Blondebeard
- Joined
- Jun 22, 2017
- Messages
- 3
So, I've built a 48v scooter that rips around great (Running on Lead Acid 12v 7.2ah batteries). I have a sound knowledge of how to put it all together, I've just never messed around with Li-ion batteries before (let alone configuring them to be super awesome).
Goal:
I'm looking to put together an actual town driving eBike. I happen to have found a source for LGABD21865 Li-ion cells. I've got about 70 so far. These are coming from new unopened and unused packages. So I could assume they're new. I was hoping to either make a 13s5p or I guess I can go higher if I wanted to(14s5p?). I've been looking into arduino spot welders https://malectrics.eu/product-category/arduino-spot-welder/, however I've come across these guys @ VRUZEND https://vruzend.com/product-category/battery-kits/. Are these useable? Also they offer BMS's https://vruzend.com/product-category/bms/. All that is great and assuming they work fine, I just have one problem... What's the best charger to use to charge these puppies once they're locked into configuration? Keep in mind I'm attempting to build this as low cost as possible. My main costs will be the largest hub motor I can buy, motor controller and Battery charger.
So to summarize:
1. Are the VRUZEND battery mechanism and BMS good enough to use?
2. Should I just invest in a Spot Welder for a similar price?
3. What's the best battery charger for $ ratio? (Just something off aliexpress?)
4. Any suggestions on Hub motors etc would be appreciated as well (otherwise I'll be doing the eBay route)
Thanks for any help I really appreciate it.
Goal:
So to summarize:
