Spot Welding Copper Strips to 18650 Battery Cells
devmonkey   1 mW
Re: Spot Welding Copper Strips to 18650 Battery Cells
Post by devmonkey » Dec 28 2020 5:37am
Power leads have been attached. I 'butterflied' 8awg silicone cable and soldered to a piece of copper which was then welded to the cells. I formed a channel in the copper to wrap around the wire increasing the joint strength. Now just need to attach some balance leads (no BMS in this pack). Any recommendations on compact connectors I can mount on the packs for the occasional balancing exercise (99% of the time these packs will just be bulk charged). Was thinking of either sub-d or pcb headers.
IMG_20201227_170630 (Large).jpg (453.67 KiB) Viewed 505 times
garolittle   1 kW
Post by garolittle » Dec 29 2020 4:39pm
I know it’s incredibly expensive, but has anyone here purchased the Orion Omega 250 system shown in the link below?
https://youtu.be/jDCY0buOI-A
Hummina Shadeeba   100 MW
Location: sausalito cali..up the hill in front of the cruising club.
Post by Hummina Shadeeba » Dec 29 2020 11:23pm
devmonkey wrote:
Dec 28 2020 5:37am
https://www.amazon.com/jst-xh-connector ... +connector
what do you do to balance?
docware   1 kW
Post by docware » Dec 30 2020 9:30am
devmonkey wrote:
Dec 28 2020 5:37am
You need reliable bullet-proof solution, I can reccomend Higo connectors.
https://www.higoconnector.com
Higo Mini B connectors.jpg (148.33 KiB) Viewed 438 times
Mini F female connectors.jpg (46.18 KiB) Viewed 438 times
Post by Hummina Shadeeba » Dec 30 2020 2:59pm
docware wrote:
Dec 30 2020 9:30am
devmonkey wrote:
Dec 28 2020 5:37am
All I can find is jst or Molex for 15 pin (14s). What you recommend?
hallkbrdz   100 W
Post by hallkbrdz » Dec 30 2020 5:40pm
devmonkey wrote:
Dec 28 2020 5:37am
I'd recommend surplus mil-spec connectors. I'm using a MS3126E22-55 for my 42S packs with external BMS. Not that expensive and very reliable.
https://www.ebay.com/itm/BRUNDY-MS3126E ... 1438.l2649
devmonkey   1 mW
Post by devmonkey » Dec 31 2020 10:33am
Finished pack, just bunged some JST on there for now as I had them already, far from ideal but will let me check the cells. Cells were within 2mV absolute straight out of the box which was amazing.
[youtube]utYveWc6Wrg[/youtube]
Post by Hummina Shadeeba » Dec 31 2020 11:03am
Why’d you make it two batteries instead of one?
devmonkey   1 mW
Post by devmonkey » Dec 31 2020 11:15am
Hummina Shadeeba wrote:
Dec 31 2020 11:03am
Yeh the layout was quite constrained and it had to be curved to fit the harness, would have been possible to do them in blocks of 6 rather than 3 to end up with a single pack but then would have needed twice the copper thickness as each plate would be carrying the full current. I can't spot weld thicker copper so this the compromise was 2 packs. I did have an alternative layout where each physical pack carried one half of each pack, starting with the negative in the middle and ending with positive in the middle of the other half but required complicated interconnects to break the pack down. This could have been made into a single pack by wiring parallel connections across each side.
garolittle   1 kW
Post by garolittle » Feb 07 2021 12:37am
Finally decided to buy the Omega 250i pulse arc welder from Sunstone Engineering. It was a really big investment but I’m very pleased with the results. I decided to practice with the most difficult spot weld of all ... thick copper. Here is a video of some sample spot weld using .4 mm thick pure copper. This is a rewrapped Samsung 25R cell.
https://youtu.be/h_XPnqejBYM
jonescg   1.21 GW
1.21 GW
Post by jonescg » Feb 07 2021 1:02am
Looks great - I reckon it's a winner.
What did it cost you? And how deep is the throat on it? Can you weld up a 350 mm deep pack?
garolittle   1 kW
Post by garolittle » Feb 07 2021 1:15am
jonescg wrote:
Feb 07 2021 1:02am
Thanks. It was a big investment at $27K (USD) but it comes with a micro pulse arc and tack welder. The weld head in the middle was used to make the welds on the .4 mm thick copper busbars in the video above. Here are a few photos of how the cells look after the bus bar is removed. Welds are very consistent and very strong. Still learning how to use the machine but so far the results are very pleasing.
garolittle   1 kW
Post by garolittle » Feb 07 2021 1:35am
20-second video of an assembled module ....
https://youtu.be/ljw1OvuyC-0
amberwolf   100 GW
Post by amberwolf » Feb 07 2021 1:38am
garolittle wrote:
Feb 07 2021 1:15am
:shock:
That's more than I've *earned* in some *pairs* of *years*, even recently. Still significantly more than I make in a whole year now.... :shock:
I...can't imagine spending that kind of money on...well, anything...but I'm guessing you're looking into commercially manufacturing batteries, not just stuff for yourself. ;)
garolittle   1 kW
Post by garolittle » Feb 07 2021 1:44am
amberwolf wrote:
Feb 07 2021 1:38am
....but I'm guessing you're looking into commercially manufacturing batteries, not just stuff for yourself. ;)
Definitely was a big investment. Had to take a deep breath before making the purchase. However, I have tried many other spot Welders over the years and finally concluded I needed a professional grade Welder like this. Definitely plan to “go commercial” with battery packs for go carts, E bikes, and electric motorcycles at some point in the future. I’ve learned many things from this forum and want to put the knowledge to good use now.
spinningmagnets   100 GW
Post by spinningmagnets » Feb 07 2021 9:50am
Boats, forklifts, home power back-ups...
garolittle   1 kW
Post by garolittle » Feb 07 2021 11:32am
spinningmagnets wrote:
Feb 07 2021 9:50am
Yes Sir. :-). Hoping to quit my regular job and go full time with battery assembly as soon as possible. Really enjoy this project.
