kWeld - "Next level" DIY battery spot welder
Portugaline   1 µW
Re: kWeld - "Next level" DIY battery spot welder
Post by Portugaline » Jul 23 2020 1:30pm
Hello people,
I made an order on the website, anyone knows how many days it usually takes to be sent?
eee291   100 kW
Post by eee291 » Jul 23 2020 4:04pm
These are unusual times, also it depends on where you live.
garolittle   1 kW
Post by garolittle » Aug 04 2020 2:37pm
So I am about to start spot welding a 22S/20P pack. I have read the discussion threads regarding cleaning the electrodes and battery cell surfaces and I think I am all set. Most people recommend fine grade sand paper to keep the electrodes clean but what is the best cleaning method for the cells? I will be using brand new INR Samsung 25R cells but I want to make sure the weld surface (ie. anode and cathode surface) is as clean as possible. Thanks again for all the great advice on this forum. Gary
flippy   1 MW
Post by flippy » Aug 04 2020 3:00pm
use a few taps of 80+ grit on the tips every 100 welds or so. just clean the cells with IPA before putting the nickel on.
Lithium beats liquid dinosaurs.
garolittle   1 kW
Post by garolittle » Aug 04 2020 5:15pm
flippy wrote:
Aug 04 2020 3:00pm
Excellent. Thanks!
Tommy L   100 kW
Post by Tommy L » Aug 27 2020 8:24pm
I got mine today!!!!
I assembled it....
Now trying to learn about powering it.
I have lots of 5p4s LiFePO4 packs A123
12.8v nominal 9.6ah. I’ve tested these packs with no voltage sag up to 5-7C (45-65amps). All parallel groups hold at 3.2v.
I’ve read the Kweld manual of 4-30v For supply but I’m reading through this thread that 12v is best.
Anyone have a guess of how many I need in parallel???
I believe the pulse CCA at either 250 or 400CCA for 10 seconds.
http://www.rawvelocity.com
- 4th Hoolagan FS Mtn 9C-2810 with 128v nom 9.2ah A123 40S40P(1.2Kw) - Lyen 18Fet 4115 - 77.8kph :)
http://endless-sphere.com/forums/viewto ... =4&t=39480
- 3rd Catrike 700 Bionx PL350 Velo build
http://www.youtube.com/watch?v=rYdnkaAhVtI
- 2nd 150lbs Pusher Trailer
http://www.youtube.com/watch?v=Q1qTc4sjORY
- 1st Sears NS mtn bike - Rigid 10a drill 800rpm - 2 12v AGM - 1000 watt inverter - 600w dimmer for throttle, wicked torque!
48.2mph/77.8kph Club
garolittle   1 kW
Post by garolittle » Aug 27 2020 10:03pm
Here is how we power it.
Tommy L   100 kW
Post by Tommy L » Sep 01 2020 9:56pm
testing right now. My two LiFePO4 12.8v nom 9.6ah in parallel are doing consistency at 90 joules 1200 amps
Nickel under in center (to simulate cell top)
then nickel on either side on top with copper sandwich between
I’m happy.
https://drive.google.com/file/d/19Fz66 ... p=drivesdk
https://drive.google.com/file/d/1nOnx2 ... p=drivesdk
Tommy L   100 kW
Post by Tommy L » Sep 03 2020 10:00am
0.1mm copper
0.2mm nickel
90 joules 1150-1200 amps
Looks a little hot, but during tests, this is where
Good adhesion is.
https://drive.google.com/file/d/1-K7nL ... p=drivesdk
ossivirt   10 W
Post by ossivirt » Sep 04 2020 7:57am
Tommy L wrote:
Sep 03 2020 10:00am
0.1mm copper
0.2mm nickel
Good adhesion is.
90 joules sound like a lot to me. I think I used 50-60 just for 0.1mm copper. It is not very strong weld since the material is just too weak by itself. You should try thinner nickel and thicker copper. Also if you have more batteries you should try to ad one more paralel so weld current goes up to 1500-1800A and that gives you shorter pulse times what means in copper welding that more energy goes to weld and less for heating the copper around the weld. I bet you can turn down joule setting with more current and get same results and less hot electrodes..
Tommy L   100 kW
Post by Tommy L » Sep 04 2020 12:13pm
ossivirt wrote:
Sep 04 2020 7:57am
Good adhesion is.
[/quote]
Ahhhhhh this sounds like an awesome tip!!!
Yes my electrodes get hot. Time to try 3
12.8v nominal 9.6ah LiFePO4. I’ll do some tests.
Thank you 🙏🏻 so much
Tommy L sends.
Tommy L   100 kW
Post by Tommy L » Sep 05 2020 9:07pm
ossivirt wrote:
Sep 04 2020 7:57am
I put another battery in parallel just now!!!
Three 12.8v nominal 9.6ah LiFePO4 in total.
You are absolutely correct. 60 joules and reads
1515amps. Electrodes are cooler!!!
You sir are a godsend 🙏🏻🙏🏻🙏🏻🙏🏻
Greatly appreciate your efforts in helping me.
ossivirt   10 W
Post by ossivirt » Sep 06 2020 2:49am
Tommy L wrote:
Sep 05 2020 9:07pm
ossivirt wrote:
Sep 04 2020 7:57am
No problem. You might be able to use even 4th battery in paralel but that could be very close or over 1800A that is max recomended I think. I have not tested the nickel over copper method but 0.1 to 0.15mm nickel should be thick enough and cheaper and even easier to weld.
