need help wiring headway 38120S 10ah lifepo4 cells
amberwolf   100 GW
Re: need help wiring headway 38120S 10ah lifepo4 cells
Post by amberwolf » Jun 18 2017 8:45pm
markmm wrote: What should the "full" charge of this cell be? Right now it is staying at 13.2.V. (Showing on solar charge controller and on standalone multimeter. Should it be higher, lower?
As Fechter notes above, truly full, new, cells should be higher. At 13.2V for teh whole battery pack, that's only 3.3v/cell on average. If the cells won't hold a voltage higher than that after being charged to their full voltage of 3.65v/cell, it can mean they are aged or damaged or defective in some other way.
What are the voltages of each of the four parallel cell groups when the battery itself is at that full 13.2V? Please measure and list each of them. This will help us help you find which cells (if any) are not charging fully.
What is the actual charger output voltage?
2. Running the trolling motor for roughly 2 hours (at highest speed) expired the cell, much shorter than I thought.
[/quote]
Since the battery is not fully charged, and/or one or more of the parallel groups of cells is either not fully charged or it is not as capable as the other groups (not as much capacity), that is expected.
What are the voltages of each of the four parallel cell groups when the battery is "expired"? Please measure and list each of them. This will help us help you find which cells (if any) are not charging fully or are lower capacity than the others.
If you also measure and list the voltages of each of the four parallel cell groups when the battery is actually in use (running the motor in the water), this will help us help you see if any of the cells is less capable than the others, as damaged or defective cells will sag lower in voltage than the others.
markmm   100 mW
Location: Metro Atlanta (N Fulton), GA, USA, Solar System...Universe
Post by markmm » Jun 19 2017 8:46am
thanks very, very much, Fetcher and AmberWolf.
I know exactly what you mean in terms of the 'bad cells may be dragging down the good cells', and the great idea to isolate the cell packs.
unfortunately, I am working above my pay grade here so actually doing the tests may require a little more help from y'all to 'splain it to me. (my first build and I had to decide to do some specific-use thing like this boat battery, haha). Basically I am working at the fringes of my knowledge on this so that is why your help is so great and why I don’t know how to do exactly what you are saying, hence these Qs:
1) I can take the battery pack out of the boat to measure the cells, but either way I need to unhook the plates and bridges that connect the batteries, so would it be the same difference to just measure each of the 16 cells individually? (to find if any are low) I would be using a SKYRC iMAX B6AC Version 2 Digital LiFe Battery Balance Charger and Discharger (http://amzn.to/2rtcCCt). Hope that is a good one. So, due to the way the 'connecting plates' are on the pack, it would be harder, I think, for me to measure each group of 4 (?) in the pack rather than just each cell individually. or maybe I could run connecting wires from the pos and neg of first set of 4 batteries, then measure those 4 cells at a time, for each of the 4 cells that make up the total of 16.
2) if the same diff. to do individually: I would then check each cell, make sure they are 3.65 volts per cell, and replace any that are below that... but how much below that is unusable? is 3.60 or 3.3 or what is too low? what is the lowest they can charge to and still be usable in the pack? (I guess the lowest cell would bring all the others down to its level?)
3) also, how much *above* that is unusable? is 3.8 or 4.0 or what is too high? (just making up numbers)
4) the charger output voltage, again, assuming I am understanding this, the goal is to use a solar panel, which is 50 watts. the solar charge controller says at times in full sun it is pumping out 17 or 19 volts at times, and in shade more like 10 to 13 volts, I believe.
the end goal is to have the battery is in the boat, the 50 watt solar panel is on top, and the 16 lifepo4 cells are charged and maintained by the solar panel, though the charge controller. set it and forget it, as long as it gets sun on the solar panel. I'll send some pics.
5) for this testing, not for day to day use, the charger output voltage when using the SKYRC iMAX B6AC can be set to whatever, I think. maybe I could try to set it to 14.6 and leave it for a while and see what happens?
6) I want to get the charge up to where it should be at 100% or 14.6, but at 13.2v now, is that like considered 80% of its capacity or 50% or what? ("At a lower voltage, it will charge to a point, but you will not get full capacity.")
