Spot Welding Copper Strips to 18650 Battery Cells
spinningmagnets   100 GW
Re: Spot Welding Copper Strips to 18650 Battery Cells
Post by spinningmagnets » Jun 01 2019 1:09pm
I'm looking forward to retirement, because then I would have had the time to perform dozens of experiments that have been on the back burner for a couple years. Making a sandwich of copper/nickel is affordable and easily done with existing supply-line materials. DIY nickel-plated copper? what thickness of nickel is best? Maybe nickel-plated aluminum? Stainless plated aluminum? Anodized aluminum? Brass-plated aluminum/copper?
I was immediately reminded about a shill who posted a while back, and even though he only posted one of his companies products, it was worth knowing about, called SigmaCLAD. (original ES post here, https://endless-sphere.com/forums/viewt ... &start=700 )
https://chargedevs.com/features/enginee ... -industry/
A
I was intrigued by the addition of a layer of stainless steel, which has an IACS conductivity rating of 3/100, compared to nickel at 23/100. Of course that makes it an excellent choice to easily spot-weld, but even as thin as its cross section would be, I think its a bad idea for ebike packs due to the horrible amount of resistance. And if you do add stainless, why add an additional layer of nickel? You can't always trust what manufacturers claim about their products, but we can still sometimes learn something valuable that might apply to us.
My first reaction was, why not just have nickel-clad copper? (cladding is a dry-process of bonding by rolling pressure, rather than electro-plating with chemicals). Wouldn't a three-layer material be cheaper to make than a five-layer material? The company PR release answered that question by saying the high conductivity of the copper core "overwhelmed" the spot-welding process. Of course, their customers may have demanded a material with no split, which would have forced the current direction through the cell-tip, rather than side-stepping through the bus itself.
I do believe it is possible for the cladding process to make bus material cheaper than electro-plating. They also mention that the symmetry of the clad materials helps it retain its shape when it heats up. If there were only two layers, the copper might expand from heat faster than the nickel, causing a pressure for the strip to bend. That being said, our goal is to allow a DIY battery pack that does not get hot when providing 15A-20A peaks per cell.
B
Is thin stainless cheaper than pure nickel and readily available locally in major cities? (doesn't need to be ordered). The lower layer would NEED to be nickel instead of stainless, because its conductivity is 23/3 better (7 times?) than stainless. If someone here got stuck with an order of nickel-plated steel ribbon (after they ordered pure nickel ribbon) then, the Ni-plated steel would likely be fine for the top cap...
I'm even now wondering if yellow brass would be acceptable for the lower layer. Its conductivity is less than copper (so it is more weldable with existing DIY machines), but conducts better than nickel...28/100, compared to 23/100... Brass is soft enough to be cut by scissors, and it is cheaper than Nickel.
garolittle   1 kW
Post by garolittle » Jun 01 2019 1:16pm
I remember that post. Very interesting concept.
VenomKarts, LLC
VenomKarts.com
Augusta, GA
SirLongAss   100 mW
Post by SirLongAss » Jun 01 2019 7:49pm
I finished building a 52v 13.6 ah battery with nickel(0.2mm) and copper(0.15mm) sandwich taps. It's kind of a pain in the rear.
Keep in mind. I was using a Malectrics Arduino Battery Spot Welder with a 800CCA car battery.
I had to set my welder to 40ms(normally I can weld 0.2mm nickel with 16ms) pulse time to get these to stick and oh boy did my welding probes get hot af real quick. So I had to take a few breaks. Also, trying to get one sandwich tap to weld to another is not recommended as it doesn't seem to hold very well and just pops off half the time.
Maybe playing around with different ratios of nickel to copper will fix some of the issues I encountered.
ridethelightning   1 MW
Post by ridethelightning » Jun 01 2019 8:12pm
sounds like your max pulse current isnt high enough. if it takes 40ms to make the weld, i think thats too long and will probably dump too much heat into the weld. your looking for a massive burst of amps in like 7ms or something.
i think you would need ballpark 2000A to attempt copper welding, with or without nickle sandwitch
(based on other posts and research on es)
SirLongAss   100 mW
Post by SirLongAss » Jun 01 2019 8:27pm
ridethelightning wrote:
Jun 01 2019 8:12pm
All my welder does is shorts a 800CCA car battery for the amount of milliseconds it is set to. No control over the pulse current lol.
Even though it has some issues, I think this is a good solution vs buying that $10,000 welder at the start of this thread.
kdog   10 kW
Post by kdog » Jun 01 2019 9:15pm
WTF!!