Post by Hummina Shadeeba » Feb 07 2021 11:48am
Why’s there such a huge gap in welders where we can get a welder for 230$ (Kweld)that will do .1mm copper but need to spend way more to get something to do .4? Cant they just make a welder with more/bigger bits on the board?
Kweld say it isn’t designed for copper though. .3mm nickel is it’s stated most conductive possibility.
My experience with a nickel then copper sandwich leaves me with just nickel and copper welded and not to the cell.
I found I can strongly weld .1mm copper to the negative side of a123 26650 cells with just 30 joules but the other side I have really weak welds at even 50 joules.
garolittle   1 kW
Post by garolittle » Feb 07 2021 3:26pm
Feb 07 2021 11:48am
That is actually a great question. I’ve often wondered the same thing. You would think there would be a $2k welder that would allow for enough power for at least .25 mm thick pure copper.
john61ct   100 GW
Post by john61ct » Feb 07 2021 3:39pm
Feb 07 2021 9:50am
What jurisdiction are you planning on locating wrt torts law?
Post by spinningmagnets » Feb 07 2021 4:45pm
Concerning laws, I would suggest forming any such business in the US as a welder-rental service, and the rental company rents the machines to the battery building company.
You don't have to be "at fault" for someone to sue you, and there are cases where liability insurance paid $15,000 for someone with NO CASE to simply "go away" instead of going to court to easily win, and THAT is a powerful incentive to sue, regardless of fault. Perhaps even a battery building competitor might sue.
The machine rental company and battery building company might be formed as LLC's to sheild your private assets.
xxxxxxxxxxxxxxxxxxxxxxxxxxxx
welding machines
It might be possible to weld 0.20mm and thicker copper with a rewired transformer-based RSU, and a 120V soid-state timer with foot-switch... I don't know. You would definitely need to use the infinite split (two completely separate strips that dont touch, instead of a single ribbon)
https://www.electricbike.com/resistance-soldering-unit/
Post by Hummina Shadeeba » Feb 07 2021 5:10pm
what about adding electrodes to one of these: https://www.harborfreight.com/120v-spot ... 65da628322 "1.5 kVA @ 50% duty cycle"
and there are also 240v versions.
in the link you just posted it looks like they were trying to make a welder for the same purpose as the one i posted: welding plates
or what's a good way to cut a slit in the copper?
garolittle   1 kW
Post by garolittle » Feb 07 2021 6:39pm
Feb 07 2021 4:45pm
Interesting idea. Thanks
Post by spinningmagnets » Feb 08 2021 8:34am
If its an LLC, the person cannot be personally sued for the liabilities of the company, but the battery building company can have its assets seized to satisfy the judgement against a lawsuit that was successful (or a spurious lawsuit brought by competition in order to get paid $15,000 to drop the suit in a settlement). Funny thing is, if they can't get anything from you, no lawyer will take the case.
So court marshals/sheriffs will lock up the business and take any tools and materials to be auctioned off to give the money to the winner of the lawsuit, along with any completed battery packs. If the business owns the building and a delivery truck, they will seize that too.
However, if the building, delivery truck, and spot-welders are rented, they cannot be seized and auctioned off. To start the rental company, write a personal check, but the check must say on its face "loan number X to Chameleon rentals, LLC". Write a one-page contract, and the terms of the loan are a balloon payment plus high interest in 50 years. Of course, you can pay yourself back early if that benefits you.
I am personally aware of a company that was raided (wife left, and decided to make false claims about husbands business to the IRS). The problem was not getting their computer back, because they bought a new laptop the same day. The problem was getting the information that was on the seized computer.
Therefore, have an external memory drive hidden near where the laptop is stored for the night. Have it use bluetooth or some other wireless communication to automatically back-up everything that happens each day (once a week, put a back-up on an SD thumbnail card). Invoices, checks written, client addresses, phone numbers, and dates of business, etc...Plus, courts aside...you also can't discount a violent meth-head with a chronic gambling addiction breaking-in and stealing the laptop to try and sell it to get enough money for a new ebike...
There's another layer where you fly to Las Vegas and form the battery building LLC in Nevada, and all calls and mail are forwarded to your "branch" in the state you live in...
I am not a attorney, nor do I play one on TV, but...if this information has been helpful, send your social security number and mothers maiden name to: spinningmagnets, prisoner #41, Kansas state correctional facility for the criminally insane, Junction City, OU812.
SlowCo   1 MW
Post by SlowCo » Feb 08 2021 9:07am
Feb 08 2021 8:34am
:lol:
