Salvaged EV cells index: Leaf, Volt, Tesla, Zero, etc
ridethelightning   1 MW
Re: Salvaged EV cells index: Leaf, Volt, Tesla, Zero, etc
Post by ridethelightning » Apr 05 2018 4:09am
subscribe
themelon   1 W
1 W
Post by themelon » Apr 05 2018 7:54am
Inwo wrote:
Apr 04 2018 6:02pm
Anyone else?
I need one more 8s for someone.
I actually have two of them but they are in my Bolt :D
Inwo   10 kW
Post by Inwo » Apr 05 2018 11:12pm
Text me next time your driving.😁
Headrc   1 W
1 W
Post by Headrc » Apr 07 2018 9:57am
Excellent thread here ...thanks Spinning Magnets
Inwo   10 kW
Post by Inwo » Apr 07 2018 5:19pm
Problem with cell 11 reading high.
Got it under control with a larger awg cable between #10 and #11.
Still get 15mv drop. And that's @ 6a. May have to make a huge bussbar or look for another solution.
Balance leads connected from both packs.
Could that be it?
All leads are 630ma fused. So wire 10+ and 11- have less resistance with parallel fuses.
ps.
Picture is with a small jumper connecting packs. #11 read .5v high with that in place.
miro13car   1 MW
Post by miro13car » Apr 11 2018 8:46am
Few can argue that the best cells for DIY ebike batteries are from salvaged EVs.
I ride on 11S Nissan Leaf battery from 2016 Nissan Leaf -
LiMnO4 41Ah rated cells.
Many here don't know that:
Nissan switched from 31Ah into 41Ah cells , 2-cell modules to 4-cell modules in 2016.
I bought from Hybridauto centre website , cells from written-off 2016 Leaf, millage unknown, where it was driven unknown /maybe in Arizona heat???/
I would love to buy brand new cells or even new Leaf pack but it is not possible unless you manager at Nissan dealership.
own dealership?? You cannot exchange battery from written off Leaf for new one in legal way.
you cannot buy LG Chem pouches whatever capacity also ,
if you know how tell me.
you cannot buy SAFT cells also , they want to design pack for me , means $$$.
any ideas how to get brand new EV cells?
miro13car   1 MW
Post by miro13car » Apr 11 2018 8:52am
again
problem with used EV packs /bolt, volt, Leaf , etc./ that you do not know history of EV , millage cannot be verified if car cannot be turned on.
I am thinking about buying almost new smashed Leaf or Volt.
Easy for you in USA , 90% OF them are in USA , few only in Canada.
travelling thousends of kms to check out crashed car ???
amberwolf   100 GW
Post by amberwolf » Apr 12 2018 12:54am
miro13car wrote:
Apr 11 2018 8:46am
If you mean EV-type cells, large capacity single cells, you can get them from EIG for at least two or three chemistries, but they wont be cheap, and youll probably have to buy a pallet full or more.
A123 cells can be had from A123 (I think thru their Stortronics site).
I dont know if any other manufacturers sell their cells outside of OEM channels.
miro13car   1 MW
Post by miro13car » Apr 12 2018 5:07am
A123 are not considered EV cells , no EV manufacturer uses them , except Fiskar but they gave up on A123 also.
miro13car   1 MW
Post by miro13car » Apr 12 2018 5:11am
which EV, hybrid uses EIG cells?
miro13car   1 MW
Post by miro13car » Apr 12 2018 7:45am
you see by EV cells I mean
cells used in currently manufactured EV.
Before picking particular cell for their packs Chevy, Nissan, etc. /or contractor for them/ did extensive research/tests
As far as I know EIG cells are not used in any mass produced EV.
spinningmagnets   100 GW
Post by spinningmagnets » Apr 13 2018 5:09am
There are hybrid cars that have a mode where they are running with the gasoline auxiliary engine on. However, when they come to a stop-light, the engine is turned off during the wait. When the light turns green, the engine is rapidly re-started.
...The 5Ah LTO prismatic pouch cell, EIG Model T005, is the first of a family of LTO cells designed specifically for markets ranging from the growing 12V and 48V stop-start micro-hybrid vehicle market...
https://www.electricvehiclesresearch.co ... d-vehicles
fechter   100 GW
Post by fechter » Apr 13 2018 8:48am
miro13car wrote:
Apr 12 2018 7:45am
I think they were available only in Japanese versions of the Mitsubishi MiEV.
amberwolf   100 GW
Post by amberwolf » Apr 14 2018 1:17am
I thought Zero Motorcycles were mass produced EVs?
jkenny23   1 µW
Post by jkenny23 » May 11 2018 5:19pm
Anyone know how to decode/identify the model year of a Leaf battery module? I bought one here: https://www.ebay.com/itm/Nissan-Leaf-Ge ... 2896857363 and trying to figure out what year/chemistry it has. Definitely a 2013+ battery, listed as 500WH so 65AH, part number printed on it is 295B9-3NK0A, and the data matrix shows "295B93NK0A0JU412CH04128030NCPCBAC60111NCPCBAC60155NCPCBAC60094NCPCBAC60097".
