I'm using the Luna 48v, 14ah, GA cell, shark pack. The charger is the Luna Advanced charger, settings are: amps set to 3 and voltage max switch set to it's up position, which is supposed to be an 80% charge.
With the 3 amp, 80% settings, the charger charges the pack to 50.8 volts. The Luna Advanced charger indicates 50.8 volts at the end of the charge, and so does my Harbor Freight multi meter when measuring pack voltage at the batteries XT-90 plug, after the battery has been off charge for a while.
A few days ago I rode my ebike 14.9 miles, pedaling more than usual, and riding at a looking for deer speed, average speed was 10.5 mph. This ride had very little climbing, and little wind. Ride time was 1 hour, 25 minutes.
Pack voltage was 47.9 at the beginning or recharge and 51.1 volts at the end of recharge. The charger was set to the 3 amp rate, recharge time was 1 hour, 11 minutes, this recharge time included voltage titration at the end of charge, if there was any. If recharge was 3 amps for 1.18 hours, then 3.55 Ah was put into the battery pack. So, the ride used 11.4 Wh/mile, drew 2.5 amps average and the power average was 120 Watts, much of this based on recharge data, average amps is based on ride time, not recharge time. At a nominal voltage of 48 volts, the pack provided 170 Wh for the 14.9 mile ride.
Bike is an old Sterling City Sport 15 MTB style bike, it has 18 speeds, upright bars and an Aotema direct drive, brushless, sensorless, front hub motor. Tires are old 26 x 1.5 Chen Shing City Tires, pressure was 60 psi, the rear had a Slime tube, the front did not have Slime. I weigh 180 lb.
Pack capacity: starting at 80% charge and ending at 20% charge remaining, the middle 60% of the batteries capacity would be used. 14Ah x .60 = 8.4 Ah available for use. As others have stated, at the amp rates we use for ebiking, the actual battery capacity will be less than 14Ah. If we use 12Ah, for our kind of use, then the middle 60% of capacity is about 7.2Ah. Wow, riding on flat bike paths, with little climbing and little wind, my potential range might be 30 miles. That is phenomenal range, especially compared to the 12 miles I was getting from my three tired and abused 12v, 12Ah gel cells, in a 36v gel cell pack. The Luna Shark pack weighs 7.8 lb, the 36v gel cell pack weighs 25.8 lb.
Hope this information helps.
Older now but still riding against the wind,
Mike S
