Cells sold with pre-soldered tabs
ThierryGTLTS   100 mW
Post by ThierryGTLTS » Feb 11 2018 7:27am
Has anyone used Li-ion or LiFePo4 cells sold with pre-soldered tabs :?: :!:
For example http://www.batteryspace.com/lifepo4-326 ... assed.aspx
Or http://www.batteryspace.com/A123-System ... 0-mAh.aspx
That way you don't have to use a spot welder.
Also this seems to be interesting http://www.batteryspace.com/battery-hol ... older.aspx
I plan to do a pack using that method, any advices welcome :!: :!:
Thierry
Buk___   10 kW
Re: Cells sold with pre-soldered tabs
Post by Buk___ » Feb 11 2018 8:34am
ThierryGTLTS wrote:
Feb 11 2018 7:27am
Thierry
NKON will also add tags (either U or Z) to the cells of your choice for +€0.55 per.
Punx0r   10 GW
Post by Punx0r » Feb 12 2018 3:31am
Yes, 18650 li-ion from NKON with tags. It works OK but is more work and not as neat as a spot-welded pack and I'm not sure I'd do it again as there is now more choice of spot welder's available.
