(CLOSED) Passing the Hat to Thank Doctor Bass !
oatnet   10 MW
Post by oatnet » Mar 21 2009 1:14am
Most of us have seen and learned from the standardized battery tests Doc has run and shared for us. Many of us have benefitted by his advice and ideas. Lots of us have benefitted from cheap a123 packs he has had up for sale. Whenever a vendor posts a new cell on E:S, we say 'send it to Doc for an impartial test.'
I had an idea of how we could thank Doc for all his hard work, by giving him the ability to take his battery testing to the next level. So far, Doc's testing has been limited by the capabilities of his CBA-II. You may have seen elsewhere on E:S mention of CamLight System's CC-400, a Programmable Electronic Load that would allow Doc to use his CBA-II to discharge-test batteries at up to 400w:
http://www.rcgroups.com/forums/showthread.php?t=938266
The CC-400 costs $389+shipping, so I'll throw $50 into the hat towards one of these for Doc, anyone else want to pitch in?
-JD
Edit - this has been funded and Doc has his CC-400, so I am adding (CLOSED) to the title.
PS - Doc sorry to embarass you with the Public Display, but THANKS for all your hard work!
voicecoils   10 MW
Re: Passing the Hat to Thank Doctor Bass !
Post by voicecoils » Mar 21 2009 1:32am
If it means 1-10C tests of Headway cells can be accomplished, put me down for $US25 :D
Paypal can be arranged when an adequate level of donation pledges have been made.
CamLight   10 kW
Post by CamLight » Mar 21 2009 1:44am
I think JD has a great idea here and CamLight would like to help out. I'll make a CC-400 available for $339+shipping. This is $50 off the regular price. Doc has some some great testing for E-S and we'd like to see him be able to do more testing as cells evolve and power levels go up!
Using our CC-400 load with Doc's CBA-II will bring his total discharge power capability to 500W continuous and over 650W intermittent, at current levels up to 150A for single Li cells. In addition, the CC-400 will allow him to set the CBA to a very low discharge current level (leaving the rest for the CC-400). This will significantly increase the accuracy of the CBA's measurement of the cell/pack voltage because of the reduced voltage drop in the CBA's leads.
We urge everyone to chip in whatever you can, Doc deserves it! :mrgreen: :mrgreen: :mrgreen:
oatnet   10 MW
Post by oatnet » Mar 21 2009 2:04am
Voicecoils I agree - get the pledges in line, then Paypal. Thanks for pledging!
Wow Camlight, vendor support! Thanks for joining in - now we are already $125 on our way!
-JD
Deepkimchi   1 kW
Post by Deepkimchi » Mar 21 2009 2:14am
I'd be good for $ 20...
DK
Bike: Cheap Korean Alton
Motor: 5304 Crystalyte rear mount
Controller: Crystalyte 72V 40A
36V (10ah) Lifebatt - the last from Gary G before Apr 08
36 V (10 ah) cells from AndyH - assembled, tested and ready to ride
Tires: Maxxis Holy Rollers
Down to 19 cells..
flip_normal   100 W
Post by flip_normal » Mar 21 2009 4:26am
I'm good for $20....Thanks Doc.
docnjoj   100 GW
Post by docnjoj » Mar 21 2009 8:23am
Put me in for 25 USD!
otherDoc
E-bike stable at our house
Steintrike Mad Max full suspension trike rear Cute 100H going on: Whoops, Cute wheel broke but I fixed it.
Sun USX delta trike EbikeKit small geared front wheel sort of front suspension for wife
Agniusm/A123 AMP 20 36 volts on the Steini has been taken off.
2x16000 Multisport from HK now gone as they died after 2 years
New Luna 10S bottle battery 13.6AH now on mine
Relatively New 10S4Px2 for wife's bike giving 20ah @ 40 volts home made Panasonic from Tumich. BMS's rule.
