Spot Welding Copper Strips to 18650 Battery Cells
spinningmagnets   100 GW
Re: Spot Welding Copper Strips to 18650 Battery Cells
Post by spinningmagnets » May 29 2020 10:53pm
A quick reminder for the casual readers, if the cost of the magnets is a concern, only the negative ends of the cells are extra sensitive to heat. Of course, if you like the magnet method, it works as well on the positive end as it does on the negative.
For the positive end, I think flattening the tip of a solid copper wire and soldering it with a 100W+ unit would work quite well (possibly fuse-wire?). Using a soldering iron with 100W (or more) means that the joint is accomplished in a very rapid manner, so heat does not penetrate deep into the cell.
Of course, for the positive end, spot-welding remains acceptable, since it can take much more heat than the negative end. For copper series bus-strips, the copper/nickel sandwich method is an interesting option.
kdog   10 kW
Post by kdog » May 30 2020 7:10am
@badazzsteveo
I used a home built transformer based spot welder. Like a mot welder but 2-3x stronger.
Post by spinningmagnets » Jun 14 2020 5:59pm
From facebook. 20S / 6P, copper/nickel sandwich method.
Molicel 21700 P42A cells, 0.10mm copper sheet, plus 0.15 nickel squares only to facilitate welding.
Edit: kWeld used, setting is 50-Joule
A
garolittle   1 kW
Post by garolittle » Jun 15 2020 9:11am
spinningmagnets wrote:
Jun 14 2020 5:59pm
From ES facebook. 20S / 6P, copper sandwich method.
That is impressive. Kweld used?
VenomKarts, LLC
VenomKarts.com
Augusta, GA
Post by spinningmagnets » Jun 15 2020 11:37am
Yes, builder just posted that the kWeld joule setting is 50J...
The nickel-plated copper strips from the kWeld supplier seems to need about 80J
serious_sam   1 kW
Post by serious_sam » Jun 15 2020 6:27pm
That's a neat looking job.
I'm thinking that nickel strip isn't that expensive that you need to cut it into tiny patches for each cell though. Kinda seems like a waste of extra effort. Just run a strip across multiple cells and be done with it.
Also, I would (did) use nickel plated steel instead of pure nickel. Cheaper. Easier to source. Higher resistance and lower melting point (lower energy required to weld).
garolittle   1 kW
Post by garolittle » Jun 15 2020 7:35pm
Jun 15 2020 11:37am
Nice! Very impressive. Thanks for posting that.
VenomKarts, LLC
VenomKarts.com
Augusta, GA
Post by spinningmagnets » Jun 15 2020 7:37pm
For the copper/nickel sandwich method, I am certain that nickel-plated steel would work fine. More affordable than pure nickel, too...
ridethelightning   1 MW
Post by ridethelightning » Jun 16 2020 8:00am
thanks for putting this here. i saw it on fb and was impressed. seems like the nickle sandwitch technique allows lower welding power to use copper. i will be experimenting with 0.2mm nickel and 1.2 mm copper in this way, ill post results here.
Post by spinningmagnets » Jun 16 2020 8:25am
0.15mm___6-mil__34 ga
0.20mm___8-mil__32 ga
0.25mm__10-mil__30 ga
I welcome any experiments. Due to the peak amps of the common cells (30A per cell?), the thicknesses listed above are the copper sheet thicknesses I most want to acquire data on.
As far as the nickel cap, it does not carry series current, and nickel can also be used for the paralleling strips. Since the nickel only needs to facilitate the welding process, there is no need to specify the more expensive thicker 0.20mm nickel strips, although the 0.20 should work well...
