miro13car
Hi!
I want to build 36V/6Ah pack from V18 Milwakee batteries 2S2P .
Each V18 is 18V /3Ah.
I am not sure what to do with BMS module inside.
But for sure this BMS plays very important role during charging, as Milwakee V18/V28 charger manual says BMS inside battery makes sure cells are balanced, at least it is clearly mentioned , also it is mentioned that BMS senses pack temperature.
I want to use this home -made pack on TF so it must accept regen current I think at least 5A.
All codless tools have some kind otf electric brake, you release trigger electric brake stops it in instant. How does this relates to BMS circuit?
Maybe some of this is return to cells during braking, just pure speculation. DeWalt drill top of the drill gets hot during ripeated on/off trigger use.
It is almost for sure brake at works. I guess drill dumps braking current into some kind of resistor.
I almst decided to disconnect BMS during powering motor and use it only for charging, because.....
I don't have to worry about overcharging , my TF draws theoretically 14A , maybe max15A, so no problems with that, overheting very unlikely with such use.
My concern is how would e-Moli cells take regen current dumped on them.
Any thoughts.
MC
Any thoughts.
MC
