10s3p best 5x6 layout for current sharing?
mrzed   100 W
Post by mrzed » Oct 26 2015 9:53pm
Hi,
I'm getting set to build up my first battery with the JP spot welder. This one will be a 10s3p mini pack using panasonic 2.9Ah PF cells, and I'm planning on a 5x6 rectangular layout, partly to make a nice compact shape that can fit in a seat bag, partly because I got the batteries (from Tumich) in 10 cell 5x2 holders. I'd like to keep the holders for physical integrity, but I'll be welding new connections to suit the layout.
Has anyone done this with a 5x6 layout, or can suggest a good arrangement for proper current sharing? I'll be using .015 pure nickel strip for the connections. I may re-use the existing welds where applicable.
Thanks
Nobuo   10 kW
Re: 10s3p best 5x6 layout for current sharing?
Post by Nobuo » Oct 27 2015 4:21pm
I made once that configuration in this way for a seat bag.
10s3p bag2.jpg (40.17 KiB) Viewed 848 times
* Lithium + Air = Fire * <-----> ** Lithium + Chemical-Additives + Air = ZERO Fire **
<Battery and EV works>
https://facebook.com/evmadrid1
<Battery building resources>
http://www.endless-sphere.com/forums/vi ... 14&t=68005
tomjasz   10 GW
Post by tomjasz » Oct 31 2015 12:37am
I like the layout you did for me. I need to change computers...sh$t...
tomjasz   10 GW
Post by tomjasz » Nov 02 2015 3:57pm
Two nice layouts
36V 14,5Ah.jpg (36.14 KiB) Viewed 380 times
tomjasz   10 GW
Post by tomjasz » Nov 02 2015 4:36pm
This one fits in small triangle bag, Decently made and $5 on aliexpress.
All thanks to boy genius Nobuo!
Thanks Damian!!!
tomjasz   10 GW
14s2p
Post by tomjasz » Nov 03 2015 4:23pm
