Synon
So I'm starting to charge 18650 cells that I've scavenged and need some feedback. I purchased a Thunder 1220 charger to use, I set the cell voltage to 4.2 (cells are in the 3.7 range). I put 10 cells in parallel to speed things along and apply only .5 amps, which is what... .05c? However the voltage shoots up when charging to 4.1v, it reaches 4.2v in a few hours and stops but then the voltage immediately drops to 3.75 or 3.8v which I assume is normal since the cells haven't received much energy yet. When you set the voltage on the charger, it stops charging when it first reaches that voltage and not what the cells settle on when the charger is no longer applying voltage. How am I suppose to full charge the cells this way? I think the highest I can set the charger to is 4.3v, am I doing something wrong here? People talk about charging at .5c or slightly less on these cells, would the voltage be closer to 5v when set that high?