Edit : After changes in battery or electrode setup its recomended to recalibrate the welder from the menu..
Edit2: kweld has setting caled kable lenght. Check that that is also correct in case your battery changes make your wiring longer. Long wires mean more inductance and that can break the welder so maximum allowed current decreases with wirelenght. Check the manual for that..
hallkbrdz   100 W
Post by hallkbrdz » Sep 08 2020 7:58pm
tatus1969 wrote:
Apr 23 2020 4:23am
I haven't used Pb batteries myself, but have collected feedback from other users on the kWeld product page. A 65AH battery (the 'normal' size for cars, likely also your Subaro) seems to be in the 1000A region, and larger 100AH models are around 1400A.
:warn: :warn: Can I make a poll from you guys using the welder with a starter battery? If you tell me model / age / reported current by kWeld, maybe along with a picture, then I would share that info for others.
Using a single used H8 AGM battery with two 2 gauge 15 inch starter leads (what I had in the drawer). The batteries are rated new for 1000A for 10 seconds at freezing, or 95Ah total. The used ones are still plenty strong to quickly turn over a v10 diesel engine. I calibrated trying to adjust the lengths to match what 8 gauge leads would be (roughly 195mm plus the welding leads), so 1.0m. That worked. Current from short showed 1679A with the used battery.
Welding 0.2mm nickel to some scrap 0.52mm copper plate took 80J consistently. No issues whatsoever.
Then I tried the 0.2mm nickel with 0.8128mm copper plate and I couldn't quite get a strong weld. Last successful was at 150J, 158ms and 1649A. Then I tried 175J and got a timeout. That copper thickness will be for most of my bus bars on the pack (nickel copper sandwich).
After that I will also need to spot weld 0.2mm nickel strips to 2mm copper plate as well.
Given that I can try:
1. Paralleling the second H8 battery to double the amperage, with the battery leads about the same length.
2. Change to a different energy source / and or add a cap bank.
Recommendations?
EKartGo - Building a kart for 100cc TAG competition :es:
ES thread viewtopic.php?f=34&t=107963
KartPulse thread https://forums.kartpulse.com/t/ekartgo-project/5857/1
Bryan
hallkbrdz   100 W
Post by hallkbrdz » Sep 09 2020 10:44am
This morning for the 0.2mm nickel with 0.8128mm copper plate I tried 100J and placed one electrode on the nickel side and the other on the opposite side of the copper plate. Better weld, but still not complete. Increasing the strength caused a timeout, so I'm going to try two of these batteries in series (easier to connect physically and a voltage over current advantage).
Bryan
spinningmagnets   100 GW
Post by spinningmagnets » Sep 09 2020 4:02pm
If you are connecting copper to nickel, and there is no cell involved, you might want to consider a microwave-oven-transformer / MOT...I found several 1500W units for free, and if you pay shipping I will send you one.
"Making a Resistance Soldering Unit, and maybe a spot-welder too"
https://www.electricbike.com/resistance-soldering-unit/
The Toecutter   10 kW
Post by The Toecutter » Sep 12 2020 3:28pm
I pre-ordered this(being that they are out of stock at the moment) and whenever they get all the components in stock it will be on the way. I look forward to putting some packs together with it.
I have x96 A123 26650s that I want to make a 24S4P LiFePO4 pack with, and another x150 Panasonic NCR18650GAs on the way which have been stripped from unused packs and are claimed to deliver 95%+ rated capacity, that hopefully will have enough good cells in that order to build a 20S6P LiIon pack with. Planning to use the nickel copper sandwich method.
I think I can get away with using two large 12V AGM automotive starting batteries in parallel as a power supply.
I do not know when I will have everything needed to get to work due to the current series of events. I've been waiting on a 24S LiFePO4 BMS since July and it's been sitting in a warehouse in Indiana since August 5th. I'm tempted to order a vruzend kit that I know is probably going to give me problems, just to get my trike converted to an EV already...
multifrag   100 W
Post by multifrag » Sep 21 2020 6:55am
agniusm wrote:
Jul 17 2020 8:10am
Received mine:
Would you mind sharing the stl files for the casing?
tatus1969 wrote:
May 18 2020 5:22am
I've ordered the kweld with the kcap module. I'm planning on charging the caps with my 60v 5A bench power supply through a murata rbq-8.2/45-d48 isolated DC-DC converter to use as much of available power as possible. Do you think that is a good alternative?
agniusm   10 MW
Post by agniusm » Sep 21 2020 7:40am
agniusm wrote:
Jul 17 2020 8:10am
Received mine:
https://grabcad.com/library/3d-printabl ... der-case-1
gutyex   1 mW
Post by gutyex » Oct 20 2020 4:12am
I have recieved a kWeld, kCap and kSupply yesterday, and am able to successfully weld 0.15mm nickel with it (that's another Sunkko on its way to the big workshop in the sky)
I have set the output voltage of the kSupply to 8.1V without anything connected as described in the manual, and when I connect everything up the the input side of the kCap reads 8.1V but the output side maxes out at 7.66V. Is this expected behaviour? I assumed the output side of the kCap would give the full 8.1V when the caps are fully charged.
