptronix » Sep 08 2014 3:53am
icecube57 had great results with the 10AH packs. I'm crossing my fingers that these will get stocked in the USA warehouse.
You could make an average sized ebike pack by just hooking up a series harness.. i'm droolin'
neptronix   100 GW
Post by neptronix » Sep 08 2014 4:02am
If you calculated these based on whrs/kg with a 3.8v nominal voltage, they'd come out to 190whrs/kg.
Just a hair below the 10AH packs, which may mean that there's extra weight from cell interconnections or whatnot.
Dude, a 12S 16AH pack comes in at 8.5lbs.
nechaus   1 MW
Post by nechaus » Sep 08 2014 6:24am
dammit hobbyking take my damm money, i need 16 ah cells
Hillhater   100 GW
Post by Hillhater » Sep 08 2014 5:52pm
nechaus wrote:dammit hobbyking take my damm money, i need 16 ah cells
...but they are only 8 Ahr cells ! .....arranged 6s, 2p into the pack :wink:
nechaus   1 MW
Post by nechaus » Sep 08 2014 5:59pm
ooooooooooooooh
bugger that then, I have about 80 of the 8000mah cell
looking at that top pic, looks like you can see heaps of cells inside..
neptronix   100 GW
Post by neptronix » Sep 09 2014 1:34pm
Wow, another company selling the same high density cell. I wonder if they come out of the same factory, or shit just gets copied so fast in China...
Hillhater   100 GW
Post by Hillhater » Sep 09 2014 6:08pm
neptronix wrote:Wow, another company selling the same high density cell. I wonder if they come out of the same factory, or shit just gets copied so fast in China...
That pack states 6S, 1P, and actually looks to only have 6 cells, 15 - 30 C and $300 !!
.......so it's not the same as the Multistar .
botz244   10 W
Post by botz244 » Sep 10 2014 4:50am
in down for 6 packs for 18s2p -32 ah oh ya for 2200.00 no problem. for 25 lbs heck ya
Emoto   10 kW
Post by Emoto » Sep 10 2014 10:08am
Punx0r wrote:Interesting.
Well spotted Punx0r but we wont know for sure until someone gets some.
neptronix wrote:icecube57 had great results with the 10AH packs. I'm crossing my fingers that these will get stocked in the USA warehouse.
These have landed in aus now ill guess the states is next :D the other thing is far less balance leads dangling around so a safer pack.
ambroseliao   100 kW
Post by ambroseliao » Sep 10 2014 11:40am
Not to change the subject, but I just spotted this 6S 22000mAh LiPO battery on alibaba...
http://www.alibaba.com/product-detail/c ... 87073.html
http://www.ebikes.ca/ is the best!
TidalForce M-750X, Tidalforce S-750 with Crystalyte HS3540, 1x TF iO-X Cruiser. E+ 1000W hybrid bike. ebikes.ca DrainBrain & Cycle Analyst meters. GoPro HD Hero2 camera. Bosch Fat Packs, 37V 10Ah LiPO pack. Turnigy Multistar batteries
My blog: http://ebikerider.blogspot.com
Remember LiFEPo4 HVC is 3.65V and LVC is 2.7V
TheBeastie   10 MW
Post by TheBeastie » Sep 10 2014 12:23pm
ambroseliao wrote:Not to change the subject, but I just spotted this 6S 22000mAh LiPO battery on alibaba...
When I try to evaluate dubious battery backs especially Zippy packs I prefer to go by weight then their stated Ah, going by weight that pack does seem like a somewhat real deal as its 2.5kilos in weight! Thats a chunky battery!
Speed Kills Range, 10mph = 46 miles range, 20mph = 20 miles, 30mph = 8 miles rangehttps://goo.gl/1JNL53
Over Charging Kills ur battery bit.ly/1hzWKl4
Consider PAS as your only throttle https://goo.gl/Kg1F8F
Fuel-Cell is the ultimate battery coupled with 4th-gen Nuclear
https://goo.gl/TcKtHs https://goo.gl/ZhFFot https://goo.gl/gfa215
10 Square Miles of solar panels = 0.12GW average power! https://goo.gl/Ub1S39
neptronix   100 GW
Post by neptronix » Sep 10 2014 12:35pm
TheBeastie wrote:When I try to evaluate dubious battery backs especially Zippy packs I prefer to go by weight then their stated Ah, going by weight that pack does seem like a somewhat real deal as its 2.5kilos in weight! Thats a chunky battery!
That's a bad way of figuring energy density, because it varies widely across batteries.
Let's do some math for that pack.
22ah x 3.8v nominal x 6 cells = 501.6 watt hours.
501.6 watt hours / 2.518kg = 199 whrs/kg.
If that pack really has that capacity, that's right up there with high end panasonic 18650's, in terms of energy density per weight. But this is some random brand - they could easily be bullshitting us.
Typical 20C lipo, by those same calculations, is 149whrs/kg. Lead acid batteries are something stupid like 33whrs/kg.
toniovelo   10 W
Post by toniovelo » Sep 18 2014 6:19am
Not new review about this big lipo Multistar? The C discharge is true or a bit less? Thanks.
TheBeastie   10 MW
Post by TheBeastie » Sep 18 2014 6:47am
Yeah I meant its the real deal in a very loose was as in its actually 2.5kilos of battery nothing more. When I evaluate zippy I still only go by weight though, buts its the only packs I look at it that way.
Also when looking at things this way is the most important final sum is of Wh/Kg per $
So actually in summary what I meant to actually say is I like to try and evaluate battery by kg/$ for a dubious battery pack like in buying fruit, raw lithium per dollar!
melodious   100 kW
Post by melodious » Sep 18 2014 8:29am
I need to see if these big capacity bricks are sized right for my skateboard. Once they hit the USA sites, I'll grab 1-2 (if the dimensions are appropriate for my build) and buzz around with confidence that I will have enough watt hours to accomplish my goals. :mrgreen:
Surly Ogre rigid 29er, rear 10T MAC @ 50V 25AH & 40A: 30mph road/gravel/hill machine
42" dual diagonal Eskateboard @6s & 90mm wheels
Next: eMTB @10-12s & 8"-12" pneumatic wheels; Got Strapped? d-(',')z
