Is there a quick load test to evaluate a Li Ion 18650?
Boyntonstu   10 kW
Post by Boyntonstu » Dec 02 2015 10:04am
I have a car battery load tester. It shows the open circuit volts and when I flip the switch it draws a lot of current.
If the voltage remains in the green, the battery is OK.
Next, iffy yellow, and finally bad red.
Assume an 18650 cell at 4.2 volts. I can measure its internal resistance, but it takes time.
Is there a draw tester similar to the car meter?
I think that if it could draw 10A for 10 seconds and maintain a minimum acceptable voltage, the cell should be OK.
I have approximately 100 cells to test.
Nobuo   10 kW
Re: Is there a quick load test to evaluate a Li Ion 18650?
Post by Nobuo » Feb 12 2016 4:12am
The opus BT-C3100 charger/analyzer do a quick IR test in a pair of seconds based on a load and the voltage drop. It is acceptable precise to have an idea of the cell status
* Lithium + Air = Fire * <-----> ** Lithium + Chemical-Additives + Air = ZERO Fire **
<Battery and EV works>
https://facebook.com/evmadrid1
<Battery building resources>
http://www.endless-sphere.com/forums/vi ... 14&t=68005
dogman dan   100 GW
Post by dogman dan » Feb 12 2016 6:11am
If it really does a 10 amp load, then you can look at voltage drop under load and make comparisons.