7) I REALLY appreciate your help. I'll be happy to send you to a small apple or starbucks gift card electronically if you want to share your email address.
thanks in advance!
markmm   100 mW
Post by markmm » Jun 19 2017 1:24pm
markmm   100 mW
Post by markmm » Jun 19 2017 1:25pm
fechter   100 GW
Post by fechter » Jun 19 2017 2:32pm
From the diagram, it looks like your pack is 4 series, 4 parallel. In each parallel group, the cells are tied together, so are forced to have the same voltage. When measuring cell voltages, you really only need to measure each group (4 total). Cells within a group will all have the same voltage.
Your basic problem seems like not enough charging voltage. You really need it to be at least 14.4v or you won't have a full charge.
If you have one cell group that is consistently lower than the others, then you may want to disassemble that group to see if it is just one cell. Hope that's not the case since others are likely to fail at the same time. When I start seeing that behavior, I start looking for a new pack. The 4 groups should be within 0.1v of each other.
The "healthy range" for LiFePO4 is from 2.0v to 3.7v. Below 2.0v and the cells can be permanently damaged. Above 3.7v is also bad, but some manufacturers state up to 4.2v is OK. The cells will be fully charged at 3.65v. Going higher can increase the risk of fire or cell damage. For your pack, you can take these numbers x4 to get the total voltage.
markmm   100 mW
Post by markmm » Jun 19 2017 3:24pm
thanks fecher, this is very helpful and down on my level, which is what I need!
1) first I will try my charger set at 14.4v and see what happens.
2) then, if no change, I will test the 4 groups of the 4 cells. would this way I have diagrammed (picture after this post) be a good/safe/accurate way to test each group of 4 cells?
3) then will try this: "If you have one cell group that is consistently lower than the others, then you may want to disassemble that group to see if it is just one cell....The 4 groups should be within 0.1v of each other. "
thank you!
markmm   100 mW
Post by markmm » Jun 19 2017 3:31pm
999zip999   100 GW
Post by 999zip999 » Jun 19 2017 5:43pm
14volt is fine at 3.5 volt per cell hvc. 2.8v is as good as empty or zero .
You guys type fast ok Fletcher. My A123 lifepo4 are dead at 2.5v. Plus he doesn't have a bms.
999zip999   100 GW
Post by 999zip999 » Jun 19 2017 5:57pm
6 years ago a got 4 voltpheaks single cell lifepo4 chargers. They all stop at 3.65v very ez for lifepo4 I think 12usd.
markmm   100 mW
Post by markmm » Jun 20 2017 3:51pm
thanks all.
also, so that is to say that when I am done charging the battery pack of 16 cells should show a 'full charge' reading on a multimeter of 14.4 volts?
or do I need to set the charger to a setting that is 14.4 volts, or both.
I guess what I am asking is, when and if it is done, the whole battery pack should ready 14.4 volts in a perfect world?
(which is confusing to me since I am talking about running a 12V trolling motor so it seems like 14.4 volts would fry a 12 volt thing?)
what should the charging rate be, up to "3C" or 1C or what?
thx!
fechter   100 GW
Post by fechter » Jun 20 2017 4:04pm
Your voltage measurement diagram looks good. Try that and see what the individual groups read. If you can bump it up to 14.6v, it might be better.
A typical motor won't mind having 2 extra volts, so don't worry about that. As soon as you turn on the motor, the battery voltage will sag anyway.
Your charge current should stay below 1C (40A) with those cells. Anything less will be OK. As the pack gets close to full, the current will taper off and approach zero at the end. If you charge at too high of a rate, the cells could overheat.
markmm   100 mW
Post by markmm » Jun 21 2017 12:21pm
ok, thanks fechter, and sorry to misspell your name before. and thanks everyone who replied so far. very helpful.
when I get a second I am going to do these test and will report back. thanks again.
teklektik   10 GW
Post by teklektik » Jun 21 2017 7:04pm
The headway spec sheet plainly states 3.65V/cell +/- 0.05V. There is no reason not to simply follow the manufacturer recommendation.
(4) * (3.65) = 14.6V
This is the HoC voltage (Hot of the Charger) and cells will slowly self-discharge to about 3.3-3.35V even if left disconnected. This is pretty much the 'full charge' voltage. At about 90% the voltage will fall to about 3.2V and stay there for pretty much the whole discharge cycle down to around 10% at which point it will fall off. Although 2.0V is listed as the absolute limit of discharge, this is not a place you want to go... 2.7V is Pretty Damn Empty and gives a small margin of safety from over discharge since there's only a couple of percent charge left. LiFePo4 is a unique chemistry in that the voltage during discharge is almost flat making it impossible to determine State of Charge by voltage. Voltage can be used as a SoC determination only in the 10% at either end of the cycle but in between voltage is around 3.2V -- all the time. All other Lithium chemistries operate differently and voltage can be used to determine SoC.
