hypertoric_amplituhedron
I understand they're a bit less in wh/kg, but some of these cells have a pretty good c-rate:
https://liionwholesale.com/collections/batteries/products/efest-imr-26650-4200mah-50a-li-mn-flat-top-batteries-wholesale-lot?variant=1074703040
"These are the new version of the Efest IMR 4200 mAh battery. They will really pump out the high current at 35A continuous, 50A pulse, and 4200mAh total capacity. These efest 26650 batteries have been awesome in our testing, being able to handle some serious current while going at it for a long time.
Size: 26650 (26.22mm diameter x 65.11mm long)
Note these seem to be ~67mm long despite the Efest spec, make sure your device has the space for them
Type: Li-Mn IMR (Rechargeable)
Rated Capacity: 4200mAh
Max Discharge Current (Continuous): 35A
Max Discharge Current (Pulse): 50A
Voltage: 3.7V
Protected: No
Style: Flat Top
Weight: 100g
Initial Impedance: 13Ω (plus or minus 2Ω)
Color: Purple
Rated storage temperature: 20-60 C"
Voltage: 3.7V
Protected: No
Style: Flat Top
Weight: 100g
Color: Purple
