Will this BMS and Charger pair nicely for a 13s3p pack?
joe7dust
10 µW
10 µW
Post by joe7dust » Feb 09, 2018 12:26 pm
Charger
BMS
I would like to find a US supplier of BMS if possible, the shipping is rather long on this one and I don't see any from the US on ebay.
Philaphlous
Re: Will this BMS and Charger pair nicely for a 13s3p pack?
Post by Philaphlous » Feb 09, 2018 2:50 pm
Charger = NO!!!! I have the identical charger and it's a lead acid charger. It charges at a cv of 56.6 although my bms will cutout around 54.4v...it's not good. Im using it because it works but it's not ideal.
Bms = Maybe. It doesn't have any balancing features and it looks only rated for 15amp discharge current...
joe7dust
10 µW
10 µW
Post by joe7dust » Feb 09, 2018 2:53 pm
You use the charger with a lead acid battery? The seller of the 48v 1000w front wheel kit I got says my pack needs to output 48v at least 12amp continuous.
Next possible chargers seem double in price and not located in the US, found these two: https://www.aliexpress.com/item/58-8V1- ... 83439.html https://www.aliexpress.com/item/OPS-48V ... 16824.html
I'm waiting to hear back if 12s3p, 13s3p, or 14s3p would be best for this motor.
Philaphlous
Post by Philaphlous » Feb 10, 2018 8:02 pm
It said it was for li ion but it's not really well suited for it. I think its a hacked charger since it doesn't drop current once it reaches 54.8v... Just go with a 13s configuration. I've got a 48v hub and 13s works perfect
joe7dust
10 µW
10 µW
Post by joe7dust » Feb 10, 2018 8:13 pm
I don't know if that first charger I linked will go up to 54.6 that 13*4.2 need for a full charge.
docw009
Post by docw009 » Feb 11, 2018 7:54 pm
For the BMS you chose, I don't see any mention about a balance function in the specifications. Sometimes they will call it a balance BMS, but you want to see the balance current listed in the specs.
I bought this one last year. Haven't used it yet. I think it took weeks to arrive.
https://www.ebay.com/itm/35A-BMS-PCB-bo ... 4b1541d165
