Charging a li-ion pack with VRLA Battery charger
desmond007
100 µW
Hi,
I'm making a li_ion battery pack of 48v (13s10p) with BMS. So the charging voltage should be 13x4.2=54.6v.
I have a VRLA battery charger which is about 48v 4A. So my questions are
1. Can I charge the lion pack with it?
2. If yes then will it damage the battery over time?
3. Will it charge the battery to100%?
4. How the BMS will handle the current and voltage?
5. Will it automatically cut off when the battery is full? (that charger have that option on VRLA battery charging)
6. Last, It won't become a atom bomb, right? :shock: :roll: :lol:
Any help will be appreciated..
I have a VRLA battery charger which is about 45v 4A.
What's the empty voltage of the cell? Multiply by 13. Compare to the charger voltage.
You can answer that simply by comparing your voltages quoted above. ;)
You'd have to look at the specs for the BMS and compare them with the charger's output.
odds are good that a 14s pack will work well.
this is because i've used a 7s pack in place of 2 sla's and my float switch is at 28.8v or 4.11/cell which is great to about double cycle life over 4.2.
you do have to sit there ONCE with 2 meters so you can see EXACTLY what it does.
don't know about the bms. i don't like them and don't use them because i don't discharge below 3.7v. and they stay in balance.
13s? maybe a 1 in 1000 chance that will somehow match up, imo.
I think you need to look at his charger's voltage again. ;)
I think Li-ion 18650 cells usually get empty at around 2.75. So 2.75*13=35.75. My charger is 48V. So what you think how much it can put in? 50%? What is the equation to calculate?
I have only written on my charger that it's 48v 4A. Nothing else I know about it. I don't know if its CC/CV or not, don't know if it's exactly put max 48v or higher than that. Also, I can't check it because all my SLA batteries are dead and won't take any charge. This charger also won't start if it's not connected with any batteries or the batteries are not taking charge. Tried to connect it with a multimeter but it didn't start. Do you know how to jump start it without connecting to batteries and measure its max voltage? This charger automatically cuts off when charging is complete.
I think my charger is already under powered for 13s config so 14s won't do much.
My main concern is if I charge my Li-ion pack with this charger (which is designed for only VRLA batteries and maybe not CC/CV), will it eventually damage my cells?
My bms config is something like this
Will it support undercharging rather than 4.2v per cell?
About discharge one thing I want to know, if I discharge via BMS (rather than direct) how the cut-off works? when a cell group reaches 2.7v does it particularly cuts off that cell group and continues to take charges from other groups or it cut off the whole power?
Sonner later I'm considering to buy a new charger for it, (54.6v, CC/CV, 4/5A). I'm concerned about charge cycles. I have read the following
So to increase the battery life if I charge it by a 54.6v charger and stop it when it charges to 80%, will it work? or I have to specifically charge it by 13x4.05v=52.6v charger?
Thanks for your answers..
P.S: Amberwolf, I just read about your dogs and can't imagine it can happen with someone. God must be evil. I had one many years ago, when he was gone I can't get another. Hope you are well and I'm sure they are well also. Good wishes to you brother. Live strong!
VRLA float v is lower than the charge v.
so if you measure the v open circuit, it will be a lot lower. 48v means nothing, other than it is on.
here is a typical reading when charging per 12.6v vrla or sla
12.5-13v 1st stage
14.4-14.5v 2nd stage
13-4-13.6 final float stage.
see that middle v? you have to watch for that while charging the pack from normal discharge, like 3.7v for each 14s! as soon it it reaches full, it switches to low v float. Then you can't get it to repeat unless you run the pack down again.
for 4 vlra stage 2 is about 58v which i like for 14s. around 4.11-4.14 per cell.
the 1 drawback is, you can't do top off charging, only full, like 50% or more charges, so i see this as an temporary charger until you find what you like better.
I'm just saying, if i had it, i'd try it, but i would not BUY it.
You'd have to look at the spec sheet for your specific cells from the manufacturer, to get their charge/discharge curves.
Well, that's probably not the actual output voltage if your SLA pack was four SLA bricks in series. It's probably more like about 58V That's usually what a 14s Li pack would charge up to (about 57-59v depending on chemistry and cell specs).
But it isn't designed to output the right curve of voltage/current for charging Li packs, so it may not do the charging you want it to do, depending on the Li cell chemistry and specs--you'll have to look at those from the cell manufacturer to see if they'll match up. Most likely, it won't matter--it'll probably work anyway, as long as the voltages are right and the current is not too high.
The problem you might have is that if you have a 13s pack, and the charger keeps outputting anywhere near full current up to the top of it's voltage, it'll be a lot more current than the BMS can shunt around the cells, so they'll all get overcharged each time. If the BMS correctly shuts charge off when any cell gets above a certain voltage (4.25v, etc) , then drains down the high ones, that shouldn't be a problem, and would just ensure they always get balanced.
IF the BMS does not shutoff when a cell goes too high, it could potentially overcharge the cells to 4.5v+, which is not healthy for them, and if they are not good cells (or a cell has a problem) could even start a fire.
If it's voltage (or current) output is higher than what your cells can take, and your BMS (if you have one) doesn't prevent overcharge, then yes.
If it's voltage is less than your cells can take, then it probably wont' hurt anything--but if it doesn't get to the point the BMS can balance the cells at, then if the pack is prone to getting unbalanced, the BMS can't fix that.
You can always charge less but most BMS won't balance the cells unless you charge to the balance point.
No, it has to cut the whole pack--there's no way for the BMS to shuffle power around like that.
Depends on the charger--the Cycle Satiator from Grin Tech http://ebikes.ca can be programmed for whatever you want it to do. But it's not cheap.
And again, if you don't charge to the balancing point of the BMS it can't balance the cells. If they don't get out of balance it doesn't matter, but if they do, it does matter, because they get further and further out of balance every cycle, and you get less and less total capacity from the pack, and the low cells are pushed harder and harder each cycle.
You don't have to balance charge every cycle, just whenever they are getting out of balance.
Thanks--it was the hardest time I've been thru so far. I have new dogs now, Yogi and Kirin (there are always more dogs that need help and a home); I do permanent fostering for the local Saint Bernard rescue group (http://www.saintrescue.org/arizona.html) and the dogs help me as much as I help them. I couldn't live without them (wouldn't have a reason to, either).
