kWeld - "Next level" DIY battery spot welder
garolittle   1 kW
Re: kWeld - "Next level" DIY battery spot welder
Post by garolittle » Jun 08 2020 8:30pm
serious_sam wrote:
Jun 08 2020 7:26pm
Sounds about right. You could try with partially discharged packs. That might lower the available current enough to get below the limit.
Thanks again. That actually gave me an idea. Would tungsten electrodes be an option since they have higher resistance? That may put me under the 2,000A limit but still provide enough current to weld copper strips. What do you think?
tatus1969   1 kW
Post by tatus1969 » Jun 09 2020 5:23am
garolittle wrote:
Jun 08 2020 7:08pm
I think I know the answer but I wanted to ask in case I’m wrong. Tonight I was spot welding .25 mm nickel plated copper strips (about 65 - 75 joules). I was curious why I encountered an “over current” message when I used two Lipo batteries in parallel instead of using just one Lipo battery. I have successfully spot welded pure nickel strips (i.e. no copper) many times using one Lipo battery and also using two Lipos connected in parallel but I have never encountered an over current message. My theory is that the nickel plated copper has much less resistance and therefore using two Lipos in parallel triggers the error code. What do you guys think?
I'd say your theory is spot on, the copper strips have significantly less resistance and push the current above the limit. I'd also try using partially discharge batteries first.
Resistance is futile - We Are The Watt.
serious_sam   1 kW
Post by serious_sam » Jun 09 2020 5:46am
garolittle wrote:
Jun 08 2020 8:30pm
Sounds promising. They'll get hot much quicker than copper electrodes, so your holder will have to have good insulation.
garolittle   1 kW
Post by garolittle » Jun 09 2020 8:26am
tatus1969 wrote:
Jun 09 2020 5:23am
Thanks Sir and thanks again for making such an awesome product! :thumb:
garolittle   1 kW
Post by garolittle » Jun 09 2020 8:27am
serious_sam wrote:
Jun 09 2020 5:46am
I will try and report back. Thanks for the response.
No_Shorty   100 mW
Post by No_Shorty » Jun 15 2020 10:07am
spinningmagnets wrote:
Apr 17 2020 11:29am
I doubt it, Al melts at 1221C (2230F). Stainless is roughly 1440C / 2624.
Once you get up to the temps to make Al plastic, the stainless is still only warm. If you get the stainless to melt, the Al will likely blow out much sooner.
Most of the 18650 cells have a shell that is nickel-plated steel, so the nickel bus-strips are welding nickel-to-nickel. Of course, there might be a method or technique that might work with the right tools. I just don't know.
Not that I know anything about it, but I had been Googling Aluminium melting temp earlier today for another reason and the answers I got were 5-600deg for most Al alloys.
garolittle   1 kW
Post by garolittle » Jun 20 2020 7:13pm
Would the resistance reading after a spot weld be a good proxy for the resistance of the material being welded (assuming the strips are identical in size and are being spot welded to the exact same battery)?
I had success in spot welding two different materials (SigmaCLAD and “Nickle Silver”) using the Kweld. The materials are similar in thickness so I obviously want to use the one with the least resistance. I tried to measure the resistance of both materials using a multimeter but could not get a good reading. It may be an over simplification but it seems like the resistance reading after each weld would answer this question. Thanks for any suggestions or responses.
ossivirt   10 W
Post by ossivirt » Jun 21 2020 1:13am
garolittle wrote:
Jun 20 2020 7:13pm
You can also try spotweld pulse with long strip. Like 10-30cm or so with electrodes on oposite ends without a cell. That could give most accurate results regarding resistance difference of different materials. I did this with 0.1 and 0.2 copper but I did not compare the readings, just felt how hot it would get :lol:. However that "new" antispark function that was added after that test may kick in and not give good results :roll:
garolittle   1 kW
Post by garolittle » Jun 21 2020 11:22am
ossivirt wrote:
Jun 21 2020 1:13am
Very clever idea. I will try it. Thanks for the suggestion
garolittle   1 kW
Post by garolittle » Jun 22 2020 12:23am
garolittle wrote:
Jun 21 2020 11:22am
ossivirt wrote:
Jun 21 2020 1:13am
Yep. It worked. It makes sense because the only variable is the material being spot welded. Here are the results:
Setting for each spot weld: 50J
Length of each strip: 3”
Width of each strip 9.1mm
Results:
“Nickel Silver” .25mm thick: 1.70mR
Nickel plated copper .25mm thick: .65mR
Basically the same results after several attempts.
