helpfulguy
First project to learn make battery packs.
I'm want to tinker together a simple replacement for 12v 5Ah SLA motorcycle starter battery using 18650, bms and vruzend becuse i dont have spot welder. Can solder but I suck big time. Starter motor is ~400w - calculating 600w for margin/light bulbs before engine start etc, ie 50A max draw. Generator power is ~250w (?) regulated/rectified to stable voltage somewhere between 13,5v-14,5v.
I'm thinking 2,5Ah+ is enough because of peukert effect. I'm thinking get 3s 18650 and maybe 2p - because not sure 1p can deliver 50A burst 3-10 sec (when 30-35A cont). I'm thinking a BMS board with same charger/discharge leads (there are bms with separate charge and discharge), for simple plug and play - SLA compatibility is crucial requirement.
So:
3 or 6 (2p) of these https://eu.nkon.nl/rechargeable/18650-size/sony-konion-us18650vtc6-3120mah-30a-met-button-top.html
1 pack vruzend (better alternatives? dont have spot welder)
1 http://www.ebay.com/itm/12V-3S-100A-PCM-BMS-same-port-of-charge-discharge-balance-for-Li-ion-battery-/282449011803?hash=item41c345e45b:g5AAAOSwVm5ZAS3Y
1 large shrinkwrap havent found yet, or I just wrap in duct tape because yolo
Is this good - any recommendations or did I miss something?
Question 1: BMS - compatible with the cells?
Question 2: BMS - it wants charging voltage 12,6v - would it handle 13,5-14,5, or do I need to change to another BMS - which one? I can add an additional regulator between generator and harness but really would prefer just swap battery pack and not make incisions in cable harness. More capable bms much preferred even if cost is higher.
Question 3: Will I be able to charge this with regular SLA charger, and BMS cut off when full?
Question 4: Will this be a foolproof pack - ie. will BMS cut off and save cells when too low voltage, when fully charged, and balance and all that?
Question 5: Would 1p be enough? How many seconds on/off starter motor would be doable, for example 3 sec on, 10 sec off? If need multiple tries a cold morning.
Thanks! =)
So:
Thanks! =)