As a side note: the more cells you put in series without a BMS, the higher you need to set your average per-cell discharge limit. This bit of strangeness arises because during the end of discharge, one weak cell in a field of good cells can over-discharge even though the entire pack voltage looks okay. For example, if you want to cut off at 2.3V per cell in a 10s pack, then setting the pack cutoff to 10 * 2.3V =23V can lead to a situation where 9 cells are at 2.4V (9 * 2.4 = 21.6V) so the last weak cell could be as low as about 1.5V (21.6V +1.5V = 23.1V = SEEMS_OK) and the pack level cutoff would still not trip. So - you either need to go to per-cell cutoff like a BMS, per cell monitoring with a display, or raise the pack level cutoff so the chances of damaging a weak cell are diminished. In short - don't press you luck with the manufacturer absolute minimums to eek out the last couple of percent charge, and be especially conservative for higher S counts.
markmm   100 mW
Post by markmm » Jun 22 2017 9:25am
thanks teklektik, not sure I understand it all. I am in the process of testing as fechter wisely recommended.
I am not sure how to add a bms to my setup (pictures above), and have heard I do not need one and heard that I do.
I was hoping/thinking that my solar charge controller (its an mppt; but have a pwm I have used in the past) which is alwys displaying the charge, and is alwys hooked up to a solar panel that is bringing in current (except at night, of course) that that would keep the charge fine, as long as it was set up to charge the right amount.
thank you to all for your insight
markmm   100 mW
Post by markmm » Jun 24 2017 8:28pm
Status update:
- refresher, this is a 16 cell headway lifepo4 battery pack, for powering a boat trolling motor and a fishfinder/ first charge with a charger, and now attached to 50W solar panel
- worked on it first test, but only for about 2 hours, however that was wide open on the 12 volt trolling motor for most of that 2:15 hours. was hoping for more run time
- from advice above, i took the pack apart today and measured each of the 16 cells individually. All sixteen were 3.3 or 3.32v. The pack voltage reports at 13.3v. I did not let each cell charge up, but the few i tested for 30minutes went to like 3.42 before i stopped it.
- this might have messed up the cells: when i first set it all up, i did not have enough 'connecting plates', so i made one from a license plate (i realize now this was prob aluminum). TODAY, i replaced this with correct steel plates like the others. The pack volatage is holding at 13.3v. Was 13.2 before disassembly.
- tomorrow, after watching parts of the NASCAR race, i am going to hook the charger back up to the full pack and see if i can get it to 14.4v. Yall said not to charge faster than 1C so ok, but it takes longer, huh.
QUESTIONS (again!):
1 Wonder how long is typical to charge a sixteen cell pack that is 13.3v up to 14.4 volts? iow, how many minutes/hours/days should i try before it is clearly not happening? I beleive it wil charge higher as before disaasmbly today i got it to 13.5 but the charger is set to stop after 2 hours of charging as a safety feature (can be turned off)
2) if forever this pack stays at 13.3v, i can expect like 2 hours as i got before, right? Or will it go down and down and become useless? Iow, at 13.3v, will it be useable for a regular cycle life at least at that rate?
3) what else should i be doing or asking that i am not doing? The battery meager of the charger says it is like 70% capacity, i think it said.
ANY further input or advice would be very, very appreciated. Thank you.
fechter   100 GW
Post by fechter » Jun 24 2017 10:04pm
If you charge to the same voltage, you should get about the same run time.
Time to charge depends on charger current. Your pack is nominal 40Ahr, so at 4A charge, would take about 10 hours. You could safely charge at a higher rate, up to 20A if your charger was up to it. At some point the pack voltage matches the charger output and charge current tapers down to zero, so charging longer does not add any capacity.
