36v BMS + charger
rupy   1 mW
36v BMS + charger
Post by rupy » Mar 10 2018 7:12pm
Hi I'm looking for a kit that includes BMS and charger.
Anyone seen something like that around?
And if not how do you match the BMS with the charger?
More specifically, is it the BMS that knows when to cutoff the charging?
So then you just supply the BMS with 36v? Or does it need to be higher?
Raisedeyebrows   1 kW
Re: 36v BMS + charger
Post by Raisedeyebrows » Mar 10 2018 10:09pm
In the Battery FAQ there is information, read 3 comments down:
https://endless-sphere.com/forums/viewt ... 14&t=26621
Yuba Mundo w/BBSHD
Specialized Hard Rock w/9c clone, statoraid, hubsink
Trek Fuel 90 w/BBSHD
Above all run on 14s4p 52v li-ion
Ecobike folder 36v
Currie Flyer scooter 24v on 24ah of SLA
Every trip made with electric bike is one less car trip, saves money, no toxic fumes, less noise, less impact on roads.
rupy   1 mW
Post by rupy » Mar 16 2018 9:59am
I can't find the info about what voltage the charger should be.
When I search on ebay I get 42v chargers for 36v packs is that right?
999zip999   100 GW
Post by 999zip999 » Mar 16 2018 4:33pm
Yes for a simple answer. The charger should match the type of battery you have and the voltage. 10 cells in series at 4.2 volt equals 42 volts for a 36v battery.
rupy   1 mW
Post by rupy » Mar 21 2018 1:41pm
But what says that 3.6v cells want 4.2v to charge?! And why?
Would f.ex. this do: https://www.ebay.com/itm/42V-2A-Charger ... 3013264877
rupy   1 mW
Post by rupy » Apr 03 2018 1:00pm
Hello?
