Plausible to build custom variable voltage Lion charger?
fechter
Re: Plausible to build custom variable voltage Lion charger?
Post by fechter » Nov 01, 2017 11:15 am
I just saw this one in my Mouser spam. A Meanwell that's actually made to be a battery charger:
Not cheap though, $97.92.
https://www.mouser.com/ProductDetail/Me ... qQIWtCM%3d
Mean Well ENC-360 360W Desktop Single Output Battery Chargers provides programmable charging for lead-acid and Li-ion batteries. The chargers feature a built-in 3-stage charging curve, a programmable function to adjust the charging mode, and parameters for different battery characteristics. ENC-360 offers a wide input range (90V to 264VAC), built-in active power factor correction, a three-year warranty, and standard 7" width. The battery chargers meets UL/CUL/CB/CE/FCC safety regulations.
The 48v version looks like it should handle up to 14s Li-ion. 6A, no fan.
flippy
Post by flippy » Nov 02, 2017 4:09 am
that thing is not suitable for lipo. lead only.
x.l.r.8
Post by x.l.r.8 » Nov 02, 2017 4:59 am
345W 57.6V 6A Programmable Desktop Type Battery Charger for SLA & Li-Ion Batteries
57.6V Boost/55.2V Float Charge Voltage @ 6 Amps
Features
Recommended Battery Capacity: 25 - 65 Ah (Amp hours)
Input Voltage Range: 90-246VAC @ 47-63Hz
Compatible with both lead-acid (flooded/Gel/AGM) and li-ion (lithium-iron/lithium manganese) battery types
Built-in 3 stage programmable charging curve
Universal AC input/Full Range
Built-in active PFC function
Fanless design, with cooling via free air convection
Built-in temperature compensation function
Protections: Short circuit, over voltage, over temperature, battery under voltage, battery over voltage, battery reverse polarity protection
3 year warranty
Specifications
Efficiency: 94%
Temperature: -30 to 70 Celsius
Dimensions: 7.56" x 7.01" x 1.79"
Applications for Use
Radio systems backup support
Surveillance systems
Electric Scooter Charging
Intelligence is distributed nearly evenly, with only the occasional concentration in one person. The total quantity of Intelligence is a constant: as more people come into being, fewer and fewer get a sufficient amount for themselves.
Some say this has already reached homeopathic levels.
x.l.r.8
Post by x.l.r.8 » Nov 02, 2017 5:00 am
fechter
Post by fechter » Nov 02, 2017 9:37 am
Ah, but to program it, you need the SBP-001 programmer:
http://meanwellusa.com/productPdf.aspx?i=769#1
$53 at Mouser.
timmy66
Post by timmy66 » Nov 09, 2017 11:52 am
Someone has figured out the communication protocol, no need to buy Mean Wells programmer interface.
https://github.com/Zweikeks/meanwell-en ... -chargelog
from
http://www.irv2.com/forums/f54/program- ... 42716.html
Very nice, maybe the Mean Well protocol is documented somewhere?
The enp-360 variety (also with program port) might be a reasonably priced programmable power supply, although the enc-360 seems to be better with the CC mode in addition to CV.
