SODIUM-ION 18650 BATTERIES ?
ScooterMan101   1 MW
Post by ScooterMan101 » Dec 13 2015 12:10am
Who is in France that knows about this ?
http://www.gizmag.com/french-researcher ... ult-widget
My first conversion ... Sold
viewtopic.php?f=3&t=71378&p=1077497&hil ... 1#p1077497
It's 2018 already, ( now 2019 ) lets get some real , improved e-bike / e-velomobile / e-motorcycle designs .
Nobuo   10 kW
Re: SODIUM-ION 18650 BATTERIES ?
Post by Nobuo » Feb 19 2016 10:18pm
The improvement is basically in energy/cost ratio and savy-cost and easy production. Their discharge rate is medium and their energy density low. A good solution for enormous and cheap static energy container installation
* Lithium + Air = Fire * <-----> ** Lithium + Chemical-Additives + Air = ZERO Fire **
<Battery and EV works>
https://facebook.com/evmadrid1
<Battery building resources>
http://www.endless-sphere.com/forums/vi ... 14&t=68005
Vanarian   10 kW
Post by Vanarian » Feb 20 2016 7:14am
That's cool, haven't heard of it and I'm in France actually :o
-+AT-One project : electric inline skates - no remote, hub motors, one frame for various wheel sizes & quasi-universal boot mount
Rollo Ergo Sum!
ScooterMan101   1 MW
Post by ScooterMan101 » Feb 21 2016 3:47pm
There are some scooters/bikes that use low a discharge rate,
For instance for the Q100 motors people are saying no more than 18 amps, and only use up to 14 amps if you use a 16s pack with that motor .
Some others are happy with 25 amps on a 48volt ( 13s pack).
I have a scooter with a 30 amp max controller.
What discharge rate are they listing / would it handle : 36volt (10s 10 amp hour pack ) ? 30 amps ?
or a 48 volt ( 13s 4p or 5 p pack ) ?
or a 52 volt ( 14s 4p or 5p pack ) ?
and
What energy density are they per cell ?
as many people are still using 2000mAh or even 2500mAh cells
Nobuo wrote:The improvement is basically in energy/cost ratio and savy-cost and easy production. Their discharge rate is medium and their energy density low. A good solution for enormous and cheap static energy container installation
