my 18650 frame pack build
izeman   10 GW
Post by izeman » Jan 29 2018 10:18am
my lipo battery is aging, and is about 4 years old now. it's down to 80% capacity, and it is time to replace it. i never had a single issue with any lipos over the years, be it in my bike or in the quadcopter, rc car ....
still the 18650 cell looked interesting to me, and i thought how a switch could happen.
the current configuration is 8 packs of 6s 5.000mAh zippy 20c rc-lipos cells. the pack weighs around 6.2kg and has a nominal capacity of 3,7V * 12s * 5.000mAh * 4p = 888Wh.
i took a lot of measurement of the available space in my self-made frame, and the space available is 370x50x110mm. thanks to the great help and support of maddin88, we found a very good solution which uses the space ideally. totally i can fit 150 cells into the frame. 2 packs of 75 cells in a 15s3p configuration. the cells will be arranged in a 3s5p honeycomb layout and then folded. this will give a long pack of 50x105x350mm.
150 cells will make the capacity much larger. from 888Wh to 3,6V * 15s * 3.000mAh * 10p = 1.620Wh (almost double the capacity), at 6.8kg. the pack is more heavy because it has more volume, and fills the room much better then the lipos which needed a connection pcb in the middle.
the sag will be much worse than before, but due to higher voltage (44.4V compared to 54.0V) the current will come down and range may be doubled.
this is what the bike looks right now:
2014-08-23 at 14.05.37.JPG (102.63 KiB) Viewed 2287 times
izeman   10 GW
Re: my 18650 frame pack build
Post by izeman » Jan 29 2018 10:26am
the new batteries from nkon have arrived. 150x samsung 30q and some meters of 25mm and 10mm wide 0.15mm thick nickle. and some heat shrink and end cap's savers as well as kapton tape.
2018-01-11 at 15.38.45.JPG (115.72 KiB) Viewed 2286 times
first of all they were arranged in groups of 5 and glued together with hot glue. i 3d printed a little box where the batteries fit in quite tightly and are perfectly aligned before fixing them in 5p packs.
2018-01-25 at 19.13.04.JPG (81.17 KiB) Viewed 2286 times
2018-01-12 at 16.09.00.JPG (80 KiB) Viewed 2286 times
then some kapton tape is wrapped around each end to reinforce the very thin heat shrink:
2018-01-28 at 17.11.41.JPG (77.24 KiB) Viewed 2286 times
these are the 10x 3s5p packs that will make the two big packs
2018-01-25 at 22.16.13.JPG (84.52 KiB) Viewed 2286 times
izeman   10 GW
Post by izeman » Jan 29 2018 10:34am
a friend of mine bought a spot welder from Aulakiria https://endless-sphere.com/forums/viewt ... &start=250.
after some initial issue of too weak welds, and the great support here we found out that the battery was too weak. it's important to use a strong battery directly connected to the welder - no adaptors, no long wires in between.
after that, the welds came out beautifully and very strong:
2 (Case Conflict).jpg (89.17 KiB) Viewed 2285 times
2018-01-27 at 13.35.12.resized.JPG (92.49 KiB) Viewed 2285 times
each cell got a little black self adheasing paper ring. the whole cell is the negative pole, so if the heatshrink anywhere is damaged there is a high risk of a short circuit.
2018-01-27 at 15.49.34.JPG (101.03 KiB) Viewed 2285 times
the batteries where stacked and glued together with regular silikone glue and let cure over night
2018-01-28 at 17.29.45.JPG (81.79 KiB) Viewed 2284 times
then i could start welding the packs together:
2018-01-28 at 17.27.19.JPG (109.12 KiB) Viewed 2285 times
2018-01-28 at 17.15.30.JPG (99.95 KiB) Viewed 2285 times
you may notice some different color heat shrink. these are all the same cells from the same charge. but during glueing them together, i did it too slowly or used too much pressure, and the hot nozzle of the heat gun destroyed the heat shrink. so i had to replace some.
2018-01-25 at 22.16.56.JPG (50.87 KiB) Viewed 2285 times
2018-01-27 at 14.26.46.JPG (74.2 KiB) Viewed 2285 times
izeman   10 GW
Post by izeman » Jan 29 2018 10:35am
the big pack has solder fins for the balance wires:
2018-01-28 at 17.24.37.JPG (76.27 KiB) Viewed 2282 times
e-beach   100 MW
Location: Any Los Angeles area beach I am at. Or Santa Monica or possibly the south bay beaches.
Post by e-beach » Jan 29 2018 10:55am
Looking very nice so far! Subscribed.
