JTL
I have a Shark 52v 13ah NCRB battery that I got from Luna. It will charge to 58v+ but runs out of juice at 47.5+. I have tried to "balance" it a few times, charging to 100% but it does not change the outcome. Luna is working with me but they tell me this is not a bad battery issue so they are sending me a new charger. What do you think?
I believe Karl posted something a while back about using the battery charging wires to run other DC things like lights. I think he was referencing Anderson connectors or something similar. I wonder if I could do the same thing with a barrel connector providing I maintain the correct polarity? If I can, could I also check the remaining power using my multi tester and a barrel connector with bare wires. Is the charging port just an extension of the main drain port?
