helpfulguy
You want a crazy city bike wheelie machine (top speed 45kph or so). Cromotor is too expensive so you go for an mxus 3000, assuming it can take 6kw in 2-3 second bursts from standstill. You want a pack that is assembled or easy to assemble, no soldering. You need 1kwh of battery. How would you power it?
Alternatives I found:
Low power lifepo4 - pack becomes enormous, very expensive and a lot of energy you dont need. Example: INR18650-29E cells from em3ev.com, 50v 24,8Ah triangle pack, 2C, (~2,5kw) cost $964. Need 4 of them - so cost is ~$4000 (!).
(http://em3ev.com/store/index.php?route=product/product&path=35&product_id=123)
Medium power lifepo4 - pack becomes expensive. Example: INR18650-20R cells from em3ev.com, 50v 18,5Ah triangle pack, 10C, (~10kw power) cost $789.
High power lifepo4 - 6s2p, 12 of them = 1kwh, 30kw continous, price $700.
(http://www.hobbyking.com/hobbyking/store/__10311__Turnigy_4500mAh_6S2P_30C_LiFePo4_Pack.html)
hk lipo hardcase 4s 5ah - 14 of them = 20kw continous (30kw burst), $378. Pack is about 5 liters, 7kg.
(http://www.hobbyking.com/hobbyking/...1P_14_8v_20C_Hardcase_Pack_US_Warehouse_.html)
What alternative would you use to satisfy the conditions? Did I miss any good alternatives?
(Side note: The hk lipo packs are very hard to ignore. The main problem they have are of course the fire hazard. Could probably be handled with a steel/ceramic charging station/pot, and put all the packs inside one of those lipo flamesafe bags inside the battery pack casing. )