:D
Favorite Quote: "This is L.A., sugar. There is no 'over the top." --- Chris Erskine
Current build: Liahona w/ cheap front suspension and suspension seat post. Yescomusa 36v 800w generic front hub motor. 15ah Headway triangle mounted pack. Tronsung 30 amp,
Previous Build:1992 Trek Antelope 800 - Bone Crusher (no suspension) - Yescomusa 800 watt 36 volt front wheel kit. Don't do it! Get suspension!!!
izeman   10 GW
Post by izeman » Feb 02 2018 9:34am
so it goes on. i made the mains connection. a 10mm wide 0.15 nickle strip.
first i cut of 5cm of insulation of the awg12 silicone wire and divided the wires in two parts, twisted those and tinned them.
then i pre-tinned the nickle and soldered the wire to it, pressing it down with a screwdriver bit by bit.
2018-02-01 at 18.10.35.JPG (157.5 KiB) Viewed 2157 times
2018-02-01 at 18.12.32.JPG (132.1 KiB) Viewed 2157 times
safety first. it's really important to isolate wires under voltage.
2018-02-01 at 18.13.08.JPG (140.67 KiB) Viewed 2157 times
pre-tinned the battery tabs as well. with a good soldering iron and 400°C this takes less than a second. so not much heat transferred into the battery.
2018-02-01 at 18.44.34.JPG (117.38 KiB) Viewed 2157 times
welded the strip to the battery. i don't know why, but there were some sparks flying and burnt holes in the nickle. so it doesn't look that nice, and i had to weld at some more points to have 6 valid welding dots.
2018-02-01 at 18.40.48.JPG (124.92 KiB) Viewed 2157 times
2018-02-01 at 18.40.54.JPG (128.37 KiB) Viewed 2157 times
all done, ready to test :) those are not the final wires. just for testing, to see if the BMS is working - which it does! all cells are within 7mV. not what i expected, but good enough. i thought that 5 parallel cells would level each other out closer than that.
2018-02-01 at 18.47.39.JPG (191.42 KiB) Viewed 2157 times
999zip999   100 GW
Post by 999zip999 » Feb 06 2018 2:24am
What amp rate are you going to use this pack at ?
e-beach   100 MW
Post by e-beach » Feb 06 2018 11:36am
Do you worry that the positive solder fins will be a potential short if they cut through the plastic wrapper and ground to the negative battery outer case?
:D
izeman   10 GW
Post by izeman » Feb 06 2018 2:08pm
I don‘t really worry, but there is a) extra capton tape b) paper rings and c) i will add some tape to the inner side after soldering as well. This should keep the risk to a minimum.
999zip999   100 GW
Post by 999zip999 » Feb 06 2018 4:16pm
Maybe there was a small air gap between the stiffer pos. End with mutli strand and solder combo. Giving a spark gap blow out. Maybe hold down with a chop stick if you have a third arm with hand attached.
izeman   10 GW
Post by izeman » Feb 10 2018 3:59pm
today i made the isolators. 0.7mm thick gfk. cut into 50x102mm pieces, then sanded and rounded the edges. i also made a slot for the wires.
2018-02-10 at 13.39.45.JPG (114.36 KiB) Viewed 1890 times
2018-02-10 at 13.44.10.JPG (120.97 KiB) Viewed 1890 times
2018-02-10 at 14.12.36.JPG (154.31 KiB) Viewed 1890 times
then those were glued to the battery with silicone
2018-02-10 at 14.57.44.JPG (166.92 KiB) Viewed 1890 times
before that i attached some additional isolation to the balance tabs. just in case ;)
2018-02-10 at 14.49.44.JPG (149.28 KiB) Viewed 1890 times
then the parts were folded together and held down by clamps to straighen the hole battery out.
now it's time to way for the silicone to cure.
2018-02-10 at 15.21.26.JPG (157.85 KiB) Viewed 1890 times
Animalector   10 kW
Post by Animalector » Feb 11 2018 10:01pm
looks great, nice work.
Andy
izeman   10 GW
Post by izeman » Feb 12 2018 10:25am
printed endcaps last night, they guide the wires and protect the ends of the battery
2018-02-12 at 07.41.32.JPG (86.77 KiB) Viewed 1793 times
added some extra protection tape. you can never have enough protection, right? ;)
2018-02-12 at 07.57.24.JPG (75.28 KiB) Viewed 1793 times
lots of silicone to glue the caps to the battery. they stick nicely, even with uncured silicone
2018-02-12 at 08.01.37.JPG (99.39 KiB) Viewed 1793 times
i also cut 0.5mm gfk sheets for the sides. they are absolutely necessary as they give stability and also isolate the nickle tabs (at the places were the battery was folded, the nickle sticks out)
2018-02-11 at 12.55.50.JPG (67.36 KiB) Viewed 1793 times
2018-02-12 at 08.11.07.JPG (86.08 KiB) Viewed 1793 times
and finally the clamps again. it's vital to make the battery as small as possible as the battery space is very limited. internal width is around 52mm, which is exactly the width of the battery with side covers.
