methods
1 GW
From phone on plane...
Brainstorm only no links.
I came back around to this why studying for interviews. I was reviewing the difference between Watts and Volt Amps (same thing really... Just one emphasizes the factors to respect individual current and voltage limits) - anyhow...
Long ago a non-paying customer requested a "quick charge box" that he could plug into a standard NEMA 5-15 to charge a cell phone auxiliary pack as fast as possible.
You may be wondering why this does not exist.
It is possible, easy really, but it requires some understanding.
We will use round numbers for this and assume the following:
* Wall can provide 1kw continuous, About 100V and 10A
* Cell phone battery is about 10wh
* Some modern lithium can charge at 10C
* 1Ah is about the smallest high C charge rate we can easily obtain.
The reason we need to respect VA is due to voltage charge limits and current charge C-Rate Limts. A cell phone is say... 4V @ 2.5Ah, 1C or maybe 2C... Possibility 3C. At best that is a full charge in 20 minutes. I wish to lower that by an order of magnitude.
10wh...
To collect that much in 6 seconds with a 1S battery would require 250A charging
(2.5A for an hour @ 4V... So... 25A for 6 minutes)
(That's 250A for about half a minute)
That equates to a 100C charge rate btw... Which is not yet currently possible.
We can draw the 1kw off of a plug.... But extreme buck would be required to turn the 100V 10A into 4V 250A... not reasonable at all.
So... Since we are keeping the mind busy and productive... Let's work orders of magnitude for the trivial solution.
If we increase our battery voltage to 40V we would need only 25A
If we run a 100V battery we would need only 10A for less than a minute.
Proof:
We need to transfer 10Wh
100V @ 10A transfers a kw in an hour, 100wh in 6min, and about 10wh in under a minute.
There is no shift required in voltage... A simple full bridge rectifier would do it.
One would need to rail current to 10A, peak and average
By using a very high voltage battery you can overcome C-rate limitations.
By matching battery voltage to Maine power you can significantly simplify and lower charger cost.
You would need a BMS on this 24S 1Ah brick... But it would be very compact overall... About 1/8th the size of a standard 24S 10Ah ebike pack.
Charger would be fanless solid state meant to run only 30 seconds and get hotter than hell.
Charger would be the ugliest form of feedback CC with huge ripple
We would incorporate a 5V USB adapter... To slowly transfer energy to the phone.
30 second full charge for a smart phone.
To make it worth the investment... User has 100X capacity margin for those times when more than 30 seconds are available... Meaning ... You could easily store 100 cell phone charges in the pack... So 100 days inn the road without a charge.
Ok - so we only accepted 1Ah due to C rate limitations, wall standards, and availability.
What if we did it with ultra low ESR caps... And only 10wh worth?
100V * C/3600 = 10wh
360F of 100V low ESR?
Meh... can't be right.
Ok, nap time.
All I smell is half chewed peanuts and stale farts.
Even SJO main lobby smelled like hot farts are 5AM this morning...
Final Answer?
In the not so distant future we will all be carrying at least 100Wh on us at all times so don't worry about it. Capacity will just be required to maintain our trajectory (picture goggles... And people zoned out everywhere... Or at least augmented glasses... It's coming FAST, it will be).
And who does not want a 70,000 lumen LED flashlight to blind bad guys???
(Make a good directional stun weapon)
-methods
10wh...
Proof:
Ok, nap time.
Final Answer?
-methods