I think you need a slightly higher charging voltage to get full capacity.
markmm   100 mW
Post by markmm » Jun 25 2017 4:45pm
Thanks fechter. I appreciate your help very much. The battery pack is now reading like 13.4 so that is a little better and the charger says "fuel" is like 80%. The smart charger I am using has all these crazy settings but i am using of course is the LiFe and in there it says it ends at 14.4. But it also has other settings and so i am using "1.5C", where I was using "1C" before. The other options go up to 4C for charging.. is that the same as the 40amp charge you mention? In terms of the "C" setting -should i go to 2c or 3C or 4C? At the 1.5C now, it stops charging after 120 minutes, which I can change but leaving it there for safety for now. (And it is set to 4S out of possible 1S -6S). So what C should I use? Thank you :D
markmm   100 mW
Post by markmm » Jun 25 2017 4:59pm
The charger I'm using
markmm   100 mW
Post by markmm » Jun 25 2017 5:02pm
smithmal   1 mW
Post by smithmal » Sep 24 2018 4:19pm
Mark,
New to the board and am possibly interested in building a similar battery pack using Headway 38140S batteries. How did you fair with completing your DIY battery pack? Did you install a BDS onto it? I would assume that's the best move to ensure all your batteries are balanced when charging them.
Also, what was the final cost for your pack? I've seen 50AH 12V batteries for under $300, but I don't think they include a BDS built into them: http://www.sun-cycle.com/12v50ah-lifepo ... p0026.html
The problem with this product is I know little about the quality of the batteries they use in their pack and I haven't seen anyone put them through their paces to see if the capacity actually holds up. I have seen one video review on the pack here: https://www.youtube.com/watch?v=tSxFod9BZTQ
But the poster doesn't get into actually testing of the batteries capacity like others have done when reviewing lithium batteries.
Thanks,
smithmal
markmm   100 mW
Post by markmm » Sep 24 2018 4:48pm
hey smithmal,
I am just barely literate in this battery stuff but basically it worked fine and is still working, though it seems not to hold as much of a charge are originally, like before maybe 13.7 max or something and now right at 12.9. I did *not* add a BDS thing to it and that might be part of my slow decline problem, but like I said, so far so good and still hooked up to the solar panel and does charge and is an adjunct to my small 2hp motor. seems like I got my cells from china for $19 each, haven't checked prices lately, and I sorta wound up getting 2 rounds as I didn’t know what I was doing even more than now and I killed some of them at first with a charger, but then I got a batter charger and it all seems ok now. and no fires or explosions, haha! this may already be in the post below but just to paste in some info. I did determine that the mpt-7210A charge controller wasn’t really mpt as far as I could tell at all but is really just a reg. charge controller.
everyone here was super helpful in answering my questions, and are much more knowledgeable than me. I'll paste some more info into my next post fwiw
take care.
Hello, I have sixteen of these: 38120S 10Ah Headway Energy Cells, wired to be a 12v40aH cell. (Pls see uploaded pic). Am using it to power a 12V, 62lb thrust trolling motor and a fishifinder. (I did all the balancing before assembling into the final cell). i am using a solar charge controller (tried pwm and mppt) to charge and recharge/maintain.
markmm   100 mW
Post by markmm » Sep 24 2018 4:49pm
what is correct full charge of a lifepo4 12V40ah cell
GWL/Power Lithium Battery 12V/90Ah
http://www.ev-power.eu/LiFeYPO4-batteri ... html?cur=1
LP = 12V Battery block
LFP = 3,2V Cell (4 x 3,2= 12,8V) needs BMS (Battery Management System) for monitoring and balancing of the individual cells.
Minimum Volt: 2,5V per cell = 10V
Recommended minimum discharge: 2,75V = 11V
Maximum Volt: 4V per cell = 16V
Recommended maximum charge: 3,65V = 14,6V
Nominal Voltage: 3,2V = 12,8V
After Full Charge the voltage will drop back to 12,8-13,6V
The Float voltage for the LiFeYPO4 batteries
Unlike the lead acid batteries, there is no need for lithium batteries to apply the constant voltage to maintain the cells in a fully charged condition. (Typical for lead acid batteries 12V - Gel 13.05V, Flooded 13.4V and AGM 13.6V values @ 25°C).
In case you replace the lead acid battery with the LiFeYPO4 battery, it is good to check how the device behaves when charging the battery. When applying the unmanaged float voltage (all called trickle charge), the voltage for LP 12V battery should be always bellow 14.4V (3.60V x 4 cells). Simply said the AGM value of 13.6V should be always OK with the LP batteries / LFP cells.
Depth of discharge (DOD)
All battery manufacturers recommend to keep the Depth of Discharge (DOD) bellow the maximal limit of 100%. Ideally 80% DOD or less is recommended. The rule is quite simple: the smaller DOD the larger number of cycles. With 50% DOD the LiFePO4 cells may have well above 5000 cycles. However it is imporatnt to keep the DOD at the cetral part of the capacity range. If the DOD is not in the center of the capacity range, the cell performace may degrade faster.