IT WORKS! easy as pie. It's like the copper isn't even there. The nickel punches a hole straight through and welds to the can, fasting the copper no prob.
I did .1mm cu for all tests
.1mm Ni on top was dead easy but a littleweak as both strips a re weak.
.15mm Ni was probly the best all round.
.2mm Ni was starting to have weaker welds but with a bit more power it would've fine.
This was a very quick test (5mins worth)
Would've saved a shit ton of headaches when I did my battery a year ago... The one with the punched copper
In all my testing can't believe i didn't stumble across this...(%$#*!)
Deleted edit
kdog   10 kW
Post by kdog » Jun 01 2019 9:21pm
A pic for you all.
On the .1 Ni you can see it was a bit hot but the. 15 Ni is pretty good and has good much strength.
Same power level for all.
Real quick test
kdog   10 kW
Post by kdog » Jun 01 2019 9:27pm
.1mm torn off to see underside.
Post by ridethelightning » Jun 01 2019 10:21pm
looking nice! :D
Post by ridethelightning » Jun 01 2019 10:25pm
SirLongAss wrote:
Jun 01 2019 8:27pm
yes you do have control of the current! just get more batteries!
if you could find 3* 800cca batteries and parallel them, id say you would be in the zone.
ofcourse, depending on your welder fets etc, you will probably need to look at using shotky diodes to control the avalanch current, or make a new power switch with more/better fets.
might be easier to get some high c lipo to power it than sla.
SirLongAss   100 mW
Post by SirLongAss » Jun 01 2019 10:46pm
Jun 01 2019 10:25pm
SirLongAss wrote:
Jun 01 2019 8:27pm
Funny enough it is on my mind. I'll have to either upgrade my welder or build another. Mine is capped at 1200CCA but from what I've read it doesn't last long at anything over 800CCA.
Nah not lipos. I got the perfect cells for that. (something that wont puff up and can be left fully charged)
I bought 3 of them a few months back and they each will do 500A pulls. 4 in parallel and you got your 2000A pulse.
https://www.aliexpress.com/item/3pcs-40 ... 2e077canK5
Post by ridethelightning » Jun 02 2019 12:33am
holy crap! they look like the perfect thing.
rebuilding your welder may not be so hard. im at that point now, modifying a riba welder
https://endless-sphere.com/forums/viewt ... 4&t=100435
basically use the low current timing circut to provide the 12v pulse for the fets and build a larger switch for the high current , using more/better fets and a few diodes.
im just waiting for my fets to arrive.
Post by spinningmagnets » Jun 02 2019 12:27pm
Here's a video about spot-welding aluminum, using this trick of making a steel sheetmetal sandwich with the aluminum in the center. Start at 1:11
https://youtu.be/gcgC3V3mkcw?t=71
garolittle   1 kW
Post by garolittle » Jun 04 2019 11:58am
Great discussion. Very interesting ideas. I am still trying to convince my wife that the $10k spot welder would be a great Fathers Day gift. No luck yet. :-)
VenomKarts, LLC
VenomKarts.com
Augusta, GA
Strizh   1 µW
Post by Strizh » Jun 26 2019 5:32am
Hey guys!
Here's a device that I've made to weld copper strips to 18650 cells using standard TIG welding machine. Please check it out. I will be very grateful for any kind of feedback.
https://youtu.be/bYDD5-u3WKw
https://youtu.be/xgTehS_9Dfg
litespeed   100 kW
Post by litespeed » Jun 26 2019 6:41am
That is awesome.....basically you made a pulse arc welder. Very cool!
Tom
Post by spinningmagnets » Jun 26 2019 12:54pm
Just did a quick google. On youtube, a $1000 TIG welder is considered entry-level and "affordable". That being said, this is useful info...
mattthemuppet   10 mW
Post by mattthemuppet » Jun 26 2019 2:20pm
kdog wrote:
Jun 01 2019 9:15pm
WTF!!
Deleted edit
fabulous, thanks for the heads up! I read through this whole thread, what a journey :) I'll be rebuilding a Giant Road-e battery in a month or so, using Sanyo GA cells from Michal and a Malectrics tab welder (both found through research on here!), and I've been thinking of ways of reducing heat in the battery especially riding in hot Texan summers. I have some 0.15mm x 10mm Ni tape and I've just ordered some 0.1mm Cu sheet (10x100cm). Can't wait to get going on this and get my range/ power back.
this place is such a fabulous resource :D
qwerkus   1 kW
Post by qwerkus » Sep 04 2019 7:41am
kdog wrote:
Jun 01 2019 9:15pm
WTF!!
