Charge and sag
torqueon   1 kW
Charge and sag
Post by torqueon » Jun 27 2015 9:22pm
Running 32120 headway's cells. They always seem saggy after a full charge and balance at 1st run, let them set for a few hours and next run is great as the day i bought them. Is this the norm for these cells.
Any input appreciated.
Pete
999zip999   100 GW
Re: Charge and sag
Post by 999zip999 » Jun 27 2015 11:42pm
More info. What controller and motor you using ? BMS ?
torqueon   1 kW
Re: Charge and sag
Post by torqueon » Jun 28 2015 12:15am
Brushed motor and controller, been using since 2009. Always the same results. Pardon me, a slow learner here !
BSATOM   1 W
1 W
Re: Charge and sag
Post by BSATOM » Jun 28 2015 12:29am
Most obvious first...Are you describing the peak charging voltage dissipating down to the nominal running voltage?
Most of a cells capacity is delivered at nominal voltage, so fully charged pack showing peak charging voltage will have a tendency to sag down to nominal voltage under load.
So this has been happening all along since 2009? Or is this a new condition? "Been using since 2009. Always the same results" contradicts "next run is great as the day I bought them".
Yeah, full, detailed system hardware info and battery charging/discharging history is needed for a less general response.
Hugo Fugusev...
1996 GT LTS3 w/Marzocchi Bomber Z2
MXUS 3000 4T 18s Multistar 20.0
7000w limit.
dogman dan   100 GW
Re: Charge and sag
Post by dogman dan » Jun 29 2015 6:22am
Good guess, are they all hot when they come off the charger when you balance them?
