Samsung 30Q INR18650-30Q 3000mah 15a cell
Hillhater   100 GW
Re: Samsung 30Q INR18650-30Q 3000mah 15a cell
Post by Hillhater » Feb 29 2016 8:44pm
hillzofvalp wrote:Anyone willing to cycle the HG2 at 2A charge, 7A discharge?
what are you wanting ?....capacity loss with # of cycles,...
... or just discharge curve? http://www.dampfakkus.de/akkuvergleich. ... u6=577&a=5
Allex   1 GW
1 GW
Post by Allex » Apr 27 2016 8:43am
okashira wrote:
Allex was kind enough to send me four NCR18650GA's... from two different sources to boot. I will start them soon. I will also add more Model S cells.
Okashira, any updates on those cells?
okashira   10 kW
Post by okashira » Apr 27 2016 9:57am
Sorry Allex, had so much going on and redid my work area again (keeps expanding) and have not re-setup the battery tester. I will make time for it this weekend
"Peace out - I'm done."
-- Bernhard Riemann, 1859
edisonmotors.net
Tesla Model S 18650 cells - like new - and custom packs from Tesla cells for sale. Any shape Any power Any capacity.
PM me or search my threads.
Wheazel   10 kW
Post by Wheazel » Apr 28 2016 8:00am
okashira wrote:Sorry Allex, had so much going on and redid my work area again (keeps expanding) and have not re-setup the battery tester. I will make time for it this weekend
Looking forward to read more about that!
youyoung21147   100 mW
Post by youyoung21147 » Jul 28 2016 4:13pm
Hi Okashira !
Any news about NCR18650GA cycling ? Does it exhibit the same self-healing effect as Tesla/18650BE cells ?
To me the results presented in this thread tend to prove the NCR18650GA is not the cell used in the Tesla 90kWh pack, as it seems to be nowhere as robust as BE or PF cells.
okashira   10 kW
Post by okashira » Jul 28 2016 5:46pm
youyoung21147 wrote:Hi Okashira !
No mews sorry. Still need to get setup again.
Yes the GA has silicone in the anode, this is great for energy density, but SiO expands like 300% when intercalated with lithium, so it tends to harm the cycle life...
I am quite sure tesla does use the GA's, cycle life is a non issue for a 90kWh Model S. as the typical cycle for that car is like 20% DoD and it's a massive pack.
edisonmotors.net
Hillhater   100 GW
Post by Hillhater » Jul 28 2016 8:06pm
okashira wrote: I am quite sure tesla does use the GA's, ........
Are you saying they use the GAs in "some" packs ? ...and BEs in others ?
okashira   10 kW
Post by okashira » Jul 28 2016 8:31pm
well.. yeah...
edisonmotors.net
Hillhater   100 GW
Post by Hillhater » Aug 01 2016 11:37pm
Evidence that Tesla have recently taken delivery of cells from Samsung..
http://electrek.co/2016/06/02/tesla-sou ... s-samsung/
But ...they are ICR 18650 22V mostly, (113 Tonnes), and a lesser amount (3.5 Tonnes) of 36G spec cells ??
Trials of 36G cells i can understand, but what would they use the 22V cells for ?
Pajda   1 kW
Post by Pajda » Aug 03 2016 9:31am
Hillhater wrote:Evidence that Tesla have recently taken delivery of cells from Samsung..
It is a little offtopic but my guess is that these Samsung cells are used in a 6.4kWh "standard" Tesla power module (one standard module is used in Powerwall, more in Tesla Energy Powerpacks)
.. Two modules inside seems to me very similar to the Model S module, I have also calculated the same number of 444 cells per basic module. So 6.4kWh divided by 888 cells makes about 7.2Wh per cell and it corresponds to 2000mAh per cell. The known amount of 888 cells makes me perfect sense of a recent delivery of Samsung cells ICR18650-22V to Tesla. This 2200mAh/8Wh cells gives 7.1kWh and so 6.4kWh is 90% DoD.
.. However, someone at Tesla reportedly said that this module is already using new Tesla "21-70" format. But it doesn't make sense for me unless the real capacity of module is about 10kWh. Because it is a nonsense to make "21-70" (I believe that it is only another name for Panasonic standard 20700) with capacity lower than 3000mAh.
okashira   10 kW
Post by okashira » Aug 03 2016 9:46am
Haha. Nah they are std 5.4 kWh model S modules. For the power wall they use 60% DoD so they call it 6kwh or so.
edisonmotors.net
Pajda   1 kW
Post by Pajda » Aug 03 2016 9:51am
I am also curious about the Samsung SDI ICR18650-36G cells. I was not able to find any datasheet but from the code it seems to be a LiCoO2 chemistry, most probably with 4.35V(3.7V nominal) voltage and capacity of 3600mAh. That makes about 13.3Wh and 760Wh/l. But it is still not enough for 100kWh battery with the same modules.
Pajda   1 kW
Post by Pajda » Aug 03 2016 9:56am
okashira wrote:Haha. Nah they are std 5.4 kWh model S modules. For the power wall they use 60% DoD so they call it 6kwh or so.
