Building battery packs. Need advice
Dr.Electric   1 mW
Post by Dr.Electric » May 08 2015 9:33am
So I just bought 224 Samsung inr 25 r cells.
And I'm planning to build 3 battery packs 2 packs with 13 s5p for my friend and his wife and one 13s7p for my cargo/kid bike.
But I need a little advice concerning BMS and charger.
I am considering this one:
http://www.ebay.com/itm/48V-54-6V-13S-4 ... 33a0bef155
From Su power.
What I'm looking for is something both cheap, but also of good tested quality.
Any ideas ore suggestions?
I looking at 25A draw in current but will probably prefere to go with at least 40A BMS.
Any ideas for at power supply. Live in Norway and need 220 volt compatibility.
What size on Nikkelstrip do you suggest for welding. 10 mm*0.15mm ?
Best regards
Johannes :idea:
riba2233   1 MW
Re: Building battery packs. Need advice
Post by riba2233 » May 08 2015 4:01pm
For welding and nickel size: -for parallel connections as this as possible, and for series connections I don't recommend nickel, solder copper wire on the nickel between the cells or weld copper sheet.
I had good experience with this BMS:
http://www.ebay.com/itm/Battery-Protect ... 3a8e707b5b
My electric moped: http://www.evalbum.com/4966
My electric car: http://www.evalbum.com/5364
Dr.Electric   1 mW
Post by Dr.Electric » May 11 2015 2:38am
That BMS is perhaps a litle bit ont the small size i current carrying capasity.
I have written to Bestech for a quote.
riba2233   1 MW
Post by riba2233 » May 11 2015 2:53am
Maybe this one:
http://www.aliexpress.com/store/product ... 21963.html
Bestech will cost a lot, because you have to order at least two, and add a shipping cost.
