Hailong pack build, 13s4p Samsung 30Q
Overclocker   1 kW
Post by Overclocker » Apr 04 2017 10:36pm
This is a slim case but I'll be using this pack w/ a 45A controller which needs a bigger BMS than would normally fit. So some surgery is needed. I also decided not to use the 52-cell carrier to create more space
Section removed to create a flat surface. That's white PVC bonded to the Hailong w/ PVC cement. The Hailong seems to be ABS so it should be a strong bond.
In progress...
Empty case: https://www.aliexpress.com/item/Free-Sh ... 12527.html
BMS: https://www.aliexpress.com/item/Electri ... 13150.html
ePassionHomebrew   10 µW
10 µW
Re: Hailong pack build, 13s4p Samsung 30Q
Post by ePassionHomebrew » Apr 06 2017 6:19am
Good luck with the build mate. May I ask where did you source the empty Hailong case from?
redilast   1 kW
Post by redilast » Apr 08 2017 12:23am
ePassionHomebrew wrote:Good luck with the build mate. May I ask where did you source the empty Hailong case from?
Probably aliexpress. Like <$40 for the case shipped i think.
Overclocker   1 kW
Post by Overclocker » Apr 12 2017 7:04am
i'm trying a new end terminal design. the center part is thicker nickel (which i can't weld directly onto the cells)
Overclocker   1 kW
Post by Overclocker » Apr 12 2017 9:23am
40A test:
teslanv   100 MW
Post by teslanv » Apr 12 2017 9:47am
I like that load tester. - Looks home made. What kind of resistor coils did you use?
DD Hubs, Batteries, Controllers & Custom Ebikes.
http://westcoastelectrics.com
West Coast Electric Cycles
Bellevue, WA
USA
Overclocker   1 kW
Post by Overclocker » Apr 12 2017 9:52am
teslanv wrote:I like that load tester. - Looks home made. What kind of resistor coils did you use?
nichrome wire on aluminum angle bar
kocetoMR   10 W
Post by kocetoMR » Apr 12 2017 12:47pm
Can you give us more info and pics about load tester. :shock:
How thick is Nichrome,,how many ohms is one coil?
what kind of spot welder use?
vex_zg   100 W
Post by vex_zg » Apr 13 2017 6:12am
Are you saying that nickel is glowing hot at 40A? At 5A my .2mm x 10mm nickel was basically room temperature.
BeckRFuture   1 µW
Post by BeckRFuture » Apr 13 2017 8:59am
Man that pack looks so clean. Best wishes on it.
fechter   100 GW
Post by fechter » Apr 13 2017 9:13am
Nice job with the nickel strips. That's a really good layout.
You could toast marshmallows while doing that load test :wink:
Did the cells get hot doing that?
Overclocker   1 kW
Post by Overclocker » Apr 13 2017 11:13am
0.8mm nichrome. just play w/ different lengths to get the desired results. if too long the resistance is too high and you'll need to use too many in parallel. but if too short the nichrome overheats and goes limp
JP Welder by riba
Overclocker   1 kW
Post by Overclocker » Apr 13 2017 11:18am
fechter wrote:Nice job with the nickel strips. That's a really good layout.
i made a burrito for dinner. was really tempting to use it to grill the tortilla :)
i only ran it at 2000w for a couple of minutes, just to check for hotspots in the nickel
sacko   10 kW
Post by sacko » Mar 12 2018 10:07am
Excellent looking build. Has the case held up?
There seems to be a few stories of the Hailong case breaking etc. I have still ordered one though...