I also bought 9.8kWH of these batteries: https://www.ebay.com/itm/800-Watt-Solar ... 2897325279 which appear to be from a Hyundai or Kia plug-in hybrid, rated at 68kW discharge for the full pack (or 5.6kW per 8s module), haven't done much testing on it yet other than a quick look over. Plan to install the full 12 modules in my Nissan Leaf as a range extender battery.
miro13car   1 MW
Post by miro13car » May 12 2018 4:00am
jkenny23.
this is 4-cell 31Ah/cell Leaf module so must be prior 2016 .
In 2016 Nissan introduced 8-cell 41Ah/cell modules in Leaf battery.
Also would love to decode those numbers
Post by spinningmagnets » Oct 13 2018 8:18pm
There is a model of Fiat that uses 5S sub-packs that are about the size of a normal 12V car starter battery. I am waiting for a response from the original poster for exact dimensions, and also the model name.
5S nominal is 3.6V X 5S = 18.0V
If fully-charged to my recommended 4.1V, then 5S X 4.1V = 20.5V
A
fechter   100 GW
Post by fechter » Oct 17 2018 9:32am
Apparently the Fiat 500e battery modules also come in a 6s size.
I see quite a few of these things driving around, so the supply should be good.
Fiat 500e pack.jpg (259.7 KiB) Viewed 544 times
MODULE SPECIFICATIONS
Number of cells 6
Construction 6 in-series
Length/Total Length 11"/12.5"
Width 7"
Height 6"
Weight 28.5 lbs
Output terminal M6 nut
Amp Hour 75
Total Voltage 24vdc @64ah
CELL SPECIFICATIONS
Cell type Laminate type
Cathode material LiMn2O4 with LiNiO2
Anode material Graphite
Rated capacity (0.3C) 64 Ah
Average voltage 3.8 VDC
Maximum Voltage 4.2VDC
Minimum Voltage 3.0VDC
Inwo   10 kW
Post by Inwo » Oct 18 2018 1:32pm
Newer may be better. I could just squeeze a little over 60ah out of the ones I tested.
Which is fine, however the seller sold them as 75ah.
Oh, and they were new. Maybe needed cycling to come up. :?
Post by spinningmagnets » Dec 11 2018 8:18am
Here is an excellent video on removing the Prius hybrid battery. It doesn't just show the Prius battery removal, it is an excellent example of how to script a "how to" video. The actual battery removal is at 11:11 (after removing lots of car-body trim). Individual modules are exposed at 13:40. The number of cells inside each module is dependent on the model year.
Looks like Nickel-Metal-Hydride / NiMH chemistry
http://www.eaa-phev.org/wiki/Toyota_Prius_Battery_Specs
https://www.youtube.com/watch?v=Q3RCdrh666w
SlowCo   10 kW
Post by SlowCo » Dec 11 2018 8:53am
What a great video instruction on how to safely remove the battery pack out of my neighbors Prius to use on my ebike project... :lol: :wink:
blisspacket   100 W
Post by blisspacket » Jan 08 2019 7:03pm
Great thread.
The Prius NiMH does have those breathing nipples on the top. I bought a full Prius battery and used it charged at 280 volts or thereabouts. This was in an open boat. Each nipple got a scrap of scotchbrite in it, and I still have of those modules working from 2013.
Leaf battery modules are nice, especially with respect to not requiring any cooling or breathing adaptions. (As I recall, the Chevy volt does need a liquid cooling system incorporated into module use/adaption.) I bought in 2015 a complete Leaf salvage battery; vendor stated 18k miles. In 2018 I sold the last of the modules and they still delivered their considerable watt-hours.
Clearly the best zap for the buck comes from salvaged EV vehicle batteries. Gathering the pertinent data is difficult, but it's the smartest way to go.
miro13car   1 MW
Post by miro13car » Jan 09 2019 12:24pm
Recently I am building 2P11S pack from 2017 volt salvaged.
Owsome cells by LG Chem
Will post more
Norco
DogDipstick   1 µW
Post by DogDipstick » Jan 16 2019 8:48pm
Yes, I bought 4Kw of Volt cells for a steal. They quickly built a 14s 13Ahr pack that takes my BBS02 750W 16 mi. approx. ( 8.6 to 50%). I've been testing individual cells and getting good consistency: so far out of some 20-25 cells i've tested only three were thrown out due to not bouncing back. I charge at 13amps, put anywhere from 12.7-13.1 Ah in. from 3.245v to 4.145v. Ir is in the 1.5-1.7 milliOhm range consistently. I used a thermocouple to see temp when first charging and discharging, but saw no noticeable temperature rise when discharging or charging at different C rates. The crux when building packs is the one or two lesser capacity cells that stop the discharge when monitoring individual cells in packs. I regularly get 12.5+ Ahr out at my 14s 25amp max discharge throttle only, no petal. Average 20 mph all the way. I balance charge up to 6s/1000w and string the packs to get 14s. Working on the 20S pack for the summer right now, built of the same cells. They were spot on 383g. ea.
