700 mile charge in 1 minute
Harold in CR
Post by Harold in CR » Jan 09, 2018 5:22 pm
Thanks to Justin, the forum is open source and NON-commercialized.
e-beach
Location: Any Los Angeles area beach I am at. Or Santa Monica or possibly the south bay beaches.
Re: 700 mile charge in 1 minute
Post by e-beach » Jan 09, 2018 5:47 pm
I think this one falls under the talk is cheap category. However if a Fisker solid state battery can take an enormous current while charging it could be possible. You won't get that current out of your wall socket. :lol:
Independent verification is need for this one.
:D
Favorite Quote: "This is L.A., sugar. There is no 'over the top." --- Chris Erskine
Current build: Liahona w/ cheap front suspension and suspension seat post. Yescomusa 36v 800w generic front hub motor. 15ah Headway triangle mounted pack. Tronsung 30 amp,
Previous Build:1992 Trek Antelope 800 - Bone Crusher (no suspension) - Yescomusa 800 watt 36 volt front wheel kit. Don't do it! Get suspension!!!
Harold in CR
Post by Harold in CR » Jan 09, 2018 8:14 pm
I took a stab at calculating the battery pack needed for 700 miles, then figured 450 Whrs/mile and my calculator went blank. Have to figure what voltage and amperage before calculating, then figure in 1 minute charge ?? I just don't see it happening.
Chalo
Post by Chalo » Jan 10, 2018 3:36 am
One day it might be possible. If that happens, it will be because batteries are better, and because cars aren't as horrifying as now, and because drivers' expectations aren't stupid/callously indifferent like now.
As for Henrik Fisker, I think he's probably just talking out his ass.
Punx0r
Post by Punx0r » Jan 10, 2018 3:52 am
The battery might be capable of it, but the wiring, connector and local supply probably won't be.
700miles x 450Wh/mi = 315kWh / (1/60) = 18,900kW = ~19MW
At 400V that's around 47,250A
Chalo
Post by Chalo » Jan 10, 2018 4:05 am
Do you think I'll need 12ga house wiring for 47kA, or will 14ga do?
Harold in CR
Post by Harold in CR » Jan 10, 2018 8:07 am
punxor has the same numbers I got with my calculations. I sometimes take a full 4.1v battery and connect it to a 3.0v battery to get it up to chargable voltage and the wire connection gets warm in a hurry. I'm a retired power company lineman, among other types of employment and have had huge plasma arcs over my head from
shorted transformers that would not equal 43000 amps, so I can actually visualize what the 1 minute charge would be. I vision substations glowing. :shock:
Maybe Henrik uses Kryptonite for the solid state materials ??
fechter
Post by fechter » Jan 10, 2018 9:32 am
If I extrapolate from a standard wire chart, it indicates 47kA would require a copper wire 29" in diameter (you need two).
Yes, the BS detector is going off.
Punx0r
Post by Punx0r » Jan 10, 2018 9:57 am
You hear of people recharging high performance RC lipo in under 10mins, so assuming 5-10x better performance with a speculative, probably solid-state future battery isn't too far fetched. However, charging your RC toy battery in 60 seconds may be practical, but there's a bit of a scaling issue with a car.
14 AWG should be ok as long as you keep the wiring infinitesimally short :D I hope you haven't got a big house!
markz
Post by markz » Jan 10, 2018 7:21 pm
On the market now - 150 miles on 10 minute charge. But you pay for it, which nets you a 400 mile pack.
Then he talks about Solid State batteries in which 500 miles for 1 minute charge. But the news anchor misheard and stated 700 miles for 1 minute charge. Which will take a very many years, if at all. What the cost is, who knows.
Yahoo is famous for its click bait article titles. Just be lucky Yahoo even posted a video for it, half the time they dont attach pictures to a story that 100% requires a picture.
Sunder
Post by Sunder » Jan 10, 2018 11:50 pm
I think the 700 mile in 1 minute is the theoretical "The battery won't catch fire" rate. This newer article here:
https://www.express.co.uk/life-style/ca ... ging-times
Says the car should charge 125miles in 9 minutes.
I use the reverse measure. Most cars seem to get about 18kwh/100km. 125 miles = 200km, 36kwh.
36kwh in 9 mins = 240kw charger required.
Imagine accidentally shorting that battery or charger...
eBike: Q100H on 16S with Phaserunner FOC Controller
eMotorscooter: Vectrix VX-1 on 36S
eCar: Mitsubishi Outlander PHEV... Waiting for warranty to expire
eHouse: Still on grid, but with LTO batteries and 3kw LF inverter...
After 5 builds, the best advice I can give, is start with high quality products. I prefer http://www.ebikes.ca
amberwolf
Post by amberwolf » Jan 11, 2018 2:57 am
I'm sure it will all work just fine, if you keep the liquid helium flowing.... ;)
Sunder
Post by Sunder » Jan 11, 2018 3:14 am
Warranty probably says: Battery warranty void if charged above absolute zero.
dogman dan
Post by dogman dan » Jan 11, 2018 7:19 am
On the other hand, if you could do a 200 mile charge in 30-45 min, that would work for pretty practical travel. Most folks will stop to eat at least every 200 miles.
Have to locate the charge station near someplace you would eat though, or have a cab ride that comes with the charge.