GGoodrum   100 MW
Post by GGoodrum » Mar 21 2009 10:33am
I'll go in for $50 as well. As the cells get better, they will need to be tested at higher and higher levels, to really document true capabilities and discount the hype. One question I know I'd like answers for is just how much better, if at all, are PSI/BMI cells over the Headway 10Ah cells JD is using? This higher limit will let Doc get the answer, I think. From my own tests with early "green" PSI/LiBeBatt cells, although they claim that these are 10C continuous, what I've found is they really aren't usuable above about 7-8C, and that is peak. Above that and the voltage drop is just too much. I'm guessing what Doc will find is that the Headways are closer to their 4-5C rating than the PSI/BMI are to their 10C ratings. In any case, hard to justify the pretty significant price difference. I'm also curious to find out if the newer "grey" cells have better performance over the original green ones.
One thing I've found with pretty much all LiFePO4 cells, from the lower C Ping/duct tape variety, upto and including a123s, is that in an EV application, the cell's C rating for continuous, is closer to a peak load you can expect to get, and not not have the voltage sag so much that it won't deliver the watts. I think Doc's continued tests will see if my general observations are valid.
-- Gary
wanders   100 W
Post by wanders » Mar 21 2009 11:43am
I'll pledge $20 US - Doc does great work!
Willie
docnjoj   100 GW
Post by docnjoj » Mar 21 2009 12:20pm
Who should we send the money to?
otherDoc
nicobie   10 MW
Post by nicobie » Mar 21 2009 12:23pm
Put me down for $20 also.
The good doctor :twisted: is nice to have around.
Nick
Take it easy... but take it. (Woody Guthrie)
my eTownie build thread: http://endless-sphere.com/forums/viewto ... =6&t=23701
Magazine article https://www.electricbike.com/nicks-etownie/
oatnet   10 MW
Post by oatnet » Mar 21 2009 1:38pm
Here are the totals so far:
oatnet 50.00
voicecoils 25.00
Camlight 50.00
Deepkimchi 20.00
flip_normal 20.00
docnjoj 25.00
GGoodrum 50.00
wanders 20.00
nicobie 20.00
Total 280.00
Wow, thanks everyone! Half a day, and we are already within $109 of the $389 we need for the unit, not including shipping. Camlight, how much additional will shipping to Doc up in Canada be?
docnjoj, once we have enough pledges to fund the gift, I guess we should send our pledges direct to Camlight, if he is OK with piecemealing it like that.
If you are thinking of contributing, please don't be intimidated by the pledges so far - the goal is just in reach, and $5 still says 'Thanks'!
-JD
slayer   1 kW
Post by slayer » Mar 21 2009 1:51pm
oatnet wrote:Here are the totals so far:
oatnet 50.00
voicecoils 25.00
Camlight 50.00
Deepkimchi 20.00
flip_normal 20.00
docnjoj 25.00
GGoodrum 50.00
wanders 20.00
nicobie 20.00
Total 280.00
-JD
yeaaah ok ...you re right oatnet put me in for 10 bucks.
slayer   1 kW
Post by slayer » Mar 21 2009 3:04pm
hey guys follow this link right now and see the doc himself on tv
http://www.tvinternetgo.com/internettvcanada/tva.html
lol... it is back to the future 3 on tv
Rassy   10 MW
Post by Rassy » Mar 21 2009 3:39pm
I don't even pretend to understand what Doc does.
But it is thanks to members on this forum that led to the purchase of duct tape LiFePO4 last year, which is doing great so far, but will need replacement some day. And that is when I expect work like this will help in making a good choice.
Put me in for $20.00 USD.
-Rassy-
Two Delta Trikes equipped with a Bafang BBS02
viewtopic.php?f=28&t=88536&p=1291260#p1291260
Doctorbass   100 GW
Post by Doctorbass » Mar 21 2009 4:08pm
:shock: :shock: :shock: :shock: :shock: :shock: :mrgreen: :mrgreen: :D :D :D :D :D :D
Hey guys!!... that's too much!!..
You make me feel shy!... :oops: but.. I still appreciate that generous idea!