As a matter of fact, since it is better to avoid deep cycle discharging, it seems to be better to charge as frequently as possible. It is better to “charge (to full) and drive” rather than “drive and charge (from null)”.
FAQ: 12V LP battery balancing and charging
Question: Can I charge the 12V LFP battery using a conventional auto-moto charger 12V?
Answer: With most of “cheap” car battery chargers you cannot charge the 12V LFP battery. Cheap chargers often end charging at 14V. As a result the LFP batteries are not charged sufficiently. In order to charge to full you need to reach above 16V.
If you have an “advanced” manageable charger, it can be used provided you can set the charge level to at least 16V.
Simply said: you can charge with any kind of charger if you make sure that the battery voltage reaches at least 16V, but does not exceed the maximum limit of 17V.
Question: What are the experiences of balancing 12V batteries, when, for example, four pieces of 12V/40Ah in the series?
Answer: Unlike 3.2V cells that can hardly be operated without balancing, the 12V LP batteries behave “very sophisticated”, so the need for continuous balancing practically does not exist. It is just enough to check the voltage levels during inspection periods. If you notice a difference in the battery voltage levels, we recommend balancing all batteries manually to the same maximum charging level (ie, max 17 V / per battery).
Such manual balancing is made after recharging cells in series, connecting the single battery charger (for 17V) to each individual battery.
The inspection periods and manual balancing is recommended to be performed in these intervals (ie, after number of discharge / charge cycles):
During the initial charge
After the first cycle
After the first 5 cycles
After the first 20 cycles
After the first 50 cycles
And then continue any time differences between batteries are noticed, about once every 50 to 200 cycles.
Question: How should new batteries 12V 20Ah, 40AH, 80 AH, 100 AH, etc. be formed before first usage?
Answer: The new 12V LP batteries delivered from the warehouse are partially charged. However before the first use, it is essential to charge the battery to full capacity. The initial charging should be done with the charging current set to less than 1C (typically 0.5C), till the voltage level of 17V is reached.
There is no other need for LP 12V batteries to be formatted or otherwise specially prepared for the use. After the first charge to full, the battery is ready to be used for use.
The above charging rule is also applied to the initial charge after the battery has been unused or stored for a long time. If not used more than 1 month, it is recommended to make again an initial charge to full.
Important: if you plan not to use the batteries for a long time, before storing you must charge batteries to full. In the case of storage longer than 1 year, it is required to recharge each battery after 12 months to full.
FAQ: Simple balancing using parallel connection
Question: Can I balance the cells by simply connecting all the batteries in parallel?
Answer: You can do this, but it will not work effectively. Actually you would need a long, long time (days or weeks) to balance the batteries this way. Effectively said: you can parallel the batteries if you want them all to discharge to the same voltage level over a period of time.
However you cannot think this way: if you have one 100% fully-charged and one 0%-charged battery and you connect them parallel you will get two 50% charged batteries over some time. It does not work this way!
First: never connect charged and discharged batteries together. Neither in serial nor in parallel. Use only batteries charged to the same voltage level.
Second: you cannot charge a battery using another battery as a charger. You need a charger to charge. You cannot use a battery to charge another battery. The reason: you need to have a higher potential (voltage level) to charge the battery.
FAQ: Using LiFePO4 batteries as starting batteries for the fuel cars
Q: Can the 12V LFP/LFYP batteries be used as starting batteries for the regular vehicles?
A: Yes. We highly recommend using the LFP/LFYP batteries for starting vehicles. Their performance is much better than the lead-acid batteries.
Q: What are the advantages of the LFP/LFYP batteries?
A: LiFePO4 batteries are able to provide much higher starting current than the lead-acid batteries (SLA). They work even in extreme low temperatures (bellow –35 deg. C). They cannot “get frozen” like SLA batteries. They contain no acids and require no special care. Their life span is 10 years and more, while SLA batteries may last just 4 to 5 years. There are no known disadvantages when using LFP/LFYP batteries.
Q: Which battery model is sufficient to start a normal gasoline car?
A: LP 12V 40Ah is sufficient for any range of starting batteries up to 65 Ah of the original lead acid value. For vehicles with larger battery we recommend LP12V 100Ah. For trucks and machinery (using 24V system) we recommend 2 pcs of LP12V 100Ah connected in serial. For campers, mobile homes and other vehicles with large battery we suggest to use 12V 200Ah, by connecting two 100Ah batteries in parallel.