2018-02-12 at 08.23.53.JPG (96.76 KiB) Viewed 1793 times
izeman   10 GW
Post by izeman » Feb 19 2018 7:52am
finished the packs over the weekend, and i'm really happy with the outcome.
i made some small caps to guide the balance wires. there are no sharp dents and the wires won't be bent to much.
the caps were designed with fusion360 and glued to the battery with the glue gun.
then one layer of 0.5mm GFK was glued to the bottom side.
one layer of foam to protect the upper side of the battery
heat shrink with a round hole in it to guide the wires through it
heat shrink already shrunk and ready to be mounted to the bike
and here it is mounted on the bike. mission accomplished :)
"fit's like a glove" has never been more true. it's a really snug fit!
999zip999   100 GW
Post by 999zip999 » Feb 19 2018 3:08pm
Very nice work and it fits in the battery box when you're done that's always a worry to you get it to fit. Good job
izeman   10 GW
Post by izeman » Feb 19 2018 6:11pm
999zip999 wrote:
Feb 19 2018 3:08pm
thanks! yes, it was a great moment when i let the battery slip in for the first time :)
unfortunately the battery is maybe a millimeter to wide. so i had to add some rubber seal to the inside of the side covers to move them away a bit. but it came out pretty good.
999zip999   100 GW
Post by 999zip999 » Feb 19 2018 8:23pm
Yes things change and hard to know the finished product. Good use of a rubber. Please let us know how this pack works out as far as voltage Watts amps and sag. Controller and motor. Thanks good luck
Raisedeyebrows   1 kW
Post by Raisedeyebrows » Feb 19 2018 10:57pm
Thanx for posting this build, feel like I'm getting closer to trying one myself, maybe after several more months of studying I'll be confident enough to jump in the shallow end of the pool.
Yuba Mundo w/BBSHD
Specialized Hard Rock w/9c clone, statoraid, hubsink
Trek Fuel 90 w/BBSHD
Above all run on 14s4p 52v li-ion
Ecobike folder 36v
Currie Flyer scooter 24v on 24ah of SLA
Every trip made with electric bike is one less car trip, saves money, no toxic fumes, less noise, less impact on roads.
e-beach   100 MW
Post by e-beach » Feb 19 2018 11:01pm
Nice work for sure!
:D
richmpdx   100 W
Post by richmpdx » Feb 20 2018 3:52pm
Very nice pack build. You do such meticulous work.
jumpjack   100 W
Post by jumpjack » Jul 29 2018 7:36am
WARNING!
This pack is very nice... but it's just a "pack", it's not a "battery".
This is a "pack" of cells:
Also this is just a "pack" of cells:
This is a "battery":
The difference is made by these:
Multiple version:
The point is: the "can" of a lithium cell is also its negative pole; it's wrapped with a thin plastic foil; if multiple cells connected together in parallel or series (like in a battery) touch one to the other, only this thin foil prevents short circuits. If it's a stationary battery, that's all you need.
But for road applications (bicycles, motorcycles, cars,...) you must take into account vibrations: the wrapping of two cells in close contact slowly wears out at each vibration; wears out, wears out... until the underlying alluminum bodies (i.e. electrodes) connect together, in an unpredictable position of your battery; and you don't want an unpredictable connection between cells in a battery.
The above shown "plastic things" are called "cells holder", but they also act as "cells separator", and they're a mandatory part in any road-battery (if you want a safe battery).
Of course they increase volume, weight and complexity... but also safety.
Note: if close cells inside a box touch one to the other until insulating wrapping wears out, nothing happens, because cells are not connected together.
izeman   10 GW
Post by izeman » Jul 29 2018 8:20am
it's nice of you to warn me, and tell me what a battery is. even a single cell is a battery, by the definition of it, but i won't argue on that.
and yes, it's very clear how heatshrink works, and what it does. and it's also clear that the whole can is the negative ground. and if negative and positive touch, bad things may happen. so far, nothing new.
but you may have noticed, each cell is glued to all its neighbors, there is extra capton tape around every cell, and all packs are held together by cfk plates which are glued to the cells again. there is not a single movement of ANY cell. not the slightest. and the whole "battery" or "pack of cells as you call it" is press fitted inside the frame. which by itself doesn't move a single bit.
so no worries. 8)
