BMS for 48V to 400V lithium-ion battery pack
ENNOID   10 mW
Post by ENNOID » Feb 20 2018 8:22pm
Hi,
I'm looking for an open source BMS (Battery Management System) which would allow me to develop my own electric vehicle lithium-ion battery pack for voltages range from 48V and up to 400V.
The problem I am encountering right now is the lack of any medium voltage open source BMS with advanced functions available on the market as far as I know. After looking on the internet for documentation and related projects, the closest thing (open source) I have been able to find, is this very cool open source 12 cells BMS :
- https://github.com/DieBieEngineering/DieBieMS
This BMS has several interesting features that I am looking for:
- STM32 MCU configurable through USB with the user interface developed for the VESC-project
- CAN Bus
- Integrated SD card for DATA logging
- Integrated pre-charge and charge/discharge enable circuit.
Despite this, the rest of this BMS is limited to 12 cells /approx 48V and is using an outdated LTC6803 integrated chip.
Considering the voltage limitation of the DieBieMS, I am tempted to start the development of a similar BMS, based on it, but capable of handling a 400V/96S cells battery pack. For this, a Master and some daisy-chained slaves boards will be required instead of just one single board. The 16 cells "bq76PL455" from TI seems to be a better choice compared to the LTC6803:
- www.ti.com/lit/ds/symlink/bq76pl455a-q1.pdf
So far, I just started the schematics on Kicad ... ( after all, I have a family to take care of, and a full time job + side business, but I still have some time somewhere for this kind of project)
The project files are available on github at :
https://github.com/EnnoidMe/ENNOID-BMS
Just for getting some attention, here is a related photo of a well documented TI evaluation BMS board that I would like to copy and operate with an STM32 MCU + some add-ons:
Does some people here are interested for such a system in the open source ecosystem? Suggestions and ideas are very welcome :D
Thanks
ENNOID   10 mW
Re: BMS for 48V to 400V lithium-ion battery pack
Post by ENNOID » Feb 23 2018 11:35am
After looking on the web I found those threads related to BMS:
- viewtopic.php?f=14&t=63863
The part used has been discontinued... so that killed the project.
Another user from previous thread listed above "methods" started a thread about the use of an up-to-date LTC6811:
- viewtopic.php?f=14&t=88358#p1288949
I personally think this chip is worth to look at, similar to TI bq76PL455, but only 12 cells capability instead of TI's 16 cells, for almost the same price tag. So I still think TI IC is a better choice... ( cheaper and less components for the same pack voltage...)
Another similar approach with outdated LTC6802, but only slave board:
- https://github.com/rickygu/openBMS
Project is quite old and no development since 2014...
Another semi-open source BMS far more advanced and maintained also based on LTC6811 and STM32 is this one:
- https://www.foxbms.org/typo3/index.php?id=4
This foxBMS is exactly what I was looking at and is nearly completed :D
ENNOID   10 mW
Post by ENNOID » Feb 23 2018 3:51pm
This www.foxBMS.org project is badass:
ENNOID   10 mW
Post by ENNOID » Feb 24 2018 4:26pm
After a thorough inspection of this "FoxBMS", I do really see "german engineering" in this project... "system is over-engineered" :roll:
The redundancy and safety is too much implemented in the hardware. I think their approach is just too expensive. (cells are monitored by two costly IC and two MCU for ensuring safety)
ENNOID   10 mW
Post by ENNOID » Jul 13 2018 1:28pm
So far, it seems that I am alone in this thread. I haven't put much effort so far in this project anyway.
I now bring the fact that I just realized how the development board DC2350A-B and the related DC2026 control board developed by analog device seems to offer a good alternative for developing a proper BMS. It seems like a better starting point than the other development boards.
It is equipped with an LTC6813 which is a next gen IC capable of monitoring & balancing up to 18 cells (72V) with a minimal external circuit. It can communicate through an ISOSPI interface which is apparently way more reliable than what TI is offering.
See doc:
http://www.analog.com/media/en/dsp-docu ... 2350AF.PDF
fechter   100 GW
Post by fechter » Jul 13 2018 2:29pm
There isn't much around that can do over 20s cells. Most of them are very expensive. If you look around on DIY Electric car you can probably find various approaches to the problem. https://www.diyelectriccar.com/
Some ES projects:
Speedict viewtopic.php?f=14&t=73354
Tiny BMS viewtopic.php?f=31&t=78552
Bluetooth BMS viewtopic.php?f=14&t=88676&p=1386696&hi ... o#p1386696
Adaptto viewtopic.php?f=31&t=58190&hilit=adaptto
I like the TI chip. There should be a way to daisy chain 16s modules to accommodate higher cell counts.
Way back when, I designed and built my own BMS for LiFePO4 cells, since there was practically nothing on the market at the time. It was good clean fun and I did finally make some boards that worked but it was WAY too much work and too time consuming. Nowadays, I look for inexpensive off the shelf boards that I can combine or modify to meet my needs rather than building from scratch.
c10yas   1 µW
Post by c10yas » Dec 13 2018 2:42pm
Hey,
I got linked here from the ennoid-bms git. I'm designing a BMS for the FSAE competition based on the LTC6813 with reliability and low cost in mind. We're in the process of completing testing of the design and would love to share our work if it helps progress this project. Linked below is the git repo where we have the designs. The BMS stuff is being designed in Altium, but Altium has a free schematic viewer and I'd be happy to export it to kicad when we're done developing, I apologise for the badly documented git in advance
https://github.com/Illini-Formula-Elect ... Slave_2019
Chai
