BC168 vs UNA9 ?
ebike11   10 kW
BC168 vs UNA9 ?
Post by ebike11 » Sep 24 2017 5:32am
Hi guys
Is one better than the other or should i flip a coin?
Looking to balance my 10 cell pack.
Not sure if these are the only choices but Ive seen them a lot.
My budget is under 100 dollars shipped
Thanks
999zip999   100 GW
Re: BC168 vs UNA9 ?
Post by 999zip999 » Sep 24 2017 9:46am
I I have a UNA9 plus + you can also buy it with a battery nanny which will help charge multiples of battery cells. I do not have a battery nanny I bought the una9 and after I push the button I noticed they had a battery nanny for $20 more. I have A123 batteries that are high quality and may never need balancing so only tried 2 times as waste of time for my always balance A123 pack with 4.5 years and 1,054 plus cycles . A good battery is always good a battery that needs balance is Bad or needs much help a battery that always needs help or needs balance is junk. Batteries do not need balance. Junk batteries always need balancing and care. Junk as need a barbecue to br safe. Junk is junk. Be careful as it stores energy. Energy is fire.
999zip999   100 GW
Re: BC168 vs UNA9 ?
Post by 999zip999 » Sep 24 2017 9:52am
Plus the una9 is set as a 6pin a and a 3pin for a 9 cell. Look look before you buy. I have owned it for 3 months or if used it four times my batteries are always balanced without a balance charger. But I check before bounds after bounce before I ride I checked I checked I don't have a BMS so I check I check and I check so you must ....check check and check or buy a BMS . And hope it works. Did I say you must chat check and recheck.EZ check.
999zip999   100 GW
Re: BC168 vs UNA9 ?
Post by 999zip999 » Sep 24 2017 9:53am
How many times have you checked since I've asked not enough go check then check again
mistercrash   10 kW
Re: BC168 vs UNA9 ?
Post by mistercrash » Sep 24 2017 3:30pm
I have both and my BC168 has proven to be a lot more dependable and easier to set up.
I am so sorry that you are experiencing difficulty in your life, but if you send $10 at paypal.me/Ray1964
, you will be in my thoughts and prayers.
TheBeastie   1 MW
Re: BC168 vs UNA9 ?
Post by TheBeastie » Sep 25 2017 4:16am
I have had the BC168 and used it for many years but it did die after about 3-4 years.
I changed over to the CB86 which seems to just be a copy, been using this for close to 2 years now I would say.
As far as I know the BC168 isn't really made any more.
I have got the UNA9 but I haven't started using it but I really like the look and feel of it, looks really solid.
I think unless you have spotted a great deal (for example I grabbed the CB86 for $50 new on ebay) I would otherwise just get the UNA9 everytime.
If for any reason because you can split a large 18S battery pack in half and charge a battery pack that large in 1 go.. With S6 chargers its only 12S with one split or you could build a battery pack that you split into 3 sections for every charge but that really is just a bit too much stuffing around and 1 single plug/unplug-forget mistake and your battery pack/charger is going into meltdown.
Speed Kills Range, 10mph = 46 miles range, 20mph = 20 miles, 30mph = 8 miles rangehttps://goo.gl/1JNL53
Over Charging Kills ur battery bit.ly/1hzWKl4
Consider PAS as your only throttle https://goo.gl/Kg1F8F
Fuel-Cell is the ultimate battery coupled with 4th-gen Nuclear
https://goo.gl/TcKtHs https://goo.gl/ZhFFot https://goo.gl/gfa215
10 Square Miles of solar panels = 0.12GW average power! https://goo.gl/Ub1S39
John Bozi   1 MW
I love my BC168
Post by John Bozi » Nov 25 2017 10:29pm
jonescg   1 GW
1 GW
Re: BC168 vs UNA9 ?
Post by jonescg » Nov 25 2017 11:06pm
Yep, BC168 is the shit. I have balanced a 100 Ah battery with one. Took for ever, but nothing else came close.
Matador   10 kW
Re: BC168 vs UNA9 ?
Post by Matador » Nov 26 2017 3:19am
Bought one new on off eBay last April IIRC. :D