Q: What are the limitations when using the 12V LFP/LFYP batteries in cold winter season?
A: There are no limitations. The 12V LiFePO4 batteries perform very well under low temperatures. We highly recommend to replace the SLA battery with LFP especially if your vehicle is parked out-side and gets very cold. The 12V LFP/LFYP batteries are ideal for countries like Canada, Scandinavian lands, Russia – Siberia, and other cold regions.
FAQ: Using LiFePO4 batteries as starting batteries for the fuel cars (2)
Q: How will the LiFePO4 battery be affected by the charging system of the car?
A: The 12V LiFePO4 battery is not affected by the charging system at all. Majority of the cars’ charging systems charge up to 14V or 14.4V. This represents the charging level of 70% to 75% for the LFP batteries.
Q: Will the car charging system overcharge the LFP battery and shorten its life?
A: No. The overcharge for LFP battery is above 17V. There is no way to reach this voltage in the vehicle. As the LFP battery has no memory effect, it can be charged any time to any capacity. There is no shortening of the life-span when using as a starting battery.
Q: What is the starting time for the fuel engine when using 12V LiFePO4 battery?
A: The starting time for any fuel engine is given by the vehicle manufacturer. Usually it is about 5 to 10 seconds. This time is the same for LFP battery. In any case, the fuel engine should not be started with long starting attempts. Please see the vehicle instruction for starting the engine.
Q: What is the max current available from the 12V LFP battery?
A: The 12V LiFePO4 battery can release the energy very quickly without any limitation. The peak short connection current may reach above 1000A. Unlike lead-acid batteries that are limited by the Peukert’s law(http://en.wikipedia.org/wiki/Peukert’s_law), the LFP batteries do not have any such limitation. However due to the high energy release, the LFP batteries should not be extremely discharged for longer than 10 seconds.
The discharge table for 12V 40Ah LP LiFePO4 battery
20 A current - min. 120 minute use (2 hours)
40 A current - min. 60 minute use (1 hour)
60 A current - min. 40 minute use
200 A - max 10 s. peaks - approx 70 times (7010s = 700 s. ~ 12 minutes)
400 A - max 10 s. peaks - approx 35 times (3510s = 350 s. ~ 6 minutes)
1000 A - max 5 s. peaks - approx 18 times (18*5s = 90 s ~ 1.5 minute)
FAQ: What is the charging voltage of the 12V battery? 16V or 14.4V?
Question: Some web pages and the GWL blog says that the final voltage of the charge for 12 LP battery is 16V. But some other pages and some charger specifications give information about charging to 14.4 ~ 14.6V. What is the difference?
Answer: The maximal charge voltage for the LiFePO4 technology is 4.00 per cells (16.00V per battery). This is the recommended charge voltage for the initial charging to balance all the cells to the same full level. Check the explanation here.
However for the long term use it may be better not to charger to full, but to charge to a lower voltage to get the maximal life-span. For example charging to 3.65V per cell is considered to be around 85% charge. It works very well for 1000, 2000, 3000 and more cycles. That is why some of the chargers (example the TC-Charger models) charge only to 3.65 V per cell (14.6V per battery). See the additional information at this post.
You must charge before the first use!
We remind all users of the LFP cells and LP batteries that the cells and batteriesMUST be charged to full voltage level BEFORE assembling into a pack and before starting to be used.
For the 3.2V cells, the full charge voltage level is 4.00V and the charging isdescribed here. For the 12V LP batteries the full charge voltage level is 16.00V. More details about the use of 12V batteries is here. (Check also the section about the 12V LP batteries)
Even in simple installations, it is important to make the first charging. Example: when assembling a 48V pack using 4 pieces of 12V batteries, it is very important to charge all batteries to the same voltage (16V) before assembling the whole pack. Only after the batteries have been balanced to the same voltage level, it is possible use them as a pack and to charge the whole pack together using the 48V charger.
Please remember: FIRST CHARGE, THEN USE!
FAQ: Can LiFePO4 cells be charged with impulse DC current? (Most lead-acid batteries prefer to be charged with trickling currents – which increases their lifespan.)
Answer: With LiFePO4 cells it is possible to charge with non-impulsive DC current. There is no study or a test report known to us that would show any advantages of impulse current charging against the standard flat current charging. Based on comments from LFP cells suppliers, as far as possible the cells should be charged with continuous (non-impulsive) DC currents.
FAQ: Do we need to install a temperature sensor to monitor the charging of the cells?