Deleted edit
Interesting results. If the top layer is only for welding resistance and physical strength, why not using ni plated steel ? Cheaper and stronger than pure ni.
mattthemuppet   10 mW
Post by mattthemuppet » Sep 04 2019 5:11pm
worked a treat for me - I used Cu sheet and cut it to cover all the cells (8) being connected, then used the Ni strip to do the serial connections. When I did some tests I had to use pliers to peal the Ni strip off the cells, so it was a solid connection. Much to my sadness I borked the BMS during the build, so ended up having to buy a new battery anyway, but the principal is sound. I'll be doing this with any batteries I build in the future - I have a bunch of power tool packs that need re-batterying :)
artvk   10 mW
Post by artvk » Oct 02 2019 9:25am
kdog wrote:
Jun 08 2017 6:48am
so a while ago now, my efforts at finding a nickel alt in copper alloys proved friutless (mostly bc of the volumes i wanted, not bc they dont exist), so i have come up with a DIY version of some high power commecial designs.
i'm building a 20s10p 30q pack that needs to be able to discharge at 120a (peak), even if i used broad sheet .2mm Ni id be required to do a lot of beefing up with solder and copper. As batteries get more and more powerful, ni is going to become increasingly inadequte, and its freaking expensive, but it remains the best welding material so far.
so im working on a different hybrid Ni:Cu spotweld only soultion. this technique isnt new, but im not sure if its been done it has a few benefits, and a few draw backs,
pros:
dual current exit for the Ni means effectively twice the nickel amount per cell
Very short path for the nickel- less loss
all copper-nickel welding is done off the cell with opposing electrodes , also this allows for using thicker copper (i welded 0.2mmNi to 0.15mmCu with ease)
can accomodate any arrangement of cells
uses far less nickel than a broad sheet alternative reducing cost substantially
cons
time consuming
requires setting up with a hole punch and opposed electrodes
The process is to cut out a piece of copper to do the parallel and series connects between adjacent groups.
Punch holes directly over the cell ends
Weld nickel over holes
Weld nickel through holes to battery
I can imaging alot of people saying why bother... and for low power packs this would be overkill, but i think its a good solution if broad nickel isnt going to cut it.
here are some pics to explain
im pretty sure ill use this technique for my current build
i can punch out a copper sheet in about 5 mins (which is copying the template), for the unique shapes it takes about 15mins. this incudes shaping and punching.
the welding of copper to the nickel is super easy and takes about 1min for a strip.
all up itll take quite a few hrs, and im still testing as i go so probly even more time there.
not sure if ill use .1mm cu or .15mm. ill order both to see if i can get consistent welds with the .15mmCu
its definitly stronger than the .1mm so i think ill try and use it.
ill update with some more pics when i get the chance
k
Would like to know the pack you build using this method , Is it still perform ? Im not sure the connection still good in the long run.
I deciding to follow same as your method.
Art
artvk   10 mW
Post by artvk » Oct 11 2019 8:48am
I use arduino spot welder to weld 0.2copper and 0.2 nickel together. High power has been use. The problem is one of connection tip(- from the welder) is solid and another tip ( + direct from battery) is not . anyone have issue with this ?
Art
Lewp91   100 µW
100 µW
Post by Lewp91 » Oct 15 2019 2:29am
kdog wrote:
Jun 01 2019 9:21pm
A pic for you all.
What thickness is the copper kdog? 0.1? Have you tired with 0.15 or 0.2?
kdog   10 kW
Post by kdog » Oct 15 2019 3:27am
Yeh the copper was 0.1mm, haven't tried the test again as I'm not currently building any high power batteries. I've got a feeling that you could use 0.15 without too much trouble cause it's more being fused by the nicked than welded with the amps.
@artvk
That pack I built is still cranking. I use it nearly every day and it can pump out 100a no worries. With regards to the polarity welding issue, yes I have definitely noticed that, it's annoying but I haven't tried rectifying it. To weld the nickel/copper section I did opposing electrodes (one each side) waay easier and much more reliable. I hacked up a couple of pincer style electrode of a pair of tin snip handles. Crude but worked a treat, just keep your cables fat and short as possible.
st35326   100 W
Post by st35326 » Dec 25 2019 11:06pm
Is anybody selling .10 Copper strip to spot weld fuse with Nickle, sold in roll for like the Nickel is? Or must you cut your own?
Lastly, anyone have any experience with Nickel plated copper for serial connections? Does is spot weld just as well as the Nickel Does?