0.10 and 0.15 nickel seem to work well as the welding cap. As stated earlier, even the very affordable nickel-plated steel should work well, in any thickness that's available.
serious_sam   1 kW
Post by serious_sam » Jun 16 2020 8:11pm
ridethelightning wrote:
Jun 16 2020 8:00am
1.2 mm copper
Wow, that's thick. I wouldn't have thought that that's even possible.
garolittle   1 kW
Post by garolittle » Jun 16 2020 8:26pm
serious_sam wrote:
Jun 16 2020 8:11pm
Jun 16 2020 8:00am
1.2 mm copper
I am guessing he intended to say .12mm. :-)
VenomKarts, LLC
VenomKarts.com
Augusta, GA
serious_sam   1 kW
Post by serious_sam » Jun 16 2020 11:42pm
garolittle wrote: I am guessing he intended to say .12mm. :-)
Possibly. But have you seen his monster mosfet array?! :lol:
garolittle   1 kW
Post by garolittle » Jun 16 2020 11:57pm
serious_sam wrote:
Jun 16 2020 11:42pm
Ok.... Now I need to see this machine. Someone post a picture so I can engage in "wishful thinking" like I do when I browse the Sunstone Welder website. :lol:
VenomKarts, LLC
VenomKarts.com
Augusta, GA
serious_sam   1 kW
Post by serious_sam » Jun 17 2020 12:45am
garolittle wrote:
Jun 16 2020 11:57pm
Here is the link. It's only 72 mosfets:
viewtopic.php?p=1479497#p1479497
Jul 08 2019 2:47am
so this is sort of but not really quite an update.
i have now received a prebuilt power switch and pulse control board from a webshop in china, who was making these spotwelders.
Post by ridethelightning » Jun 17 2020 5:39am
yeah sorry to get you excited guys :D i meant 0.12mm copper, but that doesnt mean i wont try thicker stuff aswell. im now trying to figure out which way round to install the tvs protection diode i bought as an extra.
serious_sam   1 kW
Post by serious_sam » Jun 17 2020 6:31am
Jun 17 2020 5:39am
Like this:
From here:
viewtopic.php?t=81400&start=550#p1218325
flangefrog wrote:
Aug 30 2016 3:54am
I know this has been explained before (e.g. by Tesseract) but here's my attempt to simplify it a bit for the less technically inclined.
BTW, did you ever get your electric wheelbarrow going ?
Post by ridethelightning » Jun 17 2020 8:43am
serious_sam wrote:
Jun 17 2020 6:31am
:lol: still in the pipeline! so many things prevented me from following my natural course of electric lunacy this year...i wont even go there. but now its getting colder, much less going on- the perfect conditions for a relapse!
so back to the hubmonster and vtc5A pack(which means getting a new spotwelder sorted) and then once thats going ill be in a better position for doing packs for other projects next in line.
thanks for posting the diagram. i now have the tvs diodes on a lead ready, next to do the schottky ones.
garolittle   1 kW
Post by garolittle » Jun 17 2020 11:49am
That is AWESOME. Like the "Dodge Viper" of spot welders. LOL
VenomKarts, LLC
VenomKarts.com
Augusta, GA
serious_sam   1 kW
Post by serious_sam » Jun 18 2020 6:17am
Jun 17 2020 8:43am
Keep us posted!
Post by ridethelightning » Jun 19 2020 6:37am
serious_sam wrote:
Jun 18 2020 6:17am
Jun 17 2020 8:43am
Keep us posted!
will do. chipping away at this steadily.
T
garolittle wrote:
Jun 17 2020 11:49am
:D yes indeed, or maybe a diy waterpipe sawn off shotgun equivalent.
DogDipstick   10 kW
Post by DogDipstick » Jun 22 2020 5:57pm
My Nickel plated Copper strip compared to 18650ed 0.2mm Nickel plated copper strip. lol.
0.04" x 1.250" ( 1mm x 32mm... )
Muhahahaha. Imma gonna try to tig it.
83.1v of Ironhorse XC.. :) :bolt: by Chevy :bolt: :D Broke 10 horsies :twisted: (..about 80% healed..).. :? Anybody.. what equals √3 times the line to neutral voltage? Asking for a friend.. :| (gottenymoem4115thangs?Yall?) :confused: Fabricator @ BSECo. Inc.
garolittle   1 kW
Post by garolittle » Jun 23 2020 12:06am
Not sure if anyone here has tried this but we have been getting very consistent/strong welds using “Nickel Silver”. It does not actually contain silver and is comprised of 65% Copper, 18% Nickel and 17% Zinc. We used a Kweld for the experiments and wanted to share some pictures.
VenomKarts, LLC
VenomKarts.com
Augusta, GA
