Mikey_Builds
- Joined
- Aug 6, 2017
- Messages
- 19
Excuse my ignorance--
I want to run a 3000w mid drive Cyclone or 5000w hub and I also want ample distance and enough battery to cruise 35mph easily maybe even cruise around 40ish. I want to build it on the Enduro Frame.
My plan is to build a pack that is 20s8p built from Samsung 25R 18650 cells (Please suggest any other cells if you think they will be better or even cheaper-- current price for the 160 cells is $689.76)
The above pack will put out 72v and 20AH; 1440 watt hour. I believe also believe it will have available 160A.
Question: Is there any way to calculate distance and how much juice will be needed based on body weight on flat ground? One of my concerns is also hills. We have a ton of rolling hills here, with some being difficult to climb.
Request: Give your opinion on the above pack. I have thought of breaking it down to TWO 10s8 packs and connecting them in a series to leave more space in the frame's battery compartment. I will also likely use the Vruzend kit to connect the cells so I don't have the exact dimension of the 20s8p pack but I dig get a image from LiLei showing the dimension of the battery compartment on the Enduro frame.
Question: For a 3000w Mid like the Cyclone or a 5000w hub (likely a LeiLi) will the above pack give me what I want-- 35 mph easy cruising to keep up with traffic and hill climbing ability?
