HCX-D167 LiFePO4 BMS strange behavior
rainman_v84   1 µW
Post by rainman_v84 » Apr 12 2015 6:49am
Hi everyone,
I've recently upgraded my LiFePO4 battery to 20s and used an HCX-D167 BMS.
As per supplier instructions, I've first charged the battery through the BMS and then manually balanced each cell to 3.65V.
Then I've made a test run, and found the battery capacity to be twice lower than it should have been.
I've made some measurements and found some strange BMS behavior - if I measure voltages immediately on balance leads, every cell reads as 3.3V.
However if I measure voltages above the balance resistors (see the picture) all the cells read the same 3.3V except 2 cells - 1 reads 3.7V and another reads 2.7V. So, the BMS thinks that the 2.7V cell is drained and shuts the whole battery down.
Also, when I measured the voltage drop on the resistors, there is no drop on them except two - lines 3 and 4 (~0.5V).
Does anyone know how to fix this problem?
agniusm   10 MW
Re: HCX-D167 LiFePO4 BMS strange behavior
Post by agniusm » Apr 13 2015 2:35am
Connect your charger and leave it for 48 hours. Then check back. Measure your cells on balancing connector before and after
rainman_v84   1 µW
Post by rainman_v84 » Apr 26 2015 9:11am
I've tried leaving the battery connected to a charger for 48 hours, and have again obtained an unbalanced battery with weird readings on the same channels that were faulty before.
I have measured the resistance between the leads of all the elements located after the balance resistors and found that 2 elements marked AFTV(1X) have different resistance between their leads.
What kind of elements are those? I could not find them in any database.
