Knocking a battery pack together on the cheap
tjgaryiv60   10 mW
Post by tjgaryiv60 » Jan 08 2018 11:52pm
Dogman
You have helped me before thank you. I need a new battery for my fat tire off road bike.
I wanted to know if LIFEPO4 is a good option. I got a Mxus V3 DD motor and a power velocity
18 mosfet programmable controller. Battery current up to 70a and phase up to 200a. My current
battery is 72v 20ah with 40a bms. It is not powerful enough. Here are two pre-built pack options.
72v 40ah 60a bms LIFEPO4
https://www.aliexpress.com/store/produc ... 30b7as7wmA
72v 20ah 60a bms LITHIUM ION
https://www.aliexpress.com/store/produc ... f36avO1GhB
Jack
amberwolf   100 GW
Re: Knocking a battery pack together on the cheap
Post by amberwolf » Jan 09 2018 12:08am
If you need
tjgaryiv60 wrote:
Jan 08 2018 11:52pm
for more than momentary bursts, then anything less than that (like these)
is insufficient.
If you only need momentary bursts of current that high, and the BMS (and cells) can do that, then as long as the cells are really made for whatever the sustained current you'll need is, then they might work.
Otherwise you're (at best) pushing things to their edge too much, and that reduces the lifespan of batteries, and can overheat the power electronics inside the BMS (which is usually contained inside the pack where it can't shed heat).
