Spot Welding Copper Strips to 18650 Battery Cells
ossivirt   1 W
1 W
Re: Spot Welding Copper Strips to 18650 Battery Cells
Post by ossivirt » Dec 26 2019 8:26am
st35326 wrote:
Dec 25 2019 11:06pm
Is anybody selling .10 Copper strip to spot weld fuse with Nickle, sold in roll for like the Nickel is? Or must you cut your own?
Lastly, anyone have any experience with Nickel plated copper for serial connections? Does is spot weld just as well as the Nickel Does?
I have not seen anything that is pre cut for battery welding. Copper is even easier to cut than nickel so its not huge problem unless you make lot of packs so it will take some time to cut your copper.
I plated at home some copper with nickel but it did not have pretty much any difference when welding. Nickel plating just turned dark and partly just burned away at weld spots. Its just too thin layer. Best way right now is to put your copper on your serial connections and lay 0.1 or 0.15mm nickel on top and weld through both of them. It takes less current than just copper..
st35326   100 W
Post by st35326 » Dec 27 2019 3:46am
ossivirt wrote:
Dec 26 2019 8:26am
st35326 wrote:
Dec 25 2019 11:06pm
Ok. Sounds good. I found nickel plated Copper and placed an order (link below). I believe spinning magnets is somehow affiliated with the seller. Perhaps he has some insight on its use. I plan plan on giving it a try with my Kweld.
https://www.ebay.com/itm/Pure-Nickel-Pl ... %7Ciid%3A1
ossivirt   1 W
1 W
Post by ossivirt » Dec 27 2019 4:08am
st35326 wrote:
Dec 27 2019 3:46am
ossivirt wrote:
Dec 26 2019 8:26am
st35326 wrote:
Dec 25 2019 11:06pm
Interesting. Its probably not electroplated since from side it is still copper. And its very thic so it must have alot nickel :roll:
My2c   1 µW
Post by My2c » Jan 18 2020 3:56pm
Had this nickel plated copper strip come in just before Christmas.
I have 0.15mm x 8, 6 & 4mm.
I have done some test welds with my Arduino spot welder.
I'm having to use 80ms pulse to get good welds but it is burning and the welding tips get hot real quick.
I'm pretty new to this, any advice on welding this strip to 18650's
First attempt at welding with the strip. Looks a bit of a mess but had been aggressively pulling it to test it out :)
Anything less than 80ms pulse and the welds are hit and miss.
Is the burning around the welds a bad sign??
spinningmagnets   100 GW
Post by spinningmagnets » Jan 18 2020 4:06pm
That vendor is Keith at "18650 Heat Shrink & Cell Holders INC"
https://www.facebook.com/18650Shrink/?e ... WOi-K4zMN6
https://18650shrinkandcellholders.com/
We know of each other, but we are not affiliated in any way. I was the sole vendor in the US for kWeld for one year, Keith is the new vendor. I have bought products from Keith, and I am likely to buy from him in the future on occasion.