Let's test those baby at higher C !! guys!! :twisted:
I'll put the balance amount for the total 339$ +50$ :wink:
oatnet 50.00
voicecoils 25.00
Camlight 50.00
Deepkimchi 20.00
flip_normal 20.00
docnjoj 25.00
GGoodrum 50.00
wanders 20.00
nicobie 20.00
Rassy 20.00
Total 300.00$
+ Doc (balance amount)
Cam light .. have you one of these great product for me!!! :wink: :mrgreen:
I have to say Thanks you very much guys.. i'm very impressed by this action you all contrinuted!!
That is another great proof the E-S members are so nice and so special!!!
Special thanks to Oatnet that had this idea!!..
I'll comeback in fre hour.. I have some visit for the dinner now
Thanks you :
oatnet
voicecoils
Camlight
Deepkimchi
flip_normal
docnjoj
GGoodrum
wanders
nicobie
Rassy
I still have many cells i received to test.. including the BMS and other headway.. and some K2 energy.
Doc
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
CamLight   10 kW
Post by CamLight » Mar 21 2009 4:10pm
oatnet wrote:Wow, thanks everyone! Half a day, and we are already within $109 of the $389 we need for the unit, not including shipping. Camlight, how much additional will shipping to Doc up in Canada be?
-JD
Leaving for the weekend now but I'll calculate the shipping cost Sunday night and post it.
No problem having each contributor sending their money individually. I'll PM each person with my Paypal address. :D
CamLight   10 kW
Post by CamLight » Mar 21 2009 4:16pm
Doctorbass wrote:Cam light .. have you one of these great product for me!!! :wink: :mrgreen:
Doc
I'm currently assembling two 2,000W loads (five CC-400's each) for other clients but as soon as they're done, I can get your unit assembled, burned-in, tested and out to you. Perhaps by next weekend but most likely early the following week. I'm sorry Doc, I know the wait will be tough. :( :(
voicecoils   10 MW
Post by voicecoils » Mar 21 2009 7:26pm
CamLight wrote:I'll PM each person with my Paypal address. :D
Excellent, I'll keep my eye out for the PM then.
liveforphysics   100 GW
Post by liveforphysics » Mar 21 2009 8:15pm
Put me down for something too. I like Doc :) I'm sending him a big carepackage soon :)
oatnet   10 MW
Post by oatnet » Mar 21 2009 10:57pm
Doc, you deserve this, thank YOU!
I don't think we should let you shut it down just yet though (and cut into Doc's electric car fund :lol: ). I let Doc know he missed slayer's post so we'll add that in, liveforphysics let us know how much to put you down for on top of that LiCo (I am guessing <grin>) care package you are sending.
If there is anyone else who wants in, now is the time...
-JD
Post by liveforphysics » Mar 21 2009 11:06pm
Put me down for $40. I was planning to send him some giant resistors just for battery testing (along with some wicked LiPo cells), but I think with this sweet testing setup, he wont need the resistors.
I'm looking forward to seeing LiPo discharge graphs overlapped with LiFePO4 cells at high currents :)
markcycle   10 kW
Post by markcycle » Mar 21 2009 11:45pm
Put me in for 20 just let me know where to send it
Mark
Doctorbass   100 GW
Post by Doctorbass » Mar 22 2009 12:00am
OK guys, :mrgreen:
I think this is enough money to get this great tool no
JD, thanks for all this, Let me please pay my part of that tool! :wink:
Thanks Slayer and Liveforphysics and Markcycles too!!!
Now, let give Camlight enough time to build units :wink:
I'll do my work and prior read the entire online user manual :lol: :wink:
My CBA is now 100% fully operational and have the best mosfet upgrade availlable (thanks Camlight!) and is ready to meet this new companion !.... for the coming HIGH AMP TESTS ! :twisted:
I keep some wire size AWG 0, 1, 4 and 6 for that :twisted:
Doc
two large high cfm blowers etc... the test setup will just be perfect !
Doctorbass   100 GW
Post by Doctorbass » Mar 22 2009 12:08am
I think the best way would be to send every of your precious contributions directly to John (Camlight)
and indicate this note: I Paid it forward to Doctorbass for a green planet :mrgreen:
John, I let you decide how you would like to proceed for that.
Let me know if it still miss something :wink:
Doc