tatus1969   1 kW
Post by tatus1969 » Jun 22 2020 5:07am
garolittle wrote:
Jun 22 2020 12:23am
garolittle wrote:
Jun 21 2020 11:22am
ossivirt wrote:
Jun 21 2020 1:13am
Results:
Interesting idea :-) Don't expect too accurate results please, as kWeld isn't a precision istrument. I use to measure low resistances with a bench power supply and a multimeter: set the supply to as much current as possible and connect it to the ends (I have decent crocodile clips for that). Then use the multimeter in millivolt range and probe across a known length, anywhere on the nickel strip that is carrying the current. Divide measured voltage by given current, and you have the precise resistance for that length.
garolittle   1 kW
Post by garolittle » Jun 22 2020 7:13am
tatus1969 wrote:
Jun 22 2020 5:07am
I will try that. I really appreciate the suggestion. I appreciate the Kweld even more. It is simply awesome. :-) Thanks again.
Alex_uppfinner   10 µW
10 µW
Post by Alex_uppfinner » Jun 27 2020 2:42pm
Hello!
I would just like to say that I am very happy with the results of using the kWeld, even just with a LiPO-pack as power source.
All welds (most at 35J for 0.15mm some @ 85J for 0.25 mm) were good. Built my first own battery (5P16S) without any issues.
Se relevant build thread: viewtopic.php?f=6&t=107007
/Alex
garolittle   1 kW
Post by garolittle » Jun 28 2020 4:36pm
It is an amazing product isn't it? Welcome to the Kweld World. :)
SubnetMask   1 mW
Post by SubnetMask » Jun 28 2020 11:41pm
garolittle wrote:
Jun 28 2020 4:36pm
Absolutely. I haven't used mine much yet because I've been awaiting the delivery of a MegaCell Charger to allow me to do better charging and testing than my LitoKala charger can do before I build more packs, but what I've done, right out of the gate, it was orders of magnitude better and more consistent than the Suckko spot welder I had tried before. The Suckko welder COULD NOT do .2mm nickel. Look at it hard and it would pop off. Even .15mm nickel plated steel was somewhat iffy. The kWeld? No problem. It is rather amazing that something powered off 120v mains is junk and something powered off (in my case - I charged my 3s packs, which I ran in a 2p config, up to 3.8v per cell in order to provide ample current but try to minimize the abuse to the cells) 11.4v batteries blows it out of the water.
garolittle   1 kW
Post by garolittle » Jun 29 2020 6:40am
Yes sir. That’s the difference. Excellent engineering of the Kweld
dejanc   10 µW
10 µW
Post by dejanc » Jul 02 2020 12:58pm
I would like to ask users of kWeld, how is the status of heat, working temperature?
I do not see any sink heaters, or fan?
Thanks for answers...
ossivirt   10 W
Post by ossivirt » Jul 02 2020 1:53pm
dejanc wrote:
Jul 02 2020 12:58pm
Never had any issues with the unit itself. Electrodes on the other hand get too hot to handle without gloves if pulse energy and time between welds dont allow enough cooling.. Unit has temperaturesensor and will protect itself if needed.
Edit: Next time I have to try with welding gloves :lol:
garolittle   1 kW
Post by garolittle » Jul 03 2020 11:58pm
dejanc wrote:
Jul 02 2020 12:58pm
Wear a good pair of gloves and point a fan at the pack and the cable holders while welding. Take short breaks to let things cool off. Also, some people use electrode cables a large as 4AWG which reduces heat.
agniusm   10 MW
Post by agniusm » Jul 05 2020 5:03am
Ordered this unit for the odd jobs i have. Was wondering how many weld you get out of 5ah lipo?
flippy   1 MW
Post by flippy » Jul 11 2020 1:41pm
agniusm wrote:
Jul 05 2020 5:03am
just keep a dumb charger on it and keep it floating at 4V per cell.
Lithium beats liquid dinosaurs.
agniusm   10 MW
Post by agniusm » Jul 17 2020 8:10am
Received mine:
garolittle   1 kW
Post by garolittle » Jul 17 2020 9:19am
agniusm wrote:
Jul 17 2020 8:10am
Received mine:
Looks good. Get ready for the best spot welder you have ever used:-)
ridethelightning   1 MW
Post by ridethelightning » Jul 20 2020 8:11pm
Looks great!
agniusm   10 MW
Post by agniusm » Jul 21 2020 2:11am
Have to confirm that the welder is brilliant. Very minor thing, but would be nice to have welded studs for input output wires(nut on top)
Welds are very good and i like the "charging" pitch audio feedback on Auto.