Answer: Certainly it is wise to install temperature sensors as secondary protection during the cells operation. Each cell should have its own sensor. During the standard operation all cells should have identical temperature corresponding to the temperature of the surrounding environment. The LFP cells do now get significantly warm during regular operation (standard charge/discharge at 0.5C and less).
If the temperature sensors show a temperature difference of one or more cells (even if the difference is just a few degrees), it is suggested to inspect the operation of such cells to find out the reason for the temperature increase. It is to better to locate a possible problem before the cells may get damaged for some reason.
Q: Please explain how you can charge a cell to 4.00V volt. And why some people suggest charging to 3.65 Volt.
We recommend to reach 4.0V for the initial charge. The 3.65V is a usual charging level for the regular operation of the cells. This means after you make the initial charge to 4.00V you continue to use the cells and charge to 3.65V (or 3.80V or some similar level) for the regular operation. Simply said charging to a lower level will extend the cell’s total life span (in number of cycles).
FAQ: Can I connect a charger permanently to the battery?
Such connection is not recommended and may not work properly. There are several reasons.
The danger of deep discharge of the battery after the charging is finished.Most chargers have some minimal consumption when connected to the battery. If the charger is left connected for a long period of time, the charger may discharge and deplete the battery completely.
Need to reconnect to resume function. Most chargers need to reconnect to resume the charging function. If the charger is connected permanently it will not resume charging unless the terminals are disconnected for some time and connected again.
The danger of an accident. The charger’s electronic may not be designed to be permanently connected to the battery if not charging any longer. After some time some components may overheat or become defective. In any case, we always recommend having proper fusing and disconnection option for any cabling connected to batteries. This allows disconnecting the batteries in case of an accidental short circuit connection or malfunction.
An idea: to allow repeated charging of batteries without the need for manual reconnection, the hint may be to use some timer device that will connect the batteries to the charger to allow the charging. However again we give the warning, that any battery charging must be properly monitored by a human operator.
FAQ: Can a battery be charged when being discharged?
Answer: If the charging current is higher than the discharge current, it is possible to charge the battery when being under load. When charging the charging current will be first consumed by the load and only the current in extra will be used to charge the battery: Example: the discharge current is 4 Amps, the charging current is 5 Amps. The effective charging for the battery will be the difference: 1 Amp.
FAQ: Replacing the SLA batteries
I want to replace the lead acid 12V 100Ah stating battery. Which LFP model can I use?
Answer: The performance of the LFP batteries concerning the starting current is excelling the performance of the SLA (lead-acid) batteries. Our tests and the tests of our customers show that the LP12V 40Ah battery can replace any SLA starting battery (even the 100AH, or 150 Ah models). Even big diesel machines can be started from the LFP battery at very cold weather.
For long term use and massive deployment, we suggest to make testing for each application to make sure that the replacement LFP battery will work properly for long time.
FAQ: charging multiple 12V batteries
FAQ: Can I charge multiple 12V batteries in series at the same time with one charger? (i.e. 2 batteries for 24V, 3 batteries for 36V, etc…)
Answer: Yes, it is possible to charge a battery pack consisting of multiple 12V batteries in series at the same time using one charger. However following needs to be observed:
The initial charge – you need to charge all the 12V batteries individually to full voltage level BEFORE you start using them together as a pack.
We strongly recommend to use some kind of management to make sure all the batteries are working within the proper operating voltage levels. For examplethe Akumon may be used to monitor the status of the batteries.
Additionally we remind the need to observe the general instructions concerning the use of the 12V batteries.
FAQ: Which to use: the 12V LP batteries or the 3.2V single cells?
Answer: Single cells built into packs with BMS allow for a deeper cycle, and faster charging and discharging cycles, as it is possible to charge/discharge the pack according to the lowest voltage of the cell in the pack (the weakest cell).
The “mono block” 12V LP batteries should not go deep bellow 11V (under load). These 12V batteries work similar to the standard 12V SLA batteries, where there is no user access to the individual cells.
The LiFeYPO4 technology has progressed over past few years, and the cells are significantly stable and performance-identical. This allows for the production of the “mono block” 12V LP batteries.
The simple guide-lines to help to choose between single cells and 12V blocks
We suggest to go for the individual cells with BMS monitoring and management:
• if you need high speed charging or discharging (let us say faster than 0.5C = 2 hrs)
• if you need full (deep) cycle discharge (and cannot use a larger battery to get a flat cycle)
• if you need technically to guarantee an extremely high reliance of the total solution. (e.g. a backup power supply used for the critical equipment in a nuclear power-plant) In this case you may need to have a dual BMS system, please read our suggestion here.