Hmm.. that seems to be most reasonable explanation :mrgreen:
Hillhater   100 GW
Post by Hillhater » Aug 03 2016 6:02pm
Also Remember, Musk has said there will be some significant upgrades to the Powerwall/Powerpack specifications very soon !
randyc1   100 W
Post by randyc1 » Aug 16 2016 7:04pm
Anyone know where to buy Authentic (SAMSUNG 30Q) at a good price ??...
I know Alibaba has then for around 3.50/cell ??...authentic ??
Gregory   100 kW
Post by Gregory » Aug 16 2016 7:42pm
Sounds too cheap, I'd guess lies. They can be outright fake, advertisement written to deceive buyers, factory rejects or just a good deal. You haven't given much info to go on.
You can buy one and test it.
1) x5305 Hub Motor in a 24" Sun rim with 10G spokes, Kelly 72601 controller, 74V 10Ah Turnigy LiPo 20C Battery and CycleAnalyst
2) Mac 10T rear hub in a 700C "comfort bike" 15S 5Ah LiPo, stock 28A Xie Cheng controller
3) 38" Longboard, Turnigy 6374, CC Mamba XL2 ESC
randyc1   100 W
Post by randyc1 » Aug 16 2016 8:08pm
Was curious if anyone here tested Alibaba Cells here before or if they knew where to buy Authentic cells at a good price ?
Hillhater   100 GW
Post by Hillhater » Aug 16 2016 9:23pm
"Alibarba". Is just a "gateway" to many thousands of Chinese traders...similar to EBay..
Since you dont say who the seller is, your supplier could be any one !
The only way to know if they are genuine, is to buy some (from that exact supplier) and test them.
riba2233   1 MW
Post by riba2233 » Aug 17 2016 1:41am
If it isn't fake, they stated price for xxxxx pieces. Tr asking they, i bet that the price for single cell will be at least $6-8. I think that the nkon is cheapest, but you have to know that this isn't the cheapest cell. You buy it only if you need both high discharge and high capacity. Otherwise you buy samsung 25R for current, or other cells for capacity (29E, 32E, PF, BE, MH1, MJ1, GA...)
My electric moped: http://www.evalbum.com/4966
My electric car: http://www.evalbum.com/5364
randyc1   100 W
Post by randyc1 » Aug 17 2016 9:01pm
Got a Quote back from Alibaba,.(Shenzhen Basen Technology Co., Ltd). They assure me they are 100% Authentic SAMSUNG 30Q cells ?? .
I can pay with Paypal.
3.40 U.S/cell, for 100 cells. +109.00 shipping bt Fedex in 4-6 days....??
PDF Link below if you want a list and prices of all cells
http://f03.s.alicdn.com/kf/HTB1bG9lMVXX ... gue%2B.pdf
What you think???
litespeed   100 kW
Post by litespeed » Aug 17 2016 10:23pm
I think it's a gamble.....I'd start with a few of a couple different ones to check validity. Out side the USA or what ever country your in and nothing including PayPal can save you.
Hope it's legit because those are really good prices on the 30Q, 25R and VCT4 & 5's.
You couldn't go wrong with any of those.
Tom
Gregory   100 kW
Post by Gregory » Aug 17 2016 11:02pm
Prices are very good, can't hurt to try a few out. Basen seems to have OK reviews from a quick Google.
Make inquiries of who is responsible if the item is destroyed by customs. Lots of problems with shipping large Lithium packages these days.
Especially if not properly labelled as HAZMAT.
Also remember if these turn out to not meet spec, shipping back to China will be almost impossible.
Ohbse   10 kW
Post by Ohbse » Aug 17 2016 11:43pm
I have had good experience with "Shenzhen E-fire Technology Development Co.,LTD"
In fact I am just about to purchase 1500 more Samsung 30q's. $3.4usd/cell, $225 shipping to NZ. Sea shipping so can order up to 5k cells for same money.
riba2233   1 MW
Post by riba2233 » Aug 18 2016 12:46am
randyc1 wrote:Got a Quote back from Alibaba,.(Shenzhen Basen Technology Co., Ltd). They assure me they are 100% Authentic SAMSUNG 30Q cells ?? .
What you think???
You could take a risk, but nkon has only slightly higher price:
http://eu.nkon.nl/rechargeable/18650-si ... 00mah.html
"Buy 100 times for €4.15 (€3.43 without VAT)" (you will be charged without vat)
And probably cheaper shipping, you should contact them.
Shipping cost seems too low, I doubt they are using proper hazmat shipping. But I can't be sure...
Also you have to know that dealing with someone from EU is much easier that with china, I would pay more only for that aspect alone.
randyc1   100 W
Post by randyc1 » Aug 18 2016 11:32am
What you think???
Ok so i sent nkon an email for info about VAT and shipping cost to Can .
Riba you doubt china shipping is legit because it is low cost , but you think nkon will be lower ??
