SniperGaulois
I just plugged in a new BMS to an unbalanced 14s battery, where the groups all have different voltages: 3.8v 3.3v 3.7v ... all the groups have a different voltage from 3.3v to 4.0v, but the batteries within groups are all the same.
I double checked the sequence of the BMS charge wires, and the BMS is acting strange. a row of chips on the charge circuit is going up to 70'C degrees, when it's not plugged into a charger or anything.
Before i noticed the temperature issue, i checked all voltages tried charging it, and the battery terminal voltage went down from 51.5 volts to 50.8v while charging.
What could be causing such weird BMS temperatures and non-charging? it's a new BMS. is there a problem with having groups randomly at 3.3 or 3.9v? will the BMS mulfunction from that?