• for high voltage solutions DC (above 140 Volts)
We suggest to go for the “mono block” 12V LP batteries :
• if you do not need speed charging or discharging (let us say slower than 0.5C = 2 hrs)
• especially suitable for power backup solutions, when the battery is not used very often
• good solution for small traction systems (up to 144V)
• suitable for replacement of the starting batteries in gasoline engines
• if you wish to reduce the overall costs of the solution
Please note that the monolithic 12V batteries do not have any PCM (Protection Circuit Module - any electronics) inside. The consist of finely balanced cells with identical perfomace at the standard operating range of 11V to 16V.
The management of the battery must be done outside. We offer the 12V Akumon to provide the management and balancing solution.
FAQ: Battery deeply discharged – what to do?
By mistake I have deeply discharged the 12V LP battery. When I discover this situation, the voltage of the battery is < 4 Volts. How can I restore the battery?
Honestly, there is no way to restore the LP/LFP cells and batteries if there were deeply discharged. (Bellow 2.5V per cell or 10V per 12V battery.) If the battery is deeply discharged the internal structure of the cells is damaged. There is no way to get the battery back. The battery must be replaced with another battery.
Trying to charge this kind of empty battery will only result in even bigger damage and the battery will swell and release the gases! Never try to “correct” the problem by swift charging!
The only option is to disconnect the battery and wait for some time (hours/days) to see if the voltage returns back to the minimal level. If the voltage returns by itself, there is still hope that such battery may be charged. However this charging must be done with very small currents (0.1C or less) and the charging must be monitored. If the voltage does not return and stays low, the battery is dead.
markmm   100 mW
Post by markmm » Sep 24 2018 4:54pm
pretty sure I ordered most of mine from here:
headway 38120S 10Ah LiFePO4 cell
EV Components
http://evcomponents.com/
smithmal   1 mW
Post by smithmal » Oct 02 2018 9:10am
Mark,
Thanks for all the info. There is little to no build data regarding people making DIY 12V batteries using 38120 batteries so this thread is very helpful. The link above for the GWL 12V/90AH product is very interesting (around $570 shipped). I'm assuming since you bought 38120 batteries from them they ship to the US. GWL indicates this is a "monolithic" battery which does not require a BMS (unless you buy two and want to use them in parallel). Does anyone have any experience with this company?
In terms of 38120 batteries, around $20 looks to be the going price. Similar to you, I was interested in using them to build a DIY trolling motor because they are 3.2V (which would make them close to 12V when in series) and they are known to be very safe and stable. More about them can be found in this video (https://www.youtube.com/watch?v=MdhyOFeOqyE). In terms of quality, were you ever able to confirm that GWL's stated capacity of these batteries (8Ah) before adding them to your battery array and if so, were they "as advertised."
There are now 10Ah 38120 batteries, and if I've done my math right, I believe I would need to build a 4s10p battery (i.e. 40 batteries) to create a 12V 100Ah battery. That would make the build cost at $800 for the batteries alone. At that price, I might as well buy an off the shelf solution which comes with a manufacturer warranty.
I would think a DIY solution should be at least 50% off what can be purchased @ retail. Can anyone think of a DIY battery solution for a 12V 100Ah battery that would be sub $300-$400 range in parts?
Thanks,
smithmal
e-beach   1 GW
1 GW
Location: Any Los Angeles area beach I am at. Or Santa Monica or possibly the south bay beaches.
Post by e-beach » Oct 02 2018 9:54am
smithmal wrote:
Oct 02 2018 9:10am
........Can anyone think of a DIY battery solution for a 12V 100Ah battery that would be sub $300-$400 range in parts? ....
2 100ah deep cycle lead-acid batteries from the auto parts store or walmart. Probably won't last as long as lithium, but it is in the price range.
:D
Favorite Quote: "This is L.A., sugar. There is no 'over the top." --- Chris Erskine
Current build: Liahona w/ cheap front suspension and suspension seat post. Yescomusa 36v 800w generic front hub motor. 15ah Headway triangle mounted pack. Tronsung 30 amp,
Previous Build:1992 Trek Antelope 800 - Bone Crusher (no suspension) - Yescomusa 800 watt 36 volt front wheel kit. Don't do it! Get suspension!!!
