Overclocker
ford ecosport 1.5 liter gasoline
how many amps do i need to start this?
i'm thinking Sony VTC5A or the cheaper LG HB6
Won't 4S at full charge destroy the (nearly-) empty lead-acid battery? 3S would be much safer in that regard.spinningmagnets said:4S / 4P, 16 cells.
This is the problem with lithium ion 3.7 nominal cells and 12v applications its easier to use 3.2v lifepo4 since 3 cell is not enough and four cells is too much voltage for the systems. But with lifepo4 4s is perfect.minimum said:Won't 4S at full charge destroy the (nearly-) empty lead-acid battery? 3S would be much safer in that regard.spinningmagnets said:4S / 4P, 16 cells.
There's a search function? OMG I had no idea.... :lol:Hillhater said:How many times does this topic come up ?,..why dont folk use the search function.
Icewrench said:Well here in my shop the only 4 banger is a 87 Camry 2.0. Surprisingly it takes near 200 amps to start turning over and a bit over 100 amps to keep it spinning.
True, but also beware if the main battery has died from an internal failure (common) ..Sunder said:There is a big difference between jumping a car with no battery attached at all, and one whose battery is a little flat or just old. .......
Food must be much more expensive down there...or you have more expensive standards than I do.Hillhater said:...cheap insurance.!..... For the price of a decent meal.
