Speedict neptune lite
Hello,
I received the speedict neptune lite recently and to use it, it needs the app on google play store "speedict neptune lite".
I can't find it in the store but can find the other speedict products (mercury, venus, etc)
Any idea how I can get it?
Thank you
Thank you
- bowlofsalad 1 MW
Re: Speedict neptune lite
How many e-mails have you sent the company that made this product and when did you send them your first e-mail?
Just sent 1 email and they responded immediately. They are going to put it in the app store this monday. I hope it's going to work fine!
Great to separate topic for Speedict Neptune, thanks
The Neptune Lite app is sill pending for Google review ... in the mean time we uploaded the APK on google share drive for download, sorry for the delay.
https://drive.google.com/file/d/0B5VoC0 ... sp=sharing
Speedict Technology - Drive . The . Future http://www.speedict.com | http://www.facebook.com/speedict.technology
Speedict Neptune Lite Client is available on Google Play Store now.
Neptune Lite 1.0.1 update available on play store now !
Version 1.0.1
1. redesign Dashboard, Data View and Cell Details page in Landscape mode.
2. bug fix over size font on high density display such as Samsung S6.
Version 1.0.1
- Attachments
- DASHBOARD_L.png (18.18 KiB) Viewed 5823 times
- DATAVIEW_L.png (17.51 KiB) Viewed 5823 times
- CELLDETAILS_L.png (16.9 KiB) Viewed 5823 times
I've been using it for 2 months now, almost daily.
I'm currently using it as BMS as my cells are very very stable. It does work VERY well and is VERY useful. I now know that my battery pack is healthy and safe for very little amount of money.
Recommended and kudos thanks for the product:
http://www.speedict.com/
I don't usually recommend products, but when I find one that is cheap, reliable and extremely useful. I can only promote it to the community.
My only problem now is... I want to expend it to 20s and it's up to 15s max... damn it.
It's good for 48v pack but not yet for higher voltage. If your pack is lower than 48V... go for it! I haven't found anything better at this price range in the market!
Any plans for iOS version of software?
Do you know what the current drain on the batteries is and whether it is balanced?
we don't have iOS plan, we rather focus client on Android smart watch.fechter wrote:Any plans for iOS version of software?
it has no current measurementfechter wrote:Do you know what the current drain on the batteries
it tells individual cell voltage delta among others, we can consider your idea on next upgrade for customer can define cell delta to alert whether battery pack is BALANCED !fechter wrote:is and whether it is balanced?
- parabellum 10 MW
Does it have balancing function? (it says balancing on demand)
Can 2 of them be connected in series and communicate or be shown and governed on phone at once? (24s pack as example)
Will there be any serious documentation to describe what it can do, parameters and instructions available?
Neptune Lite has no cell balancing function.parabellum wrote:Does it have balancing function? (it says balancing on demand)
It is standalone can not be stacked for more than 15 cells support.parabellum wrote:Can 2 of them be connected in series and communicate or be shown and governed on phone at once? (24s pack as example)
We are ranking the below models with different configurations and features for next product release ... your comments and suggestions are welcome
Model 1 : only cell monitoring, fixed 10 - 15 cells, no cell balancing, no charge discharge control
Model 2 : cell monitoring fixed 10 - 15 cells with cell balancing, no charge discharge control
model 3 : bms features, fixed 10 - 15 cells, with cell balancing, with charge discharge controls
model 4 : only cell monitoring, fixed 12 - 32 cells, no cell balancing, no charge discharge control
model 5 : only cell monitoring fixed 12 - 32 cells with cell balancing, no charge discharge control
model 6 : bms features, fixed 12 - 32 cells with cell balancing, with charge discharge controls
Hello, choicr is difficult without price, time to market and size.
If model 4,5 and 6 are about same size, time to release and price I'd say model 6 obviously
But if 5 can be significantly cheaper and faster to release then 5 is favourites. Same for model 4
cwah wrote:Hello, choicr is difficult without price, time to market and size.
Thanks for your comments and that's we want to collect.
Now the model 1 is released, model 3 is soon to be released if we follow the footstep the after next project would be model 4 or 5.
For the maximum cell number support we do concern the size rather than its complicity because the board width at lease 8cm for 32s connector
- parabellum 10 MW
How is power supplied to the unit? Does it drain particular cell group, leading to unbalanced pack? If yes N4 is not interesting. If it drains the pack evenly then N4 is the most interesting option for me personally.
Size is mostly not a big issue with 20lbs battery on board.
No, it take power from top cell.parabellum wrote:How is power supplied to the unit? Does it drain particular cell group, leading to unbalanced pack?
N4 ? do you mean Model 4 ? you don't need cell balance ? and don't need charge discharge control / protection ?parabellum wrote:If yes N4 is not interesting. If it drains the pack evenly then N4 is the most interesting option for me personally.
- parabellum 10 MW
Yes, model 4, I would save on balancing and charge discharge control unless price difference is insignificant.speedict wrote:
how if maximum cell support set to 24 cells ? because of market and size consideration.parabellum wrote:Yes, model 4, I would save on balancing and charge discharge control unless price difference is insignificant.speedict wrote:
- parabellum 10 MW
Usually it is controller related, most popular MosFets in DIY segment are 75V,100V and 150V and Caps go 63V, 100V and 200 (I believe), so the limits are set below those values. I have 5 controllers working on IRFb 4110 which are limited to 100V or 24S and 1 controller on IRFb 4115 limited to 150v by its nature about 36S. Some of us take BEMF in account and do not push the limits, I personally do.speedict wrote:how if maximum cell support set to 24 cells ? because of market and size consideration.parabellum wrote:Yes, model 4, I would save on balancing and charge discharge control unless price difference is insignificant.speedict wrote:
parabellum wrote: Usually it is controller related, most popular MosFets in DIY segment are 75V,100V and 150V and Caps go 63V, 100V and 200 (I believe), so the limits are set below those values. I have 5 controllers working on IRFb 4110 which are limited to 100V or 24S and 1 controller on IRFb 4115 limited to 150v by its nature about 36S. Some of us take BEMF in account and do not push the limits, I personally do.
thanks for your information
Yes, if model 4 can be released significantly faster (and much cheaper) than model 5, I'd buy it without hesitation.
As far as I know, there are no equivalent product in the market. I'd like to upgrade my battery to 20s and I'm for now limited to 15s which is (really) annoying. I'm not wanting to buy market BMS because I don't trust them either.
So I may go back to the old school Cell-log....
Please release model 4 or 5 quickly and I'd get one
cwah wrote:Yes, if model 4 can be released significantly faster (and much cheaper) than model 5, I'd buy it without hesitation.
So I may go back to the old school Cell-log....![]()
yes, will re-arrange model 4 or 5 to higher priority
Cell Balance result
- Attachments
- cell-balance-result.png (21.75 KiB) Viewed 7273 times
Hello Speedict!
I would also be interested in a 24S Model #4
My pack has 20S and I believeyou will cover 99% of the market with a 24S model - there are very few users with 32S,
and they will usually buy a complete BMS for Charge/Discharge etc.
The users that are interested in Mobile-Phone connectivity are typically not the ones with more than 24S - this just makes it very big and expensive.
Let me know when it is available!
Cheers, Ulli
Cheers, Ulli
Danny, you need to drop your plan on your 15s BMS...
We're all looking for the model 4 ASAP
Market is here, with money waiting to give it to you. Make it happen while there is no competition!
yes, right after 15s BMS Model 3, we will start Model 5 immediately.
thank you for the marketing information
