kWeld - "Next level" DIY battery spot welder
ossivirt   1 W
1 W
Re: kWeld - "Next level" DIY battery spot welder
Post by ossivirt » Jan 21 2020 3:37am
Qachi wrote:
Jan 21 2020 3:02am
Silly question but has anyone made up their own supply pack for their kweld using 18650s?
Will likely use a ~65AH car battery most of the time but it would be great to use them for a more portable setup.
On another note, drew this electrode holder up for anyone that may find it useful, shaped to be easily held, one piece and no exposed metal
https://www.thingiverse.com/thing:4117601
Hb powerwall on YouTube used his 18650 powerwall modules that are something like 100p laptop cells.. He also had similar electrode holder but that design has problem that its difficult to keep pressure equal between tips. That can cause sparks and problems..
tatus1969   1 kW
Post by tatus1969 » Jan 22 2020 5:17am
Compoundbike wrote:
Jan 20 2020 2:13pm
I have some problems with my K-Weld. It stopped making welds.. it sparks but the weld is not there.
I checked the battery, calibrated again and again.. however it doesnt weld, any known issues what i can look for ?
That's not much info to diagnose :wink: Can you post all the info that the welder displays after calibration OPEN and SHORT, and after a welding attempt? When you calibrate, please make sure to have clean electrodes for the SHORT step (use fine sand paper to clean them), push the tips together hard, and make sure that you don't get any sparks at all.
Resistance is futile - We Are The Watt.
Compoundbike   10 W
Post by Compoundbike » Jan 22 2020 12:30pm
Ok i will check out at the weekend, when im in my Workshop, thank you.
tatus1969   1 kW
Post by tatus1969 » Feb 17 2020 3:19am
I got notified about an ebay auction of 800x BCAP0650P (new unopened, dated 2007, mix of laser weldable and threaded posts), tempted to purchase them. Anyone interested in these? I'd test them and sell for 6€ a piece.
999zip999   100 GW
Post by 999zip999 » Feb 19 2020 3:58pm
You have a picture or link.
flippy   1 MW
Post by flippy » Feb 20 2020 1:47am
tatus1969 wrote:
Feb 17 2020 3:19am
i would buy a dozen
Lithium beats liquid dinosaurs.
tatus1969   1 kW
Post by tatus1969 » Feb 26 2020 1:19pm
The Maxwell caps arrived last week, I have got roughly 800 of them and have put them up in the shop: https://www.keenlab.de/index.php/product/bcap0650/
I am currently doing measurements with them, but so far they appear to be in perfect condition. Measured internal resistance is approximately 0.5 milliohms (!) at 50A test current, which is quite a bit lower than their rated "initial max" of 0.8 mR. Scope screenshots and my setup attached to the post. Capacitance is spot on, leakage current is ongoing (I need to wait a few hours to allow the voltage settle)
Very important: this is the laser weldable variant, which either needs a bit of creativity or a decent welder to attach bus bars or cables to them. Andrew from hiketech (my AU reseller) plans to do tests with his TIG welder, but if you are fine with this hardcore DIY route then a few of them in series (4S should be optimal) would make up a very decent pulse power supply for kWeld. Or, some other kind of project that needs lots of current - the combined short circuit current of all ~ 800 cells that I have here is 2,720,000 amperes 8) 8) 8) 8)
flippy   1 MW
Post by flippy » Feb 26 2020 2:38pm
tatus1969 wrote:
Feb 26 2020 1:19pm
if only there was some way to spot weld tabs on these things.... :roll: :mrgreen:
